Old Dec 13, 2009, 10:09 PM
b-29er is online now
Find More Posts by b-29er
Buzz Run Extraordinare!
b-29er's Avatar
USA, MI, Sanford
Joined Jul 2006
What was your t/w for the plane?
b-29er is online now Find More Posts by b-29er
Old Dec 14, 2009, 01:54 AM
vleisie is offline
Find More Posts by vleisie
boerie roll
vleisie's Avatar
Johannesburg, South Africa
Joined Apr 2007
Originally Posted by ATIS View Post
man that looks cool sliding across the grass!! I too cant wait for the water video. Any chance of tiled plans? She floats right in for landings.
I will definitely post plans if the water trials are successful and once the design is finalised.
vleisie is offline Find More Posts by vleisie
Old Dec 14, 2009, 01:57 AM
vleisie is offline
boerie roll
vleisie's Avatar
Joined Apr 2007
Are you asking about the weight? If so, weight in the video is 500grams with a 1250mah. I've also flown it at 550grams with a 2200mah. It balances easily with both. BTW, the paint scheme weighs 50grams!
Old Dec 14, 2009, 06:12 AM
b-29er's Avatar
USA, MI, Sanford
Joined Jul 2006
well, yes and no. What was the thrust to weight ratio?
I do have to say, however, that your model looks great. Post a video on the water, especially if you get the ski to retract and deploy.
Old Dec 14, 2009, 06:16 AM
vleisie is offline
boerie roll
vleisie's Avatar
Joined Apr 2007
Oh ok, at 500g it should be better than 1:1.
Old Dec 14, 2009, 01:45 PM
burkefj is offline
Find More Posts by burkefj
burkefj's Avatar
Joined Oct 2006
That looks really great in the air, I think you captured the lines really well, and it looks like it flies as well as the delta's I've built, nice and docile. I'm excited to see it off of water. I might have to break down and build a plane now, it's been almost half a year.
Frank
burkefj is offline Find More Posts by burkefj
Old Dec 14, 2009, 02:05 PM
vleisie is offline
boerie roll
vleisie's Avatar
Joined Apr 2007
Frank
Thank you Frank. I should get it on the water by the end of the week, but I won't be able to download video until January. I will post some pictures.
Marcel
Old Dec 14, 2009, 04:02 PM
TheTrashMan is offline
Find More Posts by TheTrashMan
TheTrashMan's Avatar
Joined Jul 2009
Marcel
Do you think the graysonhobby microjet V3 would work well on this plane?It looks great by the way!!!
TheTrashMan is offline Find More Posts by TheTrashMan
Old Dec 14, 2009, 10:17 PM
vleisie is offline
boerie roll
vleisie's Avatar
Joined Apr 2007
Thanks, and yes, I think it will work.
Marcel
Old Dec 15, 2009, 12:29 PM
Joined Jul 2009
are you going to make the plans tiled?
Old Dec 15, 2009, 07:40 PM
b-29er's Avatar
USA, MI, Sanford
Joined Jul 2006
Where was the COG of your model?
Old Dec 16, 2009, 07:06 PM
Grejen is offline
Find More Posts by Grejen
IAMCANADIAN
Grejen's Avatar
Canada, BC, North Vancouver
Joined Jul 2002
The floats seem to have solved the water stability.
Here is some video, flying off grass:
http://www.youtube.com/watch?v=mWttMnc5KAk
Most of the flight is at about 50% power and never more than 80%, as I was trying a 1250mah battery for the first time.
Very neat. normally I'm not a fan of 'slot jets' but this worked out well. Can't wait to see it running off water.
Grejen is offline Find More Posts by Grejen
Old Dec 16, 2009, 10:12 PM
vleisie is offline
boerie roll
vleisie's Avatar
Joined Apr 2007
I have it at 50% of the centreline chord (if you extend the leading and trailing edges to the centreline), which is standard for a delta. This turns out to be 40% of the root chord for this plane.
Old Dec 16, 2009, 10:15 PM
vleisie is offline
boerie roll
vleisie's Avatar
Joined Apr 2007
I don't have the tile software, but I'm sure someone else will help out.
I'm on holiday at the coast at the moment, plenty of water, but a bit windy today.
Old Dec 17, 2009, 01:02 PM
Joined Jul 2009
Is 6mm doing a kit?Have you taken off,and landed on water yet?
Build Log Prop in slot Saab Draken - Plans (6mmFlyRC) vleisie Pusher Prop Jet Models 757 Jun 03, 2016 04:41 AM
Build Log Prop in slot Kfir / Mirage 6mm depron Blueangels4 Pusher Prop Jet Models 4 Oct 23, 2013 04:28 PM
Video Prop in slot noise test leadfeather Electric Plane Talk 5 Nov 07, 2008 06:41 PM
Discussion Slot design for "prop in slot" leadfeather Foamies (Scratchbuilt) 32 Oct 17, 2008 09:45 PM
Discussion Plan for "Prop in a slot" profile Epp jet model ? dekan Pusher Prop Jet Models 0 Jul 11, 2007 01:36 PM
