Old Dec 08, 2009, 09:10 PM
mpope1 is offline
Find More Posts by mpope1
mpope1's Avatar
gilbert,az
Joined Dec 2005
Esm P-51D conversion
Well I have been waiting patiently for this to become available http://www.troybuiltmodels.com/items/ESMP51D-71-F.html. Have the plane and retracts on the way, hopefully start the build thread in the next few weeks. Not sure of the power plant yet, probably a hacker a60 outrunner, I am leaning towards the A60-20M on 9-10s. Not sure yet until I get the plane in my hands to see on weight and cowl clearence. I have also been waiting for xoar props to unounce when their 4 bladed props are do out, I have e-mailed them for some info. I really like the paint scheme, other then the 4 bladed prop I would like to fit it with a retractable tailwheel. Other then that it seems it should be a stright foward build. I will post some pix when I get the plane, the retracts are scheduled to arrive the end of this week, plane early next week..
mpope1 is offline Find More Posts by mpope1
Old Dec 11, 2009, 05:35 PM
mpope1 is offline
mpope1's Avatar
gilbert,az
Joined Dec 2005
Got my retracts set today, wow what a great deal. Everything included, struts look solid and retracts too. The wheels are beautiful, little heavy but at least they will be a scale size to the airframe. Plane is due on Monday, hope to get started on the wings next week sometime! Compared the retract unit to my robarts, alot more slop in the robarts..
Old Dec 11, 2009, 06:18 PM
flmlm is offline
Find More Posts by flmlm
flmlm's Avatar
Holly Hill, Fl.
Joined Mar 2005
Great looking P 51. I'm sure you'll have a great time with it.
Regards
flmlm is offline Find More Posts by flmlm
Old Dec 11, 2009, 09:02 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
sweeeeet mike!!!! im geleous!!!!! i want the esm corsair of course....but the 51 would be my second choice...
corsair nut is offline Find More Posts by corsair nut
Old Dec 11, 2009, 09:05 PM
mpope1 is offline
mpope1's Avatar
gilbert,az
Joined Dec 2005
Almost got the bearcat, I sold my H9 miss america cause I really wanted a military mustang. These retracts and struts are nice and the wheels are unbelievable!!
Old Dec 13, 2009, 03:06 PM
mpope1 is offline
mpope1's Avatar
gilbert,az
Joined Dec 2005
Been doing some research on the zinger 4 bladed prop hub system, does anyone no if they are available, and where to purchase them?
Old Dec 13, 2009, 04:02 PM
datazman is offline
Find More Posts by datazman
Just Plane Crazy
datazman's Avatar
United States, NY, McGraw
Joined Apr 2004
Mike:
I am sure your build thread will be great! I am looking forward to it.
Are you going to go with the D model or the B model?
From my experience, and from talking with Tom Hunt – if you go with a 4 blade prop, the only thing you should change is the ‘disk’ size and leave the pitch the same as a 2 blade prop. For instance if you would originally go with a 18 X 10 - 2 blade prop than your equivalent 4 blade would be a 17 X 10. Just my 2 cents.
Looking forward to your thread.
Ta Ta for now.
Paul
datazman is offline Find More Posts by datazman
Old Dec 13, 2009, 04:19 PM
Tommy D is offline
Find More Posts by Tommy D
Hooper, full throttle!
Tommy D's Avatar
USA, NY, East Islip
Joined Feb 2004
Originally Posted by datazman View Post
Mike:
Ta Ta for now.
Paul
More then a mouthful..... Prop Info here
Tommy D
Tommy D is offline Find More Posts by Tommy D
Old Dec 13, 2009, 04:29 PM
tehachapi, CA
Joined Jan 2006
very cool info tommy!
Old Dec 13, 2009, 05:10 PM
mpope1 is offline
mpope1's Avatar
gilbert,az
Joined Dec 2005
Very Good info, I want to have a prop that would be scale for the size of the plane. I was flying the hangar 9 60 sized mustang with a 15.5 x 12 4 blader and it was a little small in comparison to the size of the plane. One thing that is nice with electrics is that we can switch motor kv to taylor the size prop that we would want to spin. Since I dont have the plane yet, I am guessing around an 18" diameter should be close to scale for this size p-51(D model). Another factor is cell count, for a more realistic flight envelope 7s was a good match(Hacker A50-14L) but for all out speed 8s was real nice. It was the miss america version so I mostly flew on 8s except in the summer mos. to keep the motor/esc a little cooler. I actually have a 3 bladed tru-turn, and may start out with a 15 3/4 x 13 3 bladed apc just to get things dialed in and trimmed until I can figure out the 4 blade issue. I dont think the zingers are available, on towers website it says stock pending, was also waiting on xoar. The only other alternative are the solo prop systems but they are extremely expensive!
