Old Sep 20, 2010, 06:11 AM
MYC is offline
MYC
Find More Posts by MYC
MYC
Inconceivable!
MYC's Avatar
USA, NY, Smithtown
Joined Jan 2005
I'm sorry to hear you are having CG problems Kahloq. You did measure that 5" from the LE where it meets inside the fuse, right? I measured mine back from where the pins are down the centerline where the wing halves meet and then used a speed square to translate the balance lines left and right from there. Balanced upside down, mine is quite manageable at this location. I flew mine several times at NEAT this past weekend without issue.
MYC is offline Find More Posts by MYC
Old Sep 21, 2010, 07:43 AM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
Yes I measured it against the fuse/wing....same place ur describing.
All of my other ESM planes in this size range use a CG of 110-120mm(2x me-109, fw-190) so having 5"(127mm) for this P-51 didnt seem right to begin with, but went with it because someone said that 5 1/4" worked ok.
Im glad I didnt initially put it at 5 1/4" because I probably wouldnt have a plane now.
Im not dissing anyone at all...but...my opinion is that 5 1/4" is not a recipe for success unless you've got really nimble fingers and dont move the stick but miniscule amounts.
At 5", the plane was managable in the air yet very pitch sensitive, but the powered decent to landing is quite hairy to say the least....considerable amount of porpoising.
I had 60% expo on all surfaces and that was not enough to tame the sensitivity.
As a note...ive been flying warbirds for years and ive got several P-51's.
For ME....that 5" to 5 1/4" is not at all comfortable. But...others may be fine with it. As a note...my larger 80" hangar 9 P-51 has a Cg of 5 1/4"
Ive since added 2 1/4 oz more lead as far forward as I could affix it and thats given me a CG of 121mm or 4 3/4" measured directly down the centerline of the wing.
kahloq is offline Find More Posts by kahloq
Old Sep 21, 2010, 08:11 AM
MYC is offline
MYC
MYC
Inconceivable!
MYC's Avatar
USA, NY, Smithtown
Joined Jan 2005
I'm with you Kahloq. If you are comfortable at 4 3/4 than that is where you should fly it. I'm sure it will fly fine there. That extra 1/4" forward should add some more stability to mine too. I don't have any expo on my elevator and at half (my half ) flaps mine almost descends hands off. That said, I'm gonna move my cg forward a bit too and see if I like your position better. There are several pix from my flights this past weekend at the NEAT fair here on RCGroups and although I don't know where in my routine I was at when they were taken, the tail does seem a bit low... like in the pic below... nose is high but ele is down.
In this thread are some other pix of her from the fair
http://www.rcgroups.com/forums/showt...1309684&page=4
Old Sep 21, 2010, 10:10 AM
mpope1 is offline
Find More Posts by mpope1
mpope1's Avatar
gilbert,az
Joined Dec 2005
Pix look great, how far is the neat fair from the island?
mpope1 is offline Find More Posts by mpope1
Old Sep 21, 2010, 10:55 AM
MYC is offline
MYC
MYC
Inconceivable!
MYC's Avatar
USA, NY, Smithtown
Joined Jan 2005
its about 3.5hrs northwest... more pulling the 20+ planes and 12' trailer!
Old Sep 22, 2010, 11:05 PM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Mark,
Loved your 'stang! Here's yet another photo of it from NEAT.....
Peter M is offline Find More Posts by Peter M
Old Sep 25, 2010, 06:19 AM
MYC is offline
MYC
MYC
Inconceivable!
MYC's Avatar
USA, NY, Smithtown
Joined Jan 2005
Nice pic Pete. It was great to meet you.
Old Sep 25, 2010, 02:37 PM
datazman is offline
Find More Posts by datazman
Just Plane Crazy
datazman's Avatar
United States, NY, McGraw
Joined Apr 2004
Mark:
Here are the 3 I posted in the NEAT Fair photo thread.
By the way, thank you for the Name Tag but Tom asked that I not use it if I wanted a Press Pass. Guess which won out. I would have worn it with pride.
Peter M:
You are holding out I see. You should post some of your photos in the NEAT Fair photo thread.
TA Ta for now.
Paul
datazman is offline Find More Posts by datazman
Old Sep 25, 2010, 03:21 PM
MYC is offline
MYC
MYC
Inconceivable!
MYC's Avatar
USA, NY, Smithtown
Joined Jan 2005
first pic is now my desktop background Paul! Thank you very much. You are one heck of a photographer my friend
Old Sep 30, 2010, 02:00 PM
mpope1 is offline
mpope1's Avatar
gilbert,az
Joined Dec 2005
Got a flight in today, sorted out the cg. Had to move one of my flight packs slightly foward to compensate for the extra tailweight for the tail retract. Still can't figure out how to slave aux 2 to my retract channel. When I set up a mix it doesn't work? No big deal, just have to remember to hit 2 switches. Thinking about adding the same mod to my 1.50 p-47, would be real easy!
Old Oct 02, 2010, 09:55 PM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
mpope1
It was cool to see your mustang fly today down at Speedworld. That take off had me worried, But you did a nice job saving it. Looks like it has plenty of power. Well done! TW
TripleW is offline Find More Posts by TripleW
Old Oct 02, 2010, 10:19 PM
mpope1 is offline
mpope1's Avatar
gilbert,az
Joined Dec 2005
Yeah, take off was a little bit of a surprise. I just took the tires off and added a washer to get them off the struts a little. The plane is so heavy that I think the axles may be bending slightly. Gonna keep my eye on it!
Old Oct 18, 2010, 12:44 AM
shafs64 is offline
Find More Posts by shafs64
Australia, VIC, Wyndham Vale
Joined Sep 2010
I am ready to install or set up my lipos i was going to go with the 2x25c 5000 22.2v zippys. but the weight could be and issue. i did notice that mpope1 is running a 4 cell and 6 cell together. if i do this do they have to be the same voltage?
Paul
shafs64 is offline Find More Posts by shafs64
Old Oct 18, 2010, 06:46 AM
MYC is offline
MYC
MYC
Inconceivable!
MYC's Avatar
USA, NY, Smithtown
Joined Jan 2005
No Paul. MaH needs to be the same. A 6s 5000 and a 4s 5000 consist of the same cells there are just 6 of them in one and four in the other so when you wire them in SERIAL you get 10s 5000. DO NOT wire them in PARALELL as that will be really bad for the 4s pack and push it rather quickly over its max voltage.
Old Oct 18, 2010, 08:44 AM
shafs64 is offline
Joined Sep 2010
Ok thanks mate now i know what to do. one other thing i need to ask for my speed controller i am useing the turnigy programing box and its asking how many pole is my motor. i have not idea what this means.
this is my motor http://www.hobbycity.com/hobbycity/s...idProduct=3890
Build Log Top Flite Gold Edition P-51D KIT Conversion to P-51B denial15 Glow to Electric Conversions 70 Feb 05, 2010 01:46 AM
H.O.B P-51D Mustang 1/2A conversion. genovia Scale Kit/Scratch Built 42 Dec 07, 2002 11:22 PM
Flying Styro P-51D Mustang r/c conversion,anyone successful? bipeflyer Parkflyers 20 Jul 29, 2001 01:54 AM
Flying Styro P-51D Mustang r/c conversion,anyone successful? bipeflyer Foamies (Kits) 2 May 17, 2001 09:48 AM
Flying Styro P-51D Mustang r/c conversion,anyone successful? bipeflyer Scale Kit/Scratch Built 0 May 16, 2001 03:35 PM
