View Poll Results: If you are reading this thread are you an IOM owner
Yes 26 49.06%
No 27 50.94%
Voters: 53. You may not vote on this poll
Old Mar 27, 2012, 02:49 PM
FWAL is offline
Find More Posts by FWAL
Flying without a licence
FWAL's Avatar
United Kingdom, Wales, The Mumbles
Joined Dec 2010
Hi Brian
Thanks for the idea, if the pot recess filling with water does become a problem then I can see myself getting out the saw and doing some balsa bashing. Normally I doubt hardly any significant amount of water will wash over the sides, it's just that during Sundays racing the wind direction was forming larger than normal waves in the racing area.
The Pot is a clean Dulux paint match pot and despite a good test last Sunday from both water in the recess and hull everything that should stay dry did (thank goodness)
Mark
FWAL is offline Find More Posts by FWAL
Old Mar 27, 2012, 11:27 PM
bfox1 is offline
Find More Posts by bfox1
Canada, BC, Victoria
Joined Jul 2009
Hey Metman, Go talk to your favorite hull builder or the red boat captain. They have a local and inexpensive fix for you. Just a trip to the bicycle shop involved.
bfox1 is offline Find More Posts by bfox1
Old Mar 28, 2012, 04:33 PM
BAJAN SAIL 51 is offline
Find More Posts by BAJAN SAIL 51
BAJAN SAIL 51's Avatar
Joined Nov 2011
running that tube down to the fin box is going to bring water into the pot reses area as the boat sailmove foward, you need that tube going aft for it to work . tony/g
BAJAN SAIL 51 is offline Find More Posts by BAJAN SAIL 51
Old Mar 29, 2012, 02:22 AM
FWAL is offline
FWAL's Avatar
Joined Dec 2010
This could be the case but I hope not. If there is enough pressure, turbulence to push the water from the fin box up the tube into the pot recess then I would have a serious problem with the fit between the fin and hull, which in turn would cause terrific drag
The fin fits pretty good in the hull. I just need to improve the leading edge slightly as this is the area of maximum pressure build up. The trailing edge has an excellent fit with the hull and there is a small gap on either side. The water that does enter the box is probably affected more by capillary action than external factors.
Old Apr 02, 2012, 02:04 PM
FWAL is offline
FWAL's Avatar
Joined Dec 2010
The pot recess drainage tube worked All but a small drop would remain in the well and the hull remained pretty much water tight. Her performance was pretty good too and I won yesterdays racing with my lowest ever score of 12 points. I now have just over a month before my next District Event to improve my sailing skills
Old Apr 02, 2012, 04:20 PM
martin richards is online now
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
Does all that sanding seem worthwhile now?
martin richards is online now Find More Posts by martin richards
Old Apr 04, 2012, 05:59 PM
glouis is offline
Find More Posts by glouis
glouis's Avatar
Ireland, Dublin, Howth
Joined Nov 2008
V8
just saw the results of the NZL nats and noticed quite a few new designs, some already tested at the recent Worlds but one in particular is of interest to me as a V6 skipper, saw a v8 there in second place. Was that the latest design from Ian Vickers ? or is it from someone else ?
glouis is offline Find More Posts by glouis
Old Apr 04, 2012, 08:03 PM
ron locke is offline
Find More Posts by ron locke
United States, CA, Pleasanton
V-8
Yes the V-8 is Vickers' latest. He is bringing one here to San Francisco soon. He lives here now.
ron
ron locke is offline Find More Posts by ron locke
Old Apr 04, 2012, 08:10 PM
PB88 is offline
Find More Posts by PB88
Grant L
Auckland NZ
Joined Nov 2010
NZ Nationals V8
Yes this is the second V8 in the water owned by Paul Goddard who sailed a Drumbeat at the last worlds.Ian has commisioned two builders in NZ to build them and production should start by the end of the month.Ian is still waiting for his boat to arrive so you should get a taste of V8 very shortly.Ian proved to be unbeatable in the short time he had to sail in NZ and the design is very slippery with one of our top sailors having a race and commenting that it was the fastest IOM he has ever sailed and believe me he knows what he is talking about.He ordered one straight away along with around twelve others.Other feed back was that it felt like a Marblehead to sail, very well balanced quick out of tacks and extemely fast off the wind.
PB88 is offline Find More Posts by PB88
Old Apr 05, 2012, 02:00 AM
ToniGe23 is offline
Find More Posts by ToniGe23
ToniGe23's Avatar
United Kingdom, London
Joined Jun 2005
V8
Wow, the V8 sounds very promising! is there a link to the NZ nationals.
ToniGe23 is offline Find More Posts by ToniGe23
Old Apr 05, 2012, 08:03 AM
TedFlack is online now
Find More Posts by TedFlack
United States, MI, Bloomfield Hills
Joined Feb 2010
This should work:
http://radioyachtingnz.wordpress.com...ationals-2012/
TedFlack is online now Find More Posts by TedFlack
Old Apr 05, 2012, 11:02 AM
glouis is offline
glouis's Avatar
Joined Nov 2008
thanks for your replies -
very happy with my V6 made by Pepe Vinaixa but wouldn't mind a go at Ian's new V8. biggest problem is the cost for some reason they cost a little fortune here (even worse now with the exchange rate to the Euro) - had to get mine second hand from NZL - it's Alec's old one (Blackmagick sails). Have to say very well built if a little heavy and she loves a little chop as she powers through the waves. I struggle a little in the very light wind but otherwise doing quite well. Didn't go for the V7 as didn't think there was enough difference but would definitly go for a V8 if I can get my hands on one and price dependant or I'll have to wait till they come second hand again
I'm the only one sailing Ian's boat here in Ireland so a bit tricky as I have no one else to tune against but I'm still competitive against the other skippers.
Old Apr 05, 2012, 10:09 PM
CaptainBit is offline
Find More Posts by CaptainBit
Silly Old Fart
CaptainBit's Avatar
New Zealand, Wellington, Masterton
Joined Mar 2006
Here is a picture of the V8
http://picasaweb.google.com/10871316...05937562250658
CaptainBit is offline Find More Posts by CaptainBit
Old Apr 05, 2012, 10:13 PM
Silly Old Fart
CaptainBit's Avatar
Joined Mar 2006
And a close up or two....
https://picasaweb.google.com/1087131...14879653509266
https://picasaweb.google.com/1087131...07943018942466
Old Apr 06, 2012, 01:59 PM
glouis is offline
glouis's Avatar
Joined Nov 2008
argghhhh stop so bloody temping ... pity I don't have the finance for it - granted it needs to built somewhere over here in EU first !!! i take it he won't release the plans so I could make my own vs a royalty fee ???
Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion tend2it Multirotor Talk 2529 Apr 26, 2008 07:45 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 10 Jan 12, 2008 11:33 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 32 Jan 03, 2008 03:02 PM
Discussion General Discussion Inflexo Australia 172 Nov 27, 2006 10:26 PM
General Discussion / Training Area zax Site Chat 0 Oct 03, 2001 01:48 PM
