View Poll Results: If you are reading this thread are you an IOM owner
Yes 26 49.06%
No 27 50.94%
Voters: 53. You may not vote on this poll
Old Mar 05, 2012, 04:27 AM
max67's Avatar
Italy, Abruzzo, Pescara
Joined Jun 2010
Hi all
any of you knows where to find photos
max67 is offline Find More Posts by max67
Old Mar 05, 2012, 06:29 AM
United States, MI, Bloomfield Hills
Joined Feb 2010
edit=double post
TedFlack is offline Find More Posts by TedFlack
Old Mar 06, 2012, 07:22 AM
UK
Joined Sep 2002
Voltage regulators
Looking for clarification of IOM rules.
Is it legal to use a Lipo and a 'voltage regulator' as an Battery in an IOM yacht.
The use of a Lipo battery should be ok under rule 2.4.4
(4) Battery cells assembled in one or more packs.
But as there is no specific mention of a 'voltage regulator' in the 2012 IOM Rules I guess they are not allowed.
2012 rules to be found here:-
http://www.iomclass.org/doc-files/Te...012_250212.pdf
Brian
Brian Wa is offline Find More Posts by Brian Wa
Old Mar 06, 2012, 07:44 AM
waboats's Avatar
HIMI every few years
Joined Jan 2007
Brian
An interesting question that I haven't thought much about. I would tend to suggest that a stand alone regulator would NOT be permitted.
D.2.4 REMOTE CONTROL EQUIPMENT
(a) The following is permitted:
(1) One or more receivers.
(2) One rudder control unit.
(3) One sheet control unit.
(5) Electric cables, connectors and switches.
(6) One device to indicate the battery voltage. In addition, items listed under (1) to (5) may have their own built-in battery voltage indication.
Most IOM's now use an RMG and the like & regulator is usually built into the winch operation .
Personally I would not use a LiPo in a boat.. Too costly if something goes wrong.
LiFe batteries are generally much safer & can plug straight into RX.
waboats is offline Find More Posts by waboats
Old Mar 06, 2012, 07:55 AM
UK
Joined Sep 2002
Originally Posted by waboats View Post
Brian
Sorry if I didn't make it clear in my post, I was referring to the legality of stand alone voltage regulators.
I also us an RMG winch with a built in Regulator.
Brian
Old Mar 06, 2012, 09:02 AM
USA, LA, Mandeville
Joined Feb 2005
So, if I were to zip tie a CCBEC voltage regulator to the side of my Hitech arm winch and dip it in plastic, it would become legal like the RMG?
hew565 is offline Find More Posts by hew565
Old Mar 06, 2012, 09:53 AM
FROM THE MIND OF A MADMAN
gpzy's Avatar
Joined Apr 2007
Doesn't number 6 say a voltage regulator is allowed ?
I use a lipo in my IOM with no voltage regulator fully charged it puts out over 8 volts, after aout 4 hours of sailing it is still putting out between 6 and 7 volts.
gpzy is offline Find More Posts by gpzy
Old Mar 06, 2012, 10:06 AM
UK
Joined Sep 2002
Number 6 says that a 'device to indicate the Battery Voltage' is allowed.
A battery voltage indicator is not a voltage regulator.
Brian
Old Mar 06, 2012, 10:14 AM
Joined Jan 2006
What about diodes in line with the pack? I usually just put two power diodes in my wiring and call it done. Cheaper and easier than a regulator.
slotracer577 is offline Find More Posts by slotracer577
Old Mar 06, 2012, 01:04 PM
Joined Apr 2007
Still not legal, 2.5 (4) only electric cables, connectors and switches allowed. You could argue on the definition of "cables" but if you solder diodes on them you will have a really hard time in convincing a RD that those a re still "cables".
The only way you cold get away with a voltage regulator, the way the rules are written now is if the regulator is build in the "sheet control unit" or the receiver.
The rule will be most likely emended soon to allow voltage regulators as it happen with the 2.4G receiver, the spectrum is composed of two units, and the way the rule was written before (receiver - singular so only one piece of equipment) had all those spectrum radios not IOM class legal.
gio06226 is offline Find More Posts by gio06226
Old Mar 06, 2012, 02:21 PM
micro scale builder
tmtbiker's Avatar
USA, FL, Miami
Joined May 2008
The last few posts ^^^ seem to indicate this is a gray area (at best). However, you could circumvent the whole regulator issue entirely by using some of the new servos that are designed for a 2S 7.4V lipo...I have installed two in my micro magic to eliminate the weight of a regulator, as well as eliminating a potential failure point.
I know Hitec makes a bunch now and Futaba has a few of their own..not sure about the other big names, but they can't be far behind. Admittedly this option doesn't do you much good if you already have servos, but it could be a viable option for a new build or a restoration.
tmtbiker is offline Find More Posts by tmtbiker
Old Mar 06, 2012, 03:28 PM
Nirvana 138, Seawind 178
seabee CE's Avatar
United States, NC
Joined Feb 2012
It's only gray to those that want to run a seperate regulator.
seabee CE is online now Find More Posts by seabee CE
Old Mar 06, 2012, 03:58 PM
Joined Sep 2011
An interesting question about the legality of a battery regulator. Its similar to the question on twin receivers and battery indicators, before the question was raised they were technically illegal but everyone used them and most importantly they are not performance enhancing but ever so helpful so IOMICA rightly changed the rules to allow them as they probably would do with regulators.
I know for certain an awful lot of skippers use a capacitor plugged into the receiver, i used to use one myself when i used a digital servo.
Moved to a £2.99 servo from Ebay now and got rid of the capacitor. I also use £4.99 lipo 1300mah LIPO batteries (60g) that i picked up from Ebay. Charger cost £17 from Ken Binks.
It is all very easy when you have a completely dry boat, just dust after a whole days sailing in West Kirby waves.
Graham J Elliott is offline Find More Posts by Graham J Elliott
Old Mar 06, 2012, 04:29 PM
ToniGe23's Avatar
United Kingdom, London
Joined Jun 2005
Hi Graham,
I watched all the 'A' class racing on both days only managed to get up there once on the Sunday though but never fell out of 'B' fleet so I was happy for an event with such outstanding skippers. I must admit your Grey boat was a struggle for me to see at the far buoys but you have younger eyes than mine
ToniGe23 is offline Find More Posts by ToniGe23
Old Mar 06, 2012, 04:32 PM
ToniGe23's Avatar
Joined Jun 2005
some of the days racing
MYA IOM Ranking Bartley Green Sailing Club 3rd March 2012 (8 min 10 sec)
Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion tend2it Multirotor Talk 2529 Apr 26, 2008 07:45 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 10 Jan 12, 2008 11:33 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 32 Jan 03, 2008 03:02 PM
Discussion General Discussion PLD Australia 172 Nov 27, 2006 10:26 PM
General Discussion / Training Area zax Site Chat 0 Oct 03, 2001 01:48 PM
