This thread is privately moderated by dag214, who may elect to delete unwanted replies.
Old Apr 20, 2011, 06:12 AM
pmisuinas is offline
Find More Posts by pmisuinas
United States, VA, Springfield
Joined Feb 2000
subscribed...
pmisuinas is offline Find More Posts by pmisuinas
Old Sep 05, 2011, 05:43 AM
dag214 is offline
Find More Posts by dag214
Rock On- Damon Atwood
dag214's Avatar
Fishers, Indiana
Here is an update with the A7.
Over the last month I got most the the wing designed in Compufoil. The wing is very cool. I should start pulling the Compufoil info into CAD next month and then in to my 3D design after that.
Thanks, DAG
dag214 is offline Find More Posts by dag214
Old Nov 17, 2011, 03:24 PM
seeingeyegod is offline
Find More Posts by seeingeyegod
seeingeyegod's Avatar
United States, OR, Portland
Just noticed you were working on this plane while going back through the B-36 thread. You are crazy! Or a genius! A crazy genius And not evil Wishing I had your life sometimes.. thanks for sharing and remember to ignore the trolls because they are a very small annoyance compared to the inspiration and excitement your projects bring to so many.
seeingeyegod is offline Find More Posts by seeingeyegod
Old Nov 18, 2011, 10:10 AM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Thanks!!
Dag
Old Nov 19, 2011, 08:41 AM
coptercptn is offline
Find More Posts by coptercptn
coptercptn's Avatar
United States, AZ, Mesa
Joined Dec 2008
Can't say it any better than that!!!!!
coptercptn is offline Find More Posts by coptercptn
Old Jan 19, 2012, 12:04 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Well.......
Here is a real update.
Still on the ropes as if this will be next, but I have the wings about 65% design, and the fuse about 80%.
DAG
Old Jan 19, 2012, 09:11 PM
JohnSH is online now
Find More Posts by JohnSH
Joined Aug 2010
Air flow adjustments
Dag; I have been silently following your B36 build and cannot fully express my amazement at you skill and audacity at even attempting such a project.
I think your A7D is just as brazen and I really want you to succeed at it. I was checking out your sketch of the A7D design and couldn't help but notice that you might experience some loss of EDF efficiency because of the uneven airflow pattern through your engine duct work.
At first glance, it appears that the air entering the two EDFs will be unevenly distributed and somewhat turbulent. The air exiting the fans will also experience some significant turbulence as it recombines to exit the exhaust nozzle.
Here is a sketch showing extensions to the inlet and outlet splitter vanes.
I would suggest that you do a wind tunnel mock-up study to fine tune the length and angle of the vanes. Find a way to measure the airflow through the two fans to equalize it and blow some smoke through the mock-up to study the turbulence and minimize it.
I doubt that it could ever be perfect but otherwise you may risk a significant loss of efficiency and thrust if you don't give it a try.
JohnSH is online now Find More Posts by JohnSH
Old Jan 20, 2012, 07:58 AM
dag214 is offline
dag214's Avatar
Fishers, Indiana
111% agree.
This project will have most of it R&D in this ducting. As drawn does not reflect at all the ducting design I am working with, just airframe.
Thanks!!!!
DAG
Old Jan 20, 2012, 12:23 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
The dual fans using a common exhaust ducting has been done alread and has proven to work reliably. Ducted fans perform like positive displacement pumps at the levels we use them, as long as both run there can only be one direction the airflow will travel and that is thru the exit. It is imperative that the design of the outlet tube must be area ruled and the areas must coincide with the areas of the both fans tapering to ~85% of the total Fan Swept Area or the veloctiy out will either be low or there wont be enough area and back pressure will cause rotor efficiency to drop.
Tamjets already does this with thier 100mm sized fans in a large T45 they sell. I am sure Barry(Monkamarm2000) or Tam can help if you want the scoop on what they did.
http://www.rcgroups.com/forums/showp...1&postcount=37
Cheers,
Eric B.
AirX is offline Find More Posts by AirX
Old Jan 20, 2012, 04:51 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Cheers,
Eric B.
Thanks, as I get the design more stream line I will start looking at options.
My rough estimates are she will be 32-36 pounds. So I need a good safe 15-20 pounds of thrust. Some of my calcs show her closer to 28 pounds.
Attached is what I got done late last night and this afternoon. I took off from work at 4 toady....... I needed to find more room for air tanks and by raising the motors a bit I actually helped with the ducting.....
DAG
Old Jan 20, 2012, 07:46 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Well this kinda sucks,...... but you will understand just how much time it takes to design a fuse from the station lines from a A7 maintenance manual....
But at least my math is right and everything will fit perfect with the other components.
DAG
Old Jan 20, 2012, 07:49 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Dag,
2-125mm fans from a reputable manufacturer ie Tamjets or similar vendor should be able to provide 30-36lbs thrust in a pair of 12s-6000mah systems.
Cheers,
Eric B.
Old Jan 20, 2012, 08:12 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Dag,
Cheers,
Eric B.
30-36 pounds....Really??
This is really looking like my next project........
I believe this summer after the 36 is done I will have to start setting up a mock-up fuse. If I can get everything I want to fit in the fuse then the only other challenge is the folding wings.....
I think this plane a 98-101" span would look sooooo cool.....
Thanks for all your input, I am very new, hell not even hatched into DF.....
DAG
Old Jan 20, 2012, 08:47 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Yup 5 kw will give ~15lb thrust which would be average. Note this is bench thrust installed it would drop some due to duct losses.
Cheers,
Eric B.
Old Jan 21, 2012, 07:43 AM
dag214 is offline
dag214's Avatar
Fishers, Indiana
A bit more done... The ducts are not designed only for reference. I think you are all seeing inside how much it takes to get this all to fit, and know where the weight will be.
DAG
Build Log 257" B-36D Scratch Build 6 a turning and 4 a burning dag214 Giant Electric Planes 14874 Mar 31, 2016 04:21 PM
Discussion New AP platform coming together - cdi3d Aerial Photography 70 Nov 14, 2009 06:35 PM
Discussion Help with 257" B-36D power system. dag214 Power Systems 18 Sep 22, 2009 07:28 AM
Discussion Need help with 257" B-36 dag214 Electric Plane Talk 6 Nov 24, 2008 02:47 PM
