Old May 06, 2003, 01:15 PM
surfimp is offline
Find More Posts by surfimp
Piscine Promulgator
surfimp's Avatar
United States, CA, Santa Barbara
Joined Feb 2003
Airfoil suggestions for tailless FSW slope glider sought
Hello all, I'm in the pencil & paper stage on a tailless forward swept wing (FSW) slope glider design, and am seeking opinions regarding suitable airfoils.
This is the first plane I'm attempting to design completely from scratch, so it's a great learning experience for me. I do have a bit of experience flying tailless gliders (the Weasel to be precise) and have access to a very nice CNC foam cutter.
I plan to use a fiberglass fuse and balsa-sheeted EPS wings.
My current dimensions are as follows:
Span 60"
Length 27"
Root chord 10.5"
Tip chord 4.5"
Forward sweep at LE 1.5"
Fin length 12"
Fin height 6"
Apologies as I'm at work right now and don't have access to my pencil sketch of the proposed planform. I will post that later on today when I get back home. Hopefully the above information is adequate to give an idea of what I'm thinking about.
So, any airfoil suggestions?
surfimp is offline Find More Posts by surfimp
Old May 06, 2003, 06:04 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Here's all the world's knowledge on flying wings...
http://www.b2streamlines.com/winglinks.html
Something in the MH series would probably fit your purposes.
Sparky Paul is offline Find More Posts by Sparky Paul
Old May 06, 2003, 06:11 PM
Ollie is offline
Find More Posts by Ollie
Punta Gorda, FL
Joined Apr 2002
See Bill Evan's Saracen at:
http://www.rcmmagazine.com/e/env/000...m=plans:pl-639
The airfoil is tried and true for your application. There are many other possibilities. You will need low pitching moment coefficient airfoils and wash-in or, positive pitching moment coefficient airfoils with no twist in the wing. See:
http://www.aerodesign.de/english/profile/profile_s.htm
and
http://perso.wanadoo.fr/scherrer/mat...h/fwairfe.html
A swept forward wing is unstable in yaw and needs a large vertical tail volume coefficient to stabilize it in yaw.
Aerodynamically, the sweep angle is defined by the 25% chord line , not the leading or trailing edge.
The CG, taper, sweep, twist and airfoil selection are interdependent in a flying wing design. All five factors must be harmonized to achieve pitch stability and pitch trim. Since four of the factors are usually built in and not very adjustable, successful flying wing design rests more heavily on theoretical calculations than does the design of a conventional, tailed configuration. By guess or by gosh seldom works for flying wings. Just so you know what you are letting yourself in for.
Ollie is offline Find More Posts by Ollie
Old May 07, 2003, 07:38 AM
orectolobus is offline
Find More Posts by orectolobus
TerryM
orectolobus's Avatar
United States, AR, Heber Springs
Joined Sep 2001
Scratch Design and airfoils
If your going to draw your own plans and need to
import your selected airfoil into the project you may
want to check out the Airfoil Design Workshop.
It's an easy-to-use piece of software that allows you to
display and interactively modify airfoil shapes. It can
import airfoil data files directly from a web site. You can
export the airfoils to either a DXF file or ASCII text.
If you don't have or need CAD software and just want
to view and print the airfoils you can use a free DXF
file viewer called CADView. (Link to this viewer
on the AFD web site.)
AFD Web Site - Free Demo
orectolobus is offline Find More Posts by orectolobus
Old May 07, 2003, 02:05 PM
surfimp is offline
Piscine Promulgator
surfimp's Avatar
Joined Feb 2003
First up, thanks all for the advice. I'm aware of the special challenges associated with FSWs in general, and in specific when it comes to tailless designs. But I figure I get the most learning bang-for-my-buck this way!
Here's more detailed info, sorry for the introductory stuff, it was from memory while I was at work:
Code:
Wingspan        60.0"
Root Chord      10.5"
Tip Chord        4.5"
Wing Area       ~450 sq.in.
Aspect Ratio     8.00
Taper Ratio      0.43
Sweep @ C/4     -5.62
Static Margin    3% / ~0.25"
Neutral Point    1.30"
C.G.             1.05"
I'm shooting for an AUW of around 20-22oz., and a wingloading of around 7oz./ft. A similar plane of about 51" span was built around this fuse, with FSWs and a V-tail. It came out to 16oz. balanced, so even with my rather noseweight-requiring large and rearward fin (to be from 1/8" competition balsa) I think I'll be OK with an estimated AUW of around 20-22oz.
