This thread is privately moderated by dag214, who may elect to delete unwanted replies.
Old Dec 08, 2009, 10:44 AM
dag214 is offline
Find More Posts by dag214
Rock On- Damon Atwood
dag214's Avatar
Fishers, Indiana
Build Log
A-7D Project
This is my A-7 Design Log, that will become my Build Log
Here is some of my design development 3D's and CAD. As I said I will not be doing anything with this design (maybe when I am traveling) until the B-36 is in the air. This will be a duel design, My 101" span A7-D, and a 36" span A7-D.
If I had to guess I would say this design will be done around December. And that depends on the B-36.
dag214 is offline Find More Posts by dag214
Old Mar 04, 2011, 06:49 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
I will update this as I get more of the design done.
Thanks, Dag
Old Mar 04, 2011, 07:00 PM
magillag is offline
Find More Posts by magillag
United States, MA, Swampscott
Joined Apr 2008
Subscribed!
magillag is offline Find More Posts by magillag
Old Mar 04, 2011, 07:38 PM
bdelapen is offline
Find More Posts by bdelapen
Sponsored by Team de la Peņa
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
OK Dag,
Found the video on Jack's site, the link is here:
http://www.flylowandfast.com/Files/V...20(High_L).wmv
The file is a little large but worth the download. You will notice that Rob does not use partial throttle very much during the flight, it's nearly like he has it on a two way toggle
Regards,
- Birger
bdelapen is offline Find More Posts by bdelapen
Old Mar 04, 2011, 08:14 PM
yates55 is offline
Find More Posts by yates55
The Ground came up and got me
yates55's Avatar
United States, NC, Newport
Joined Dec 2007
Subscribed!
yates55 is offline Find More Posts by yates55
Old Mar 04, 2011, 08:49 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Originally Posted by bdelapen View Post
OK Dag,
Regards,
- Birger
Is the way he uses the throttle because he wants speed, and not to burn up the ESC/motor? When I flew DF I was always between 50-70% power except on take off.
Also I found out with DF that once you had the plane clean and in the air it did not take a lot of power to fly the plane scale. If you wanted to go fast you just screamed around at full power. And I understand that most EDF's can't run at 100% for long with out getting hot.
If I take on this project I will do a ton of testing, but what I want to find out is if you have a plane with a huge wing (this would have 2,049 square inches) and have a very clean airframe, and has extremely efficient systems what would it take to really fly it. I have learned long ago that to fly scale takes much less power than most put into planes now days.
Thanks Buddy,
Damon
Old Mar 04, 2011, 08:58 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
And another thing.
After watching that video 3-5 times, that plane is so clean that it most likely hits max speed very efficiently, and fast. There is no drag on that plane and there for would not need a mid throttle setting to hold speed. I bet the EDF set up would fly twice the weight of that aircraft if it had twice the wing.
That is a great jet, but no way is it a scale flight. He seems to only use the power to hit a speed he is aiming for, then uses energy management to glide, until he hits the turbo-boost to hit his speed.
Very cool jet, but for what I am looking for way over powered.
Also keep in mind, the DF of the 80's were very under powered, we flew the wing, and had to stay a mile ahead of our jets. , kind of funny, that's the way the real ones were.
Thanks, D
Old Mar 04, 2011, 09:31 PM
bdelapen is offline
bdelapen's Avatar
Joined Aug 2008
Thanks Buddy,
Damon
So the main issue is currently the ESC's. There are not a lot of ESC's that can take that kind of power for long periods of time. The second thing is how ESC's generate heat, there are two components to how ESC generate heat:
  1. One is dissipation from the current passing through the transistors, higher current = higher heat (this is many times not the most critical component).
  2. The second is the heat generated from the actual switching, transistors only consume power when changing state (switching) thus generating heat during all these transitons.
This basically means that the worst heat generation in the ESC is typically between 60% and 99% throttle position when the ESC is in PWM. Now most of this problem will go away once ESC's have the ability to better take the power but right now 8000W is about where the technology has gotten.
Anyway, we can have a long discussion about this at SEFF
Regards,
- Birger
Old Mar 05, 2011, 05:45 PM
Fuzzy711 is offline
Find More Posts by Fuzzy711
Fuzzy711's Avatar
USA, MA, Chicopee
Joined Apr 2010
Subscribed!
Fuzzy711 is offline Find More Posts by Fuzzy711
Old Mar 06, 2011, 07:18 AM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Hey all,
I have gotten a ton of e-mails this weekend from guys sharing info on this project.
