This thread is privately moderated by j j b, who may elect to delete unwanted replies.
Old Dec 08, 2009, 07:27 AM
j j b is offline
Find More Posts by j j b
Joined Dec 2009
high lift airfoil
i will be entering a heavy lift challenge in 2010 with a group from university and we are currently trying to find a suitable airfoil to use. We are limited to the airfoils on compufoil 3D and as far as my research tells me, the eppler 214 is going to be the best one for producing the most lift. If anyone knows better could they let me know?
thanks. joe.
j j b is offline Find More Posts by j j b
Old Dec 10, 2009, 03:41 PM
j j b is offline
Joined Dec 2009
Some more details if they're needed to choose an appropriate airfoil:
wing span: around 190mm
engine: 6.47cc
any suggestions would be appreciated
Old Dec 16, 2009, 09:24 PM
Magician is offline
Find More Posts by Magician
Professional Lurker
Magician's Avatar
United States, MD, La Plata
Joined Nov 2004
Joe,
If you're looking for high lift then the S1223 designed by Selig is highly recommended. This foil was his answer to the dominant high lift foil that was used previously, the Wortman FX 63-137, which is still very good. The Eppler 214 is more for thermal sailplanes that use camber changing to get a wide performance range, it is not a real high Cl airfoil.
Good Luck with your project!
Magician is offline Find More Posts by Magician
Old Dec 29, 2009, 04:07 PM
Sefco is offline
Find More Posts by Sefco
Joined Feb 2009
Hey J J B I would suggest you read, read and read again the famous AMO Smith paper on high lift aerodynamics.
https://classshares.student.usp.ac.f...es%20paper.pdf
I would also suggest you research the Custer Channel Wing, this seems like an ideal application.
http://www.custerchannelwing.com/
Sefco is offline Find More Posts by Sefco
Old Feb 18, 2010, 03:13 PM
MCarlton is offline
Find More Posts by MCarlton
Cromer,Norfolk, UK
Joined Nov 2006
Are you allowed to import coordinates into Compufoil?
Something like Chuch Hollinger CH10 or similar would be a good bet;
http://www.ae.illinois.edu/m-selig/a...ots/ch10sm.gif
http://www.ae.illinois.edu/m-selig/a..._database.html
MCarlton is offline Find More Posts by MCarlton
Question High lift airfoil b-29er Fuel Plane Talk 8 Oct 05, 2009 03:03 PM
Help! Looking for an airfoil with high lift and gently stall nick_cool Modeling Science 34 Jul 14, 2009 11:47 PM
High lift airfoil with good low speed stall properties ? dvint Modeling Science 3 Sep 20, 2005 12:01 PM
Low wind high lift airfoil malkymoo Slope 4 Aug 11, 2005 02:15 AM
High Lift Airfoil Chuckhead1 Slope 12 Feb 04, 2005 11:05 AM