I've been recommended to try to find an airfoil that is thin (~8% or so), with 1-1.5% camber, and an
average Cm of about +0.01. Apparently, EMX 07 might be a good candidate, although it might need a bit more reflex. In general, the recommendation has been to look at profiles for plank-type wings, as opposed to regular swept wings.
Thanks again for any feedback!
Old May 07, 2003, 03:05 PM
surfimp is offline
Piscine Promulgator
surfimp's Avatar
Joined Feb 2003
Any thoughts on HS 2.0/8.0 from the Flying Wing database mentioned above? Here's the link:
http://www.aerodesign.de/english/pro...e_s.htm#hs2080
Here's the info:
HS 2.0/8.0
Class: Schlagprofile (Reflexed)
d[%]: 8.00
cm_0: +0.0120
a_0: -0.33
Use: Plank, Slope
Old May 07, 2003, 03:14 PM
Ollie is offline
Punta Gorda, FL
Joined Apr 2002
EMX-07
1.00000 0.00152
0.99726 0.00167
0.98907 0.00212
0.97553 0.00291
0.95677 0.00407
0.93301 0.00571
0.90451 0.00793
0.87157 0.01078
0.83457 0.01425
0.79389 0.01845
0.75000 0.02339
0.70337 0.02896
0.65451 0.03504
0.60396 0.04152
0.55226 0.04819
0.50000 0.05475
0.44774 0.06091
0.39604 0.06636
0.34549 0.07074
0.29663 0.07360
0.25000 0.07447
0.20611 0.07291
0.16543 0.06921
0.12843 0.06333
0.09549 0.05555
0.06699 0.04655
0.04323 0.03690
0.02447 0.02692
0.01093 0.01679
0.00274 0.00723
0.00000 0.00000
0.00274 -0.00495
0.01093 -0.00831
0.02447 -0.01113
0.04323 -0.01362
0.06699 -0.01571
0.09549 -0.01751
0.12843 -0.01916
0.16543 -0.02077
0.20611 -0.02236
0.25000 -0.02394
0.29663 -0.02539
0.34549 -0.02656
0.39604 -0.02744
0.44774 -0.02801
0.50000 -0.02825
0.55226 -0.02811
0.60396 -0.02756
0.65451 -0.02659
0.70337 -0.02502
0.75000 -0.02273
0.79389 -0.02013
0.83457 -0.01755
0.87157 -0.01497
0.90451 -0.01225
0.93301 -0.00947
0.95677 -0.00688
0.97553 -0.00466
0.98907 -0.00296
0.99726 -0.00189
1.00000 -0.00152
Old May 07, 2003, 09:07 PM
surfimp is offline
Piscine Promulgator
surfimp's Avatar
Joined Feb 2003
I've decided to try it out with the HS 2.0/8.0...I've bounced that off my co-conspirator and we think it will work. Thanks all for your help, I'll be posting project progress reports to the Slope forum once it gets underway. Should be interesting, to say the least.
Old Aug 14, 2009, 04:35 AM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
So how did it work out?
DT56 is offline Find More Posts by DT56
Old Aug 16, 2009, 01:05 AM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
You, being an old slope hand, probably remember the Larry Renger Toucan, in a 1993 Model Airplane News construction article.
It was a very well done and attractive FS sloper. I ended up with a rather ratty DCU T60R (after buying someone out when they got out of the hobby), a developmental version of the Toucan kitted by DCU and Dreamcatcher.
Might be worth some research to see what airfoil Larry used.
There are some Toucan or T60R pics here on R/C groups, somewhere
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Aug 16, 2009, 09:54 PM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
The amount of forward sweep you're indicating is insignificant in terms of any possible forward sweep issues. Just treat the whole model as a plank style wing in terms of airfoil choice and CG location to the MAC.
BMatthews is online now Find More Posts by BMatthews
Power Suggestions for SR X440 Powered Glider Crashmaster Electric Sailplanes 7 Nov 04, 2005 09:28 PM
Airfoil suggestions for a Mini Falcon/Limit type plane? davekra Slope 6 Jan 18, 2005 12:58 PM
Motor/prop/battery suggestions for powering micro SPAD glider? surfimp Power Systems 0 Dec 17, 2003 02:05 AM
Airfoil suggestions for Pylon 400's Admiral_Red High Performance 2 Dec 02, 2002 10:13 AM
Airfoil suggestions for 2M project... Redster Thermal 4 Sep 02, 2002 09:32 AM
