View Poll Results: If you are reading this thread are you an IOM owner
Yes 26 49.06%
No 27 50.94%
Voters: 53. You may not vote on this poll
Old Apr 02, 2011, 03:27 AM
ToniGe23 is offline
Find More Posts by ToniGe23
ToniGe23's Avatar
United Kingdom, London
Joined Jun 2005
Yep, no carbon masts or booms for IOM's
ToniGe23 is offline Find More Posts by ToniGe23
Old Apr 03, 2011, 12:18 PM
Ted Flack is offline
Find More Posts by Ted Flack
USA-Michigan
Joined Feb 2008
Does anyone know what design boat Peter Stollery used at the Ranking event yesterday?
Ted Flack is offline Find More Posts by Ted Flack
Old Apr 03, 2011, 01:59 PM
ToniGe23 is offline
ToniGe23's Avatar
Joined Jun 2005
Hi Ted,
Ist day of the IOM rankings I see Brad done it again I know most of the boats that were sailed but not sure about Peter's.
Old Apr 04, 2011, 08:03 AM
mainboom is offline
Find More Posts by mainboom
mainboom's Avatar
Italia, Abruzzo, Pescara
Joined Apr 2011
GBR Ranking
Stollery has used a model called Britpop, building Brad Gibson
for more information : http://mainboom.blogspot.com/
cheers, massimo
mainboom is offline Find More Posts by mainboom
Old Apr 04, 2011, 08:16 AM
USA-Michigan
Joined Feb 2008
Thanks.
That's what I thought when I saw the pictures. That is the Brad's new design that he has been using since last summer. He came here to the USA and won nearly every race at our Nationals.
From BG Sails & Design News:
"Our Britpop lines and prototype plug is now in the hands of its UK builder for full tooling and machining work to be done with production to follow as soon as ready."
Old Apr 04, 2011, 05:38 PM
jims123 is offline
Find More Posts by jims123
jims123's Avatar
USA, CA, San Diego 92120
Joined Oct 2007
Question came up today..
I hit a marker buoy we tossed out to use as the starting line marker, but was on a downwind run, and I did a 360 penalty turn .. but my competitors both said itís not required unless you are starting , and after that, that mark is just an obstruction .. BUT that doesn't seem right to me.. Iím not so sure, tried to find it in the racing rules but they are hard to interpret. .. seems like any time you hit a mark there should be a penalty shouldnít there.. And I am assuming one of you IOM guruís would know for sure.. Thanks In advance..
JimS
jims123 is offline Find More Posts by jims123
Old Apr 04, 2011, 05:49 PM
USA-Michigan
Joined Feb 2008
If you hit a mark before the start you need to do a turn.
31 TOUCHING A MARK
While racing, a boat shall not touch a starting mark before starting, a mark that begins, bounds or ends the leg of the course on which she is sailing, or a finishing mark after finishing.
Old Apr 04, 2011, 05:56 PM
jims123 is offline
jims123's Avatar
Joined Oct 2007
ahhh Ok, so does that mean (since as mentioned, we we not starting)
that since it's not clearly mentioned (below) you can hit a mark that is not part of the course (after the start) and if you do it's Ok to skip the peanalty turn.. Or not? sorry to be so dense here but it's not at all clear to me yet..and i have a bet on the outcome..
I'll take a look at rule 31 tho and perhaps I can sort it out.
Regards, JimS.
31 TOUCHING A MARK
Old Apr 04, 2011, 06:28 PM
USA-Michigan
Joined Feb 2008
Had the starting sequence started yet. If the sequence has started than you need to be sailing by the rules.
It may be under one minute in a two minute sequence, or 30 seconds in a one minute countdown before the rules all apply. I am not sure about that. I just assume it is after the sequence starts and that way I know I am safe.
Old Apr 04, 2011, 06:33 PM
jims123 is offline
jims123's Avatar
Joined Oct 2007
Ted,
I guess stating we were all on a downwind run, and that we were not starting is not clear enough.. we had all rounded the windward mark, and were heading to the downwind mark.. this was all WELL AFTER the start..
Old Apr 04, 2011, 06:37 PM
ToniGe23 is offline
ToniGe23's Avatar
Joined Jun 2005
Originally Posted by jims123 View Post
I hit a marker buoy we tossed out to use as the starting line marker, but was on a downwind run, and I did a 360 penalty turn .. but my competitors both said it’s not required unless you are starting , and after that, that mark is just an obstruction .. BUT that doesn't seem right to me.. I’m not so sure, tried to find it in the racing rules but they are hard to interpret. .. seems like any time you hit a mark there should be a penalty shouldn’t there.. And I am assuming one of you IOM guru’s would know for sure.. Thanks In advance..
JimS
If the buoy was there for marking the start line only and nothing else then if you hit it after the race has begun you do not have to do a turn, your friends were correct.
Old Apr 04, 2011, 06:48 PM
USA-Michigan
Joined Feb 2008
Deleted
Old Apr 04, 2011, 08:18 PM
CaptainBit is offline
Find More Posts by CaptainBit
Silly Old Fart
CaptainBit's Avatar
New Zealand, Wellington, Masterton
Joined Mar 2006
You did not have to do a penalty because the mark you hit was not a mark of the course at the time you hit it.
CaptainBit is offline Find More Posts by CaptainBit
Old Apr 04, 2011, 08:32 PM
USA-Michigan
Joined Feb 2008
What he said!!
Old Apr 04, 2011, 09:00 PM
jims123 is offline
jims123's Avatar
Joined Oct 2007
Hey, all that helped me sort this out thanks a lot..!
I am going to assume that Rule 31 which Ted copied verbatim.. implies this indirectly because if it's not stated specifically.. I'm just used to taking the penalty as i hit a mark..
Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion tend2it Multirotor Talk 2529 Apr 26, 2008 07:45 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 10 Jan 12, 2008 11:33 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 32 Jan 03, 2008 03:02 PM
Discussion General Discussion Inflexo Australia 172 Nov 27, 2006 10:26 PM
General Discussion / Training Area zax Site Chat 0 Oct 03, 2001 01:48 PM
