Old Aug 18, 2010, 10:19 AM
2secondnosediv is offline
Find More Posts by 2secondnosediv
fairviewrcflier.webs.com
Fairview Heights IL
Joined Mar 2010
My sea dart
So I made this last night.... total pain in the ass, LOL.... I need to put my power pack into it (Microjet V3, 1600 mah 3S battery, 20A ESC, Dx6i RX) normally I paint planes and make them pretty but I want to maiden this plane first because I am skeptical of its preformance on Air, Land and Sea (hahaha) anyways, here are some build pictures.
2secondnosediv is offline Find More Posts by 2secondnosediv
Old Aug 18, 2010, 10:31 AM
siddus is offline
Find More Posts by siddus
Scott Quinn
siddus's Avatar
Nottingham UK
Joined Oct 2006
No need to be sceptical, build it to plan / not over heavy and ensure its ballanced atleast on or in front of the recommended CG and it will fly very well . . . (This plane does seem to be CG critical, otherwise it tends have weird tendancies in my experience)
I have over 50 flights on mine, 90% of them on/off water . . . I enjoy flying it and it has ensured I have continued flying on a couple of occasions at various water meets.
Siddus74
siddus is offline Find More Posts by siddus
Old Aug 18, 2010, 11:03 AM
Fairview Heights IL
Joined Mar 2010
When I set this on concrete it tips to the right. I probably need to adjust the plank thingy under the plane so the plane is centered right? Also, I have ensured the front portion is water tight which I assume is what needs to be done.
I have read something about up trip for the elevon setup. What was it like 8mms? Where is this measured?
Old Aug 18, 2010, 11:13 AM
siddus is offline
Scott Quinn
siddus's Avatar
Nottingham UK
Joined Oct 2006
I posted some pics previously that showed the 'reflex' from the rear view . . . check them out . . . (Its only a guide and trim changes anyway when you use different cells)
Siddus74
Old Aug 18, 2010, 11:55 AM
Jürgen Be is offline
Find More Posts by Jürgen Be
Jürgen Be's Avatar
near Stuttgart, Germany
Joined Oct 2008
Marcel
when I first seen your design and vid`s, the Seadart went to the "to do list"
You did a very nice job and thanks for sharing the plans.
My first thoughts were, that the prop in slot design is a bit noisy and maybe I will get some problems, when I take the plane to the small lake around here.
So the plans went to the "briefcase" `till last week............................and I played around with some 3mm Depron...................
Do you have any idea, what can be seen on the following photos?...........
Jürgen
Jürgen Be is offline Find More Posts by Jürgen Be
Old Aug 18, 2010, 12:01 PM
siddus is offline
Scott Quinn
siddus's Avatar
Nottingham UK
Joined Oct 2006
Nice fabrication, where the battery going to go?
Siddus.
Old Aug 18, 2010, 12:14 PM
Jürgen Be's Avatar
Joined Oct 2008
Nice question
I will try the fit of the EDF, then take a closer look, how to get the CG...........
Maybe I make a hatch in front of the inlets.
Jürgen
Old Aug 18, 2010, 12:17 PM
Fairview Heights IL
Joined Mar 2010
Originally Posted by Jürgen Be View Post
Nice question
Jürgen
Very nice... can you tell me your configuration set up (EDF type, ESC, battery, etc...)
Old Aug 18, 2010, 01:05 PM
Jürgen Be's Avatar
Joined Oct 2008
I will try an Alfa 60/25 Fan with a Mega 16/7/4 motor, on a 3 cell 1350mAh 20C, ECS should be 25-30A. I think I can get up to 500g thrust.
I don`t know, if it will work on the Seadart, but I want to try it out.
Jürgen
Old Aug 18, 2010, 01:13 PM
Fairview Heights IL
Joined Mar 2010
If it does I wouldn't expect to get any flight time out of it... a friend of mine said its a battery sucker
Old Aug 18, 2010, 01:21 PM
captaingeek is offline
Find More Posts by captaingeek
master of the universe
captaingeek's Avatar
USA, CA, Novato
Joined Jul 2008
Siddus74
Second that. I probably have a good 30 flights on mine. Watch the rates and CG on your maiden. mine is pretty heavy but is a great flier. I'm thinking of upgrading the motor.
captaingeek is offline Find More Posts by captaingeek
Old Aug 18, 2010, 01:24 PM
Fairview Heights IL
Joined Mar 2010
What motor are you using? Whats your set up
Old Aug 18, 2010, 01:26 PM
USA, CA, Novato
Joined Jul 2008
im currently using a rct 2200kv / 30A ESC
Old Aug 18, 2010, 01:45 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I'll second that power setup. The Microjet V3 may not be enough for this. Go with the standard 2212-6 2200kv motor, 30A ESC and APC 6X4E prop. RCTimer, RC Hot Deals, Grayson all have them.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Aug 18, 2010, 02:43 PM
JettaManDan is offline
Find More Posts by JettaManDan
Crazy Foamie Builder
JettaManDan's Avatar
United States, MD, Lexington Park
Joined Jan 2010
don't see your EDF design working..splitting up the exhaust from the fan is going to rob all of it's power..
JettaManDan is offline Find More Posts by JettaManDan
Build Log Prop in slot Saab Draken - Plans (6mmFlyRC) vleisie Pusher Prop Jet Models 757 Jun 03, 2016 04:41 AM
Build Log Prop in slot Kfir / Mirage 6mm depron Blueangels4 Pusher Prop Jet Models 4 Oct 23, 2013 04:28 PM
Video Prop in slot noise test leadfeather Electric Plane Talk 5 Nov 07, 2008 06:41 PM
Discussion Slot design for "prop in slot" leadfeather Foamies (Scratchbuilt) 32 Oct 17, 2008 09:45 PM
Discussion Plan for "Prop in a slot" profile Epp jet model ? dekan Pusher Prop Jet Models 0 Jul 11, 2007 01:36 PM