Old Dec 14, 2009, 10:28 PM
mpope1 is offline
mpope1's Avatar
gilbert,az
Joined Dec 2005
Received the plane today. Real nice quality, built like a tank. The wood is very strong, even the sheeting. Fiberglass is excellent, for a 71" w.s it seems pretty large, more scale then the hangar 9. I measured the cowl, it will need a 4 1/2" spinner(ouch!) I installed one retract, just about dropped right in with some minor dremeling. I will probably screw down the wheel well liners instead of glueing them. I want to make them easily removable incase I ever want to swap out the retracts. Gear doors will be screwed into a supplied block that mounts over the strut. I had to shim the lower one to make sure the wheel doesnt rub against it. Try to post more pix this weekend!
Old Dec 15, 2009, 02:27 AM
drksyd is offline
Find More Posts by drksyd
MultipleCrashSurvivor
drksyd's Avatar
USA, HI, Honolulu
Joined Jan 2003
Nice Mike. I've been looking at the KMP kits and now the ESM's as they are much better priced for the same thing.
drksyd is offline Find More Posts by drksyd
Old Dec 15, 2009, 07:56 AM
mpope1 is offline
mpope1's Avatar
gilbert,az
Joined Dec 2005
I always used to go to kmps website and drool over the planes also, now they are more affordable and electric tech. has come along way so weight isnt as much of a problem anymore. I sold my H9 mustang and p-40, both were real old, to do this project! I heard that esm is gonna come out with a p-40 next year
Old Dec 15, 2009, 10:53 AM
800mZero is offline
Find More Posts by 800mZero
3DHS Junkie
800mZero's Avatar
Rhode Island
Joined Jun 2005
Mike I am putting a 4 blade zinger on the new hanger 9 mustang. They are avaialble from zingerpropellor.com---you need to call them. You would be looking at a 18-19X8-10 for scale size and performance.
For that why not look at the eflite power 160 on 10s, Coastwatcher another gent on here has great experience with zingers and has been coaching me.
Things I can tell you---they are nice, but expensive. The hub is very thick so make sure the prop adapter is long enough to accommodate spinner back plate and prop hub. Zinger makes the 4 blade spinners to go with your prop and they are nice.
Although close you will need to balance the prop.
Heres a pic of mine in place using the hanger 9 spinner.
800mZero is offline Find More Posts by 800mZero
Old Dec 15, 2009, 07:03 PM
mpope1 is offline
mpope1's Avatar
gilbert,az
Joined Dec 2005
Thanks for the info, I thought I was missing something on there website. Couldn't figure out pricing and how to order, I will give them a call. I like to use hacker motors because they are distributed out of Tempe,Az. Only a few miles from where I live, so they let me go down and p/u stuff when I need it. Mike Donovan is real helpful, sure he can help me witht the prop adapter. I like that they have 3 different kv's in each class to choose from to really taylor the power I want to get! Man those blades look great on your mustang, what size did you use. That is the 80" p-51?
Build Log Top Flite Gold Edition P-51D KIT Conversion to P-51B denial15 Glow to Electric Conversions 70 Feb 05, 2010 12:46 AM
H.O.B P-51D Mustang 1/2A conversion. genovia Scale Kit/Scratch Built 42 Dec 07, 2002 10:22 PM
Flying Styro P-51D Mustang r/c conversion,anyone successful? bipeflyer Parkflyers 20 Jul 29, 2001 12:54 AM
Flying Styro P-51D Mustang r/c conversion,anyone successful? bipeflyer Foamies (Kits) 2 May 17, 2001 08:48 AM
Flying Styro P-51D Mustang r/c conversion,anyone successful? bipeflyer Scale Kit/Scratch Built 0 May 16, 2001 02:35 PM
