View Poll Results: If you are reading this thread are you an IOM owner
Yes 26 49.06%
No 27 50.94%
Voters: 53. You may not vote on this poll
Old Dec 23, 2011, 11:38 AM
FWAL is offline
Find More Posts by FWAL
Flying without a licence
FWAL's Avatar
United Kingdom, Wales, The Mumbles
Joined Dec 2010
Christmas came a little early today when my new rudder servo arrived. It's a Futaba 9650 bought off ebay for under half RRP. It's a great size being smaller than a standard servo yet large enough to have 4.5kg-cm at 6.0V and only weighs 26 grams, it's not that slow either 0.11sec/60deg at 6.0V. It's just a pity the guy controlling it wasn't better
I've also added a couple of progress photo's
Nadolig Llawen
Mark
FWAL is offline Find More Posts by FWAL
Old Dec 24, 2011, 09:14 AM
8387mike is offline
Find More Posts by 8387mike
8387mike's Avatar
Perth Western Australia
Joined Jul 2009
Hello All,
I would just like to wish all a Merry Christmas and a happy and safe New Year.
Regards
8387mike is offline Find More Posts by 8387mike
Old Dec 27, 2011, 02:23 PM
expat flyer is offline
Find More Posts by expat flyer
Toulouse
Joined Jan 2007
FWAL, so much innovation in one boat !
Hope it does not freeze before launch day.
Thanks for the inspiration
Jerry
expat flyer is offline Find More Posts by expat flyer
Old Dec 27, 2011, 04:07 PM
FWAL is offline
FWAL's Avatar
Joined Dec 2010
Finished installing the foredeck fittings and glued the foredeck to the hull today. I also took one last photo of the aft deck internals. You'll notice there is no diagonal bracing from the deck to the foot of the mast case. In this case it isn't required as the mast case and fin box is well supported by the deck construction and the shrouds will terminate in the hull sides where an additional to layers of glass will dispense the loads. You can just see the two small blocks of hardwood where the shrouds will terminate.
In the other photo the aluminium tube will house the jib sheet from the deck bulkhead to the foredeck and the wire twisted around the mast ram locating tube is the underside of No 2 jib sheet fairlead loop
Old Dec 28, 2011, 08:44 AM
FWAL is offline
FWAL's Avatar
Joined Dec 2010
I had been expecting to make a fibre glass mould for the bow bumper. However, after spending most of yesterday afternoon helping to build a Lego Fire Station, Helicopter and Fire Engine I guess it was time to re think!
Lego and Play Dough I hope will do the job
Old Dec 29, 2011, 04:10 AM
FWAL is offline
FWAL's Avatar
Joined Dec 2010
It worked!
The edges will be tidied up once it is fixed to the bow using latex glue
Old Dec 29, 2011, 04:56 AM
8387mike is offline
8387mike's Avatar
Joined Jul 2009
DWAL
All that I use is is good old bathroom silicon, very cheap
Old Dec 29, 2011, 07:24 AM
A.B. is offline
Find More Posts by A.B.
A.B.'s Avatar
Calgary Alberta, Canada
Joined Feb 2008
I have tried bathroom silicone and it never wants to dry in the middle? I have let it sit for days?
A.B. is offline Find More Posts by A.B.
Old Dec 29, 2011, 07:34 AM
8387mike is offline
8387mike's Avatar
Joined Jul 2009
Hi AB,
Sorry I meant for glueing the bumper to the hull.
FWAL,
What did you use for the bumper?
Old Dec 29, 2011, 08:15 AM
FWAL is offline
FWAL's Avatar
Joined Dec 2010
Hi Mike
I have used fairly cheap white silicone and it is a little soft in the middle but I don't think it will affect performance, not enough that I would notice. I wasn't sure what else was readily available.
I'm only using latex because it's in my garage and cures hard enough to sand making a nice flush joint between bumper and bow which at present don't marry up as flush as I would really like! Perhaps due in part to rushing the balsa plug. Latex is also extreme sticky, flexible stuff but don't ask me or the missus how I know
Old Dec 29, 2011, 12:03 PM
Guz is offline
Guz
Find More Posts by Guz
Guz
Gutless wonder
Guz's Avatar
Tempe, AZ
Joined Dec 2005
Poke it with a damp toothpick (on the backside) to the soft part. Keep doing it till it gets firm. Takes a day or two to firm up this way.
As for mounting... More silicone. Just a thin film on the bow, then push the bumper on, and secure it tape till it dries. Don't deform the bumper with the tape, just enough pressure to hold it in place.
P.S.
I like the Play Dough idea. I used plaster and Vaseline when I made mine. I wonder if I could use molding clay instead (would silicone stick to it)?
Guz is offline Find More Posts by Guz
Old Dec 29, 2011, 02:07 PM
FWAL is offline
FWAL's Avatar
Joined Dec 2010
Thanks for the valuable advice regarding the cocktail stick Guz
As for the moulding I spread a generous layer of polishing wax over the varnished balsa plug before pressing it into the play dough, this might also work for moulding clay or just wait for the clay to harden then rub either wax, vasaline or pva in the mould.
Old Dec 29, 2011, 08:11 PM
ToniGe23 is offline
Find More Posts by ToniGe23
ToniGe23's Avatar
United Kingdom, London
Joined Jun 2005
Australian Nationals 2012
anybody on here entered the Australian Nationals 2012 the venue looks fantastic
http://2012nationals.radiosailing.org.au/1/
ToniGe23 is offline Find More Posts by ToniGe23
Old Dec 31, 2011, 02:32 AM
martin richards is online now
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
Another idea: http://sugru.com/about#main_properties
martin richards is online now Find More Posts by martin richards
Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion tend2it Multirotor Talk 2529 Apr 26, 2008 08:45 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 10 Jan 13, 2008 12:33 AM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 32 Jan 03, 2008 04:02 PM
Discussion General Discussion PLD Australia 172 Nov 27, 2006 11:26 PM
General Discussion / Training Area zax Site Chat 0 Oct 03, 2001 02:48 PM
