View Poll Results: If you are reading this thread are you an IOM owner
Yes 26 49.06%
No 27 50.94%
Voters: 53. You may not vote on this poll
Old Oct 12, 2011, 10:37 AM
Ted Flack is offline
Find More Posts by Ted Flack
USA-Michigan
Joined Feb 2008
Hey Hew and Al,
Where are you guys staying at the Nationals. I am thinking the Best Western just down the road from the pond. Bar and restaurant on site.
Ted
Ted Flack is offline Find More Posts by Ted Flack
Old Oct 12, 2011, 11:13 AM
aralross is offline
Find More Posts by aralross
Mandeville, La.
Joined Mar 2007
Haven't made plans yet, but that might be the place.
I will get back with you as soon as we decide.
aralross is offline Find More Posts by aralross
Old Oct 13, 2011, 03:34 AM
Craig Richards is offline
Find More Posts by Craig Richards
Cape Town South Africa
Joined Jan 2010
I dont think pigmented resins are allowed yet throughout the boat, but this is just the external coat instead of paint. The laminated layers of cloth are all with clear epoxy.
I tried to make an epoxy gelcoat by adding some red pigment and a thickening agent, but its almost impossible to get it opaque enough. If you look in the picture, you will see the boat is fairly transparent.
In trying to get enough pigmented resin into the mould to make it opaque, I ended up with a fairly thick layer and a boat 70 grams underweight. The painted boat is 280g underweight by comparison.
The extra 200g of epoxy coating have definitely made the boat a bit thicker and noticeably stiffer, even though they have the same layup (80g, 165g,165g)
Craig Richards is offline Find More Posts by Craig Richards
Old Oct 13, 2011, 07:34 AM
Brian Wa is offline
Find More Posts by Brian Wa
UK
Joined Sep 2002
Originally Posted by Craig Richards View Post
I dont think pigmented resins are allowed yet throughout the boat, but this is just the external coat instead of paint. )
Pigmented resins are allowed - see Rulee D 2.1(B)
"(b) In glass fibre reinforced plastic:
(1) an external gel coat is optional and may be pigmented,"
Found in the latest IOM rules:-
http://www.iomclass.org/class-rules/
or
http://www.iomclass.org/doc-files/Te...011_020211.pdf
Brian
Brian Wa is offline Find More Posts by Brian Wa
Old Oct 13, 2011, 10:22 AM
hew565 is offline
Find More Posts by hew565
USA, LA, Mandeville
Joined Feb 2005
To clarify, Yes, pigmented resins are allowed in the outer layer, or "gelcoat", but not in the fiberglass layup.
The reason it was brought up is that there is currently a request for rule change to allow pigmented resins throughout the layup. Read it here: http://www.iomclass.org/doc-files/Te...20proposal.pdf
hew565 is offline Find More Posts by hew565
Old Oct 15, 2011, 09:40 AM
flatlandsailor is offline
Find More Posts by flatlandsailor
flatlandsailor's Avatar
United States, KS, Wichita
Joined Feb 2008
Hi Guys. Any thoughts on good paint for an IOM? I have an older boat that could use some more paint.
Thanks!
flatlandsailor is offline Find More Posts by flatlandsailor
Old Oct 15, 2011, 12:32 PM
hew565 is offline
USA, LA, Mandeville
Joined Feb 2005
I'm partial to automotive, 2 part clear over the top of a base coat of color (basecoat-clearcoat systems). They are more expensive because the smallest they sell is a quart. They typically have a good UV inhibitor in the clear to help prevent fading.
You can even use waterbased AutoAir type colors that DO come in small containers, then shoot the clear over it. The clear can be wetsanded and polished nicely.
I would sand off as much of the old paint as you can. No need for any extra weight there!
Old Oct 15, 2011, 05:35 PM
Joined Feb 2008
Hew,
Any particular brand name for the bigger stuff that you recommend?
It has white gel coat I believe, but it needs some tlc.
Andy
Old Oct 17, 2011, 12:37 AM
Rssailor is offline
Find More Posts by Rssailor
United States, CA, Alameda
Joined Nov 2010
Pikanto Tuning
I acquired a Pikanto built in Australia by peter morris. So far have not been able to acquire any rake numbers that work. Craig Smith was kind enough to send me some info with rake, but that was not it for this boat. If anyone out there has any A or B rig rake info for this boat or other tuning tips that would help me get this boat up to speed. The boat has a round 11.1 MM mast. Ryan
Rssailor is offline Find More Posts by Rssailor
Old Oct 17, 2011, 02:32 AM
ToniGe23 is offline
Find More Posts by ToniGe23
ToniGe23's Avatar
United Kingdom, London
Joined Jun 2005
Hi Ryan,
I may be able to help I own a Pikanto built by Zvonko Jelecic can you get a closer picture of the mast ram area to see mast position please I'll get some pictures on here later of my mast position marks.
ToniGe23 is offline Find More Posts by ToniGe23
Old Oct 17, 2011, 09:46 AM
The Tug is online now
Find More Posts by The Tug
Barbados
Joined Jan 2011
Give him a measurement from the middle mast band to the stern,rig in the boat and backstay on.
The Tug is online now Find More Posts by The Tug
Old Oct 17, 2011, 12:39 PM
hew565 is offline
USA, LA, Mandeville
Joined Feb 2005
Flatlandsailor, The last couple of boats I have done with Transtar 6864 High Gloss clear, with the hardener added. This was over a Transtar color basecoat on one boat, and over Autoair, waterbased color on my "mermaid" boat.
Call around to auto parts shops to see if any carry Transtar paints. This is actually an inexpensive line of auto paints. There are better, more expensive lines too, but for our purposes, should be good.
Old Oct 20, 2011, 09:10 AM
A.B. is offline
Find More Posts by A.B.
A.B.'s Avatar
Calgary Alberta, Canada
Joined Feb 2008
Could someone tell me what size the sail numbers need to be? I for some reason cannot find that in the rules?
A.B. is offline Find More Posts by A.B.
Old Oct 20, 2011, 09:33 AM
USA-Michigan
Joined Feb 2008
ISAF Rules Appendix E
Old Oct 20, 2011, 09:51 AM
Brian Wa is offline
UK
Joined Sep 2002
Try Here:
http://www.3rryc.org.uk/resources/MY...gram_Oct09.pdf
Brian
Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion tend2it Multirotor Talk 2529 Apr 26, 2008 07:45 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 10 Jan 12, 2008 11:33 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 32 Jan 03, 2008 03:02 PM
Discussion General Discussion Inflexo Australia 172 Nov 27, 2006 10:26 PM
General Discussion / Training Area zax Site Chat 0 Oct 03, 2001 01:48 PM