A guy that flys a system shared some numbers with me. He stated that if I want a targeted thrust I also need to know what tail pipe speed I need. He stated that the efficiency of the system will rely on the fan used, and all my ducting. He also shared some thoughts about in coming/out going are volume. I already have some of the formulas used on full scale, but because most of those can go super sonic it doesn't really work at this scale. Also a real jet only needs a small percentage of incoming air as the out going is expanded hundreds of times from combustion. EDF are just suck and blows. He also stated that there are not that many EDF guys that fly in a scale manner. He stated that the EPX system on 12C will pull under 120 amps and have at least 16 pounds of thrust, and that there are plenty of controllers out there that can handle that. He said the castle I used on my A-100 would work.
My design is going to be very aggressive as in the starting stage of the fuse it will be built in 2 halves to allow for as perfect at possible ducting system to be placed in side.
DAG
Old Mar 06, 2011, 10:23 PM
doonbt13 is offline
Find More Posts by doonbt13
United States, Mt, Belgrade
Joined Feb 2009
Subscribed
Very good. Happy. OH yeah... Excited to see this one.
doonbt13 is offline Find More Posts by doonbt13
Old Mar 06, 2011, 11:01 PM
AvistarAddict is offline
Find More Posts by AvistarAddict
AvistarAddict's Avatar
Joined Sep 2009
Been following the B-36, definately following along with this one.
AvistarAddict is offline Find More Posts by AvistarAddict
Old Mar 07, 2011, 09:48 AM
bdshort is offline
Find More Posts by bdshort
United States, AK, Ketchikan
Joined Mar 2008
I'll follow this one too! I was on the USS Midway yesterday, which has an A-7 on the flight deck. I'm actually embarrassed to admit I am not really familiar with the A-7, but it is a nice looking plane. BTW, if you're ever in the San Diego area, the Midway is a must see. We didn't get there until around lunch time, and half a day really is not enough time for even a "fast" visit. I probably missed the audio tour for 75% of the planes, didn't read a lot of the displays, and didn't get to hear any docent talks. I think I could easily spend 2 full days there.
Here's a pic of the A-7 - I thought I had more, but I guess not. If I'd known about this thread before I left I would have taken a lot more to post.
bdshort is offline Find More Posts by bdshort
Old Mar 07, 2011, 06:26 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
Very cool picture, Thanks!
I travel out there about 4 times a year, but never seem to have time to see anything cool. I will have to see the carrier though.
Thanks, DAG
Old Mar 07, 2011, 06:40 PM
dag214 is offline
dag214's Avatar
Fishers, Indiana
I have had some wonderful e-mails about this project, just wanted to say thanks for the info and support to all that like the A-7.
One e-mail I got was about how I go about my designs.
First I do the rough math of the airframe, then I size it to a power system that will give me a .25-1 to .5-1 power ration. My Emmaselle had a .3-1 on takeoff, and a .16-1 at cruise. She was a draggy pig and flew on the wing. So what I look at (and has worked for me all except once) is what will the plane need to fly in a envelop that will allow a good climb at takeoff with 100% power, but also cruise at level flight and make shallow turns at about 45-65% power. I have always pushed my designs to be light. Using bargain contest grade balsa, and CF I can build really light. Using CF tube on main gear struts also saves weight. When I am laying out a design, and I look at all the data on its size and weight, it is then at this point I look for the power system, then take the data of that system and scale the size of the airframe to that data.
It kind sounds like I am saying two things at once, and I kind of am. Knowing the material of what will make up the aircraft will give you a weight target, then when I find a close power system I then tweak the size for that power system, do I sound crazy yet. Or.... once I find a power system I know is cool and has some good data to support it, I size the airframe to that power system
I am going to try to share all of my design steps in this thread with this aircraft. I hope it does not get to boring, but I hope some will find it helpful.
Rock On!
DAG
Build Log 257" B-36D Scratch Build 6 a turning and 4 a burning dag214 Giant Electric Planes 14874 Mar 31, 2016 04:21 PM
Discussion New AP platform coming together - cdi3d Aerial Photography 70 Nov 14, 2009 06:35 PM
Discussion Help with 257" B-36D power system. dag214 Power Systems 18 Sep 22, 2009 07:28 AM
Discussion Need help with 257" B-36 dag214 Electric Plane Talk 6 Nov 24, 2008 02:47 PM
