Old May 06, 2003, 01:51 PM
aaronredbaron is offline
Find More Posts by aaronredbaron
Spektrum Dev Team
aaronredbaron's Avatar
United States, IL, Champaign
Joined Apr 2002
trying to find CG for burt rutan quickie
it is sort of a canard/sort of a stagger wing bipe. I am hating myself right now for dropping out of aerospace engineering, AND selling my best AE book. what is the formula that relates the center of lift for both wings and then takes into acount the overall lift force since the area's are different? can I then simply average the distance??? any idea's?
aaronredbaron is offline Find More Posts by aaronredbaron
Old May 06, 2003, 09:38 PM
DanSavage is offline
Find More Posts by DanSavage
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Re: trying to find CG for burt rutan quickie
I know what a Rutan Quickie is. My brother Daren is building a 1/4-scale model. This should help.
However, since the canard on a quickie is actually below the wing, I'm not sure whether the wing flys through the canard's downwash.
Are you building it from scratch or from a kit?
Dan
DanSavage is offline Find More Posts by DanSavage
Old May 07, 2003, 03:42 PM
Spektrum Dev Team
Joined Apr 2002
my model is 1/4 scale and is already built
it currently is powered by a OS 40 FP w/ perry pump because the fuel tank is at the CG (I think) depending how well it flies I may do a brushless conversion. since your brother is building a 1/4 scale one too maybe you could measure the CG from a constant point (trailing edge of front wing/canard, or from the firewall or whatever) also if you could give me a constant length to go from (wingspan, fuse length.. anything) I should be able to account for any variences in size. from what I have heard the CG range should be pretty wide, so as long as I get it close and maybe a little nose heavy I should be OK
Old May 07, 2003, 03:49 PM
Spektrum Dev Team
Joined Apr 2002
about the ineffectiveness of the wing....
I can't see how the image can apply to the quickie, because the front wingspane is nearly the same as the rear it would render to rear wing nearly useless. if you look at the plane from the front it has anahedral (speelled wrong) in the fron and it is at the bottom of the fuse, then the fuse extends upward and the rear wing is at the top of the fuse with dihedral. looking at it, for me, suggests that the reason the plane was designed the way it was, was to eliminate any airflow from the canard interfering with the airflow over the rear wings. I need to get a digital camera.....
Old May 08, 2003, 07:09 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Re: about the ineffectiveness of the wing....
I think you've got it wrong.
Find the canard area (A)
Find the wing area (B)
Find the Neutral Point for the main wing. (NPW)
Calculate the CG for the canard and the main wing at 1/4 chord (25% MAC)
Find the longitudinal separation distance between the two.
Multiply A times longitudinal separation.
Divide A + B by the result.
This gives the distance from the CG of the main wing to the neutral point. (NP)
Next, add the distance between the NPW of the main wing to its CG at 25% MAC to the result of the calculations above to find the starting CG of the model.
The configuration of the Quickie you describe is why I wrote what I did about the wing not flying through the canard's downwash. For the purposes of calculation, I could simply leave the rear wing effective area at 100%.
Dan
Old May 09, 2003, 12:50 AM
Spektrum Dev Team
Joined Apr 2002
thank you for your help
sorry about the confusion... there is only one way at this point to see if it is right!
Old May 09, 2003, 04:48 AM
Ollie is offline
Find More Posts by Ollie
Punta Gorda, FL
Joined Apr 2002
The downwash behind a wing extends several chord lengths above and below the wing. That's why some wind tunnels can measure the coefficient of lift by an array of manometers placed in the roof of the windtunnel. That's why biplanes are inherently less efficient than monoplanes and why the greater the gap between the top and bottom wing, the less the wings' efficiency is degraded.
The air flow over the aft wing is slowed by the influence of the forewing and fuselage. In calculating the neutral point, an allowance has to be made for the reduced effectiveness of the aft wing. This is usually done by using a smaller area of the aft wing in the neutral point calculation. It is very hard to accurately estimate the actual reduced effectiveness of the aft wing. To cover this uncertainty, it is best to start out with a static margin of 15 or 20%. That is with the CG 15 or 20% of the wing's mean aerodynamic chord ahead of the neutral point in a tandem wing design.
