Espritmodel.com Heli Air
View Poll Results: If you are reading this thread are you an IOM owner
Yes 26 49.06%
No 27 50.94%
Voters: 53. You may not vote on this poll
Old May 17, 2012, 05:52 PM
Australia, QLD, Brisbane
Joined Oct 2007
Sofar noted charistics
With my boat, have noted 2 things that stand out . On a run the stern seems to stay well attached to the water(squats) and only nosedives @ the very top of A,but has no trouble sailing downwind with top boats of my fleet,& I donot have a good rudder design as yet,also have too much wetted surface on fin.The other, which is a problem.!! In light conditions when I tack the boat. it seems to sit uprite for several sec. before heeling & accelerating esp. @ bottom mark where I lose places, I try to do right things,tack slowly,bear off slightly crack main sheet slightly,but I always loose places to round bilge hulls. Any thoughts John
ronahearn is offline Find More Posts by ronahearn
Old May 17, 2012, 11:59 PM
Silly Old Fart
CaptainBit's Avatar
New Zealand, Wellington, Masterton
Joined Mar 2006
Originally Posted by GER 87 View Post
Are you bored seeing all this Lintel / BritPop / Cheinz and what have you thingies. Well now for something totally different than the current trend.
Check out the bottom posting in one of the German RC sailing forums : http://www.rc-network.de/forum/showt...m-22.04-in-USH
Comment from one of our top class RM skippers. Design is fast, points very high, neutral helm in the puffs and basically sails as stable as a well trimmed RM.
GER 87, do you have the contact details for the designer of this IOM?
I have a friend here in NZL who is very keen to acquire a set of plans for it.
Any help you can provide would be much appreciated.
CaptainBit is offline Find More Posts by CaptainBit
Old May 18, 2012, 02:21 AM
john m taylor's Avatar
Fleetwood, UK
Joined Dec 2010
RE: Sofar
Ron, thanks for the comments. Initially its hard to make an assessment without watching the boat perform myself. Therefore, im purely using my imagination to picture what is happening by what your saying.
When the boat is floated in the tank, is the transom sitting on top of the water, or is it immersed in the water. Ideally the transom should be sitting on top of the water. Adjust the lead ballast or internal ballast to suit.
Most IOM yachts will nose dive at the very top end of the A-rig.
I recommend that you use David Creed foils with Sofar, these foils are proven. Your foils might be the reason why the boat stays upright before heeling. In the UK Championship at Eastbourne 2011, we were competing on the final day in light wind conditions, I got myself back into A-Fleet and remained there with my boat.
I recommend you make the changes and then assess the boat again.
A wonderful finished product, built by Stefano Fasi (Italy)
Name: Sofar (IOM).jpg
Description:
JT
john m taylor is offline Find More Posts by john m taylor
Old May 18, 2012, 02:46 AM
Joined Oct 2007
Thanks John, will float test, might have probs.with foils in oz.
Old May 19, 2012, 06:57 AM
Joined May 2012
Just a quick thought - if you have to much mast rake you can find the issues you describe occurring.
Tony
basildog is offline Find More Posts by basildog
Old May 19, 2012, 09:38 PM
Joined Oct 2007
No the mast is less than 1 deg from vertical,weather helm is good,going sailing now, wind is light ,will investigate further , no doubt it will be simple when I find out why it happens .
Creers
Old May 20, 2012, 03:04 PM
Joined May 2012
Attachment 4871835
JT
Stefano Fasi??
The design of this boat is very similar to my XS Project !!!
ITA09 is offline Find More Posts by ITA09
Old May 21, 2012, 04:11 AM
Fleetwood, UK
Joined Dec 2010
Interesting the two boats do look similar, but on close inspection the hieght of the bows are different and looking at the 'hull rocker' of both boats, they are different too. But I know what you mean about the two boats being similar when you first look at them. Where does your 'XS' project originate from??
JT
Old May 21, 2012, 05:44 AM
GER 87's Avatar
Joined Apr 2012
Hi,
sorry for the late response haven't been reading here for a few days.
The design is not available as a plan but only as a completed boat built to deck level. Having seen some of these boats and taking into account the skills, tools and time going into the build and finish of one of these boats, I strongly doubt that this would actually be anything for even a pretty skilled home builder.
GER 87 is offline Find More Posts by GER 87
Old May 21, 2012, 10:27 AM
Joined May 2012
JT
Born from my head drawn on my Pesonal computer 02-2011.This project by me later sold the team BOXER XS Ronconi ITA-39 Tancini ITA-59 Mazzini ITA-171
Many photos
http://www.flickr.com/photos/2868305...86498090/show/
Old May 21, 2012, 10:56 PM
United States, CA, Alameda
Joined Nov 2010
I am going to be building a new rig for my IOM later this week when all the parts arrive. I have some T-9 11MM mast sections coming from Washington state. Anyone want to share their rig building tips? Planning on using clip on spreaders and terminating the shrouds where they attach to the mast instead of running shrouds all the way to the top inside the mast and having them attached to the mast head fitting.
That sofar design looks fast. Are there any of those boats in the US? Ryan
Rssailor is offline Find More Posts by Rssailor
Old May 22, 2012, 02:41 AM
Joined Oct 2007
Hi , From Sofar AUS 65, I run H.Ten.10.8mm mast , Shrouds exit front of mast,fixed to masthead Chainplates 20mm back,clipon spreaders,no mast prebend.no prob. with forstay tension ,aprox 8mm round in main luff, & mast stows in box with no probs.Sofar,realy truck in a breeze, but I think I have Fore/aft trim Probs, Stern down 3mm ,reballisting and will give another try.
Old May 22, 2012, 01:20 PM
United States, MI, Bloomfield Hills
Joined Feb 2010
Whose sails are you using? You may want to ask the sail maker for his thoughts on how to build the rig.
I used to use one of those masts. Those masts are pretty stiff so I suggest you have the sidestays pretty low, about 500mm down from the forestay, and just have a hook with the stays connected at the front of the mast. I used 25mm of pre-bend but that may vary depending on whose sails you are using. With that mast section and 25mm of pre-bend you will have a lot of forestay tension if that is what you are looking for.
It is not easy to bend a 7075 T9 mast, you need an actual tubing bender to bend that material. I assume it is the Easton thick wall tubing.
TedFlack is offline Find More Posts by TedFlack
Old May 22, 2012, 10:07 PM
Joined Nov 2010
I am using Vector sails. How would i prebend the rig? Where are you suggesting putting the spreaders? I am going to use one of those isobar headstay fittings.
Really hoping to get a rig where headstay tension is a non issue. Ryan
Old May 22, 2012, 11:53 PM
8387mike's Avatar
Perth Western Australia
Joined Jul 2009
A good reference to use is this by Anders Wallin and Craig Smith (these are readerly available on the net)
And how to build a rig by Radio Sailing Shop
http://radiosailingshop.com.au/index...9337b4ba297311
8387mike is offline Find More Posts by 8387mike
Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion tend2it Multirotor Talk 2529 Apr 26, 2008 07:45 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 10 Jan 12, 2008 11:33 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 32 Jan 03, 2008 03:02 PM
Discussion General Discussion PLD Australia 172 Nov 27, 2006 10:26 PM
General Discussion / Training Area zax Site Chat 0 Oct 03, 2001 01:48 PM
