Old Jun 12, 2012, 12:02 AM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
Originally Posted by viperviper View Post
thanks for the recommendation. btw i keep hving my nose retract's inner rod bent, the rod that which the nose strut is inserted to..
anyway to reinforce it to prevent any further bending?
Hmmm I've never had that problem, not sure why that's happening but something must be wrong. I'm using the Eflite retracts on a habu32, het F20, pro design f-18 and pro design f-22 with no problems. I did bust a main on the F-22 after a hard landing but since then they have worked great. Never had one nose gear bend or fail.
bri6672 is offline Find More Posts by bri6672
Old Jun 12, 2012, 12:06 AM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Originally Posted by kingkyle View Post
I just got mine in the mail. What do you guys think about attaching the rear stabs and cutting in elevators in the conventional method? Only reason I ask is because I've had issues with full flying stabs. Do you think I would have enough control surface?
Stick with the full flying stabs it flys great with them no problems. If you have the older kit with the bearing boxes you just need to add hysol to the L bend in the stab to reinforce it (mentioned a bunch of times in this thread) if you have the newer version with the brass tubes and axels sliding thru you need to cut out and remove the axel with a thicker axel wire and put in larger brass tubes. The current stock axels flex quite a bit. My F-22 is pretty light but on high speed passes they flex alot. The f-18 will need them upgraded!
Old Jun 12, 2012, 01:45 AM
viperviper is online now
Find More Posts by viperviper
Antarctica
Joined Apr 2012
Thanks for the reply, the reason it breaks is becos it's not eflite retracts.
anyway, i hv a f20 70mm, prodesign rafale 70mm twin, het f-15 70mm twin and hk f-18 90mm single... can u recommend one set of eflite retracts with structs for it to be transfer from one aircraft to another...for all these aircraft. Just hope to buy one set, as i will be building only one aircraft at the time to fly and subsequently flying another after decommission.
viperviper is online now Find More Posts by viperviper
Old Jun 12, 2012, 02:30 AM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Well I use the 10-15 size for the nose and then make a wire strut out of 1/8 wire that is centered as opposed to offset, this allows me to set up a mechanical gear door. For the mains I use 15-25's with the stock struts, I use styrene tubing to simulate a strut and they end up looking great with no additional weight. Tams struts are real nice but you need to make sure that they will work on the mains with the front to back retract configuration compared to the left to right format. There really isn't any decent struts in this size aircraft other than Tams.
Old Jun 12, 2012, 04:31 AM
Antarctica
Joined Apr 2012
hi Bro, is it possible that u take a pic of the retracts setup in your F-18 ?many tks in advance.
Old Jun 16, 2012, 02:11 AM
seadog985 is offline
Find More Posts by seadog985
Tin Can Sailor
seadog985's Avatar
Alabama, USA
Joined Feb 2009
Just wondering, did anyone that cut their exhaust back to get a 50mm opening make new extensions for a more scale look or did you just leave it "bobtail". Wanting to know what they might have made them (exhaust) out of. Have moved mine to the work bench. Have recieved the new canopies from Park Flyer Plastics and have started getting one ready. I'm going to put the 1st one on the frame that came with the plane and I think I'll order the detailed cockpit and put a second canopy on that one. One for display and one for flight. Will post picks of canopy early next week, working this weekend
seadog985 is offline Find More Posts by seadog985
Old Jun 16, 2012, 09:41 AM
Antarctica
Joined Apr 2012
i gave up... the stock retracts are lousy.... firstly it bends easily almost every landing.. now the internal motor not working.... why cant one sell or manufacture a super robust landing gears.... Anyone can recommend...E-Flite 15-25? will the rod struct of this eflite retracts bend easily too... yes, the rod piece .. pls advise/
Old Jun 16, 2012, 04:05 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Put spring air 602s or tams retracts in it and be done with it.
Old Jun 19, 2012, 03:26 PM
Tin Can Sailor
seadog985's Avatar
Alabama, USA
Joined Feb 2009
Have one of the new canopies almost ready. Material is much stronger than the stock canopy.
Old Jul 07, 2012, 06:05 AM
Antarctica
Joined Apr 2012
may i ask for those who hv the jet and flying with 6S , what is your F-18 AUW? pls kindly advise. tks!!
Old Jul 07, 2012, 06:24 AM
MattinAZ is offline
Find More Posts by MattinAZ
MattinAZ's Avatar
United States, AZ, Gilbert
Joined Jan 2005
6.75 lbs with spring air retracts, 6S4000's. 7.5 lbs with 7S5000's. Flys great and lands like a parachute. There is video of it somewhere in this thread.
MattinAZ is offline Find More Posts by MattinAZ
Old Jul 08, 2012, 07:35 AM
Boostoman is offline
Find More Posts by Boostoman
Boostoman's Avatar
Oman, Masqat
Joined Apr 2010
Mattin,
what motor are u using and what thrust/watts are u getting
Boostoman is offline Find More Posts by Boostoman
Old Jul 08, 2012, 08:59 AM
Tin Can Sailor
seadog985's Avatar
Alabama, USA
Joined Feb 2009
Mattin, did you cut the extra hatch behind the canopy?
Old Aug 04, 2012, 07:50 PM
MattinAZ is offline
MattinAZ's Avatar
Joined Jan 2005
Prodesign 5 blade balanced outrunner combo. 81 amps 2000 watts.
No I did not cut the extra hatch behind the canopy.
Old Aug 04, 2012, 07:52 PM
MattinAZ is offline
MattinAZ's Avatar
Joined Jan 2005
Does anyone have an extra thrust tube for the Prodesign F-18 from a crashed airframe?
I need qty 2 for a scratch build project. I will pay for the shipping and handling.
Matt
New Product Silverlit Swiss Version F/A-18 (NEW and diff from AirHogs F-18!) xlcrlee Micro Ready-to-Fly 152 Oct 05, 2015 02:35 AM
Video New Pro-design 90mm F-18 video lavochkin Electric Plane Talk 5 Nov 19, 2009 05:57 PM
Discussion New RTF Jet BlitzRCWorks F/A 18 Hornet Pro V2, 130MPH Steam28 Banana Hobby 4 Oct 27, 2009 05:54 PM
Alert F-18 vs F-18 takeoff1 Fuel Plane Talk 0 Sep 13, 2009 09:00 PM
Discussion Art tech F-18 or Exceed rc F-18? RC-PlaneFan Foamy EDFs 6 Sep 12, 2009 05:27 PM