For a fuller discussion of tandem wing setup see R/C MODEL AIRPLANE DESIGN, Chapter 10 by A.G. (Andy) Lennon. The rules of thumb in Lennon's book have been verified experimentally and would apply well to the Quickie configuration.
Ollie is offline Find More Posts by Ollie
Old May 09, 2003, 06:41 AM
Trizza is offline
Find More Posts by Trizza
Grand Poobah of Nothing
Trizza's Avatar
Once Australia, now Finland
Joined Feb 2001
You could always build a small balsa model to figure the CG out with. Just to glide test in your living room or something.
Trizza is offline Find More Posts by Trizza
Old May 11, 2003, 11:38 PM
Spektrum Dev Team
Joined Apr 2002
I got ahold of the original plans and instructions!!
I feel very confident having the right info. they claim it is a very good flying plane and flies pretty fast...we'll see
Old Jun 02, 2003, 06:26 PM
aeropenguin is offline
Find More Posts by aeropenguin
Who Says Penguins Can't Fly?
aeropenguin's Avatar
Bay Area, California
Joined Jan 2003
Hello guys!
I am very intersted in your Quickie, and I am in the proccess of designing a much, much smaller scale model of the quickie, and needed a few good pics or 3 view diagrams - well, the more views the better.
Do you still have those plans of the full scale Rutan Quickie? Do you know where I could get them or find pics? Or even less acurate drawings with just outlines? Can you scan in your plans?
If not, do you have any directly side view photos or directly top view (as for top, I see a good one on the link you gave in the first post, but it is small and a little hard to understand how/where everything goes/fits) or front or back?
Thank you very much!
-Michael
aeropenguin is offline Find More Posts by aeropenguin
Old Jun 18, 2003, 01:51 AM
daisycutter is offline
Find More Posts by daisycutter
36 Russky jets
daisycutter's Avatar
malaysia
Joined Nov 2002
does anyone have a pic?
daisycutter is offline Find More Posts by daisycutter
Old Jun 18, 2003, 01:24 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Did a search on the 'net for "quickie".... !!!!! Amazing things you can find!!!! :
Got results with "quickie & Rutan"...
dimensions -can- be read with a little enlargement..
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jun 18, 2003, 01:25 PM
Joined Jan 2003
guys, looks like somebody did ALL the math for ya......
and drew in formers, bulkwalls, fuse sides...an entire plan.
NO, two entire plans!!!!!!
http://www.rcgroups.com/forums/showt...hlight=quickie
http://victorian.fortunecity.com/stoker/123/
Old Jun 18, 2003, 01:27 PM
Joined Jan 2003
click on planos, then scroll down until you see "Quickie" under the canard section, then scroll down more until you see "Qac-Quickie" they are the two plans, both scale. The Qac-Quickie is harder to build from and much less complete, but it is far more scale. Elevator goes in front wing, aileron goes in the back wing, for three chnnels. For four, add the rudder..... rudder and elevator doesn't work...
-aeroP
P.S. SPARKY, that's noit the Rutan Quickie, I'm sorry to say. That's a dragonfly or something. The way you can tell is that the Q has straight fuselage sides, looking from a top view.
Old Jun 18, 2003, 02:42 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
magnify the title block.
WTB: St. Croix Burt Rutan Quickie Matt Chester Aircraft - Electric - Airplanes (FS/W) 1 Sep 05, 2013 12:54 PM
Burt Rutan Quickie FFF Matt Chester Foamies (Kits) 10 Jul 02, 2004 01:12 AM
WTB: St. Croix Burt Rutan Quickie Matt Chester Aircraft - Fuel - Airplanes (FS/W) 0 Apr 19, 2004 12:19 PM
Trying To Find A Camera For My Plane dog1barking Aircraft - Electric - Airplanes (FS/W) 4 Mar 30, 2003 05:16 PM
I need to find the CG for a swept wing D.FLinn Power Systems 6 Apr 19, 2002 02:10 PM
