Jan 24, 2010, 08:58 PM
gilbert,az
Joined Dec 2005
Did some taxi testing today, both wheels locked up on the axles. I don't know why, but I greased them both and they seem fine now. Very weird, the wheel is held on by a lock nut rather then a wheel collar which is fine. There is a spacer on the strut side. Very simple, one locked up so bad I almost couldn't get it off. There was a bur on the axle, from what I dont know. I took the wheel apart, and only one side of the hub has the axle insert. I sanded the axle a little and greased them and added a washer and they are fine now. Tonight I may try to shim the retracts, they are 90 degree retracts, so the struts point outwards to much for a mustang. I may be able to use a couple of washers to shim them and still be able to get the gear to lock in the wheel liners when retracted. I think a mustang needs 85 degrees. Was hoping to get my spinner tonight, not gonna happen probably Wed.
