Old Jan 20, 2010, 01:48 PM
MattinAZ is online now
Find More Posts by MattinAZ
MattinAZ's Avatar
United States, AZ, Gilbert
Joined Jan 2005
Yes, a 4S and 3S in series
Originally Posted by bri6672 View Post
Nice specs Matt! Just goes to show you how far off fancalc can be! Looking forward to seeing some pics and hear about the Maiden. We are getting slammed with rain in San Diego as well, fingers crossed that I can fly this weekend.
Brian
Oh by the way did you go 3s 5000 and 4s 5000 in series?
MattinAZ is online now Find More Posts by MattinAZ
Old Jan 20, 2010, 01:49 PM
MattinAZ's Avatar
Joined Jan 2005
Thanks for the tips.
Matt
Originally Posted by ApexAero View Post
Fiberglass panel adhesive works well on formers and doesn't drip all inside the fuse like that epoxy job you got there. Try giving Bounty some business.
Also if you tape off the areas you're gonna cut layout then score the lines a few times with a blade before letting that chain saw get to that nice glass work.
Old Jan 21, 2010, 05:56 AM
zach_dad is offline
Find More Posts by zach_dad
TEXAS
Joined Sep 2005
MAtt, Have you done a power test, If you hold plane in hand with the nose straight up and give it full throttle will it stay a float if you let go? Or does it fall back. Do you also have a scale to weigh the plane with batteries and everyhing inside? A ready to fly weight basically. I would greatly appreciate some numbers and like to see if plane can hold it self up with out falling back.
zach_dad is offline Find More Posts by zach_dad
Old Jan 21, 2010, 08:58 AM
MattinAZ's Avatar
Joined Jan 2005
Read back to post #56.
Old Jan 21, 2010, 09:30 AM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
Looks like they have made a recent design change to this plane, Matt's came with 9 gram size servo cutouts for the tailerons but mine has std size servo cutouts and the manual now states std size servos with metal gears are required. Sounds like the 9 gram setups didn't hold up. I worked on my retracts with the prodesign struts last night, some people complained about the size of the front tire that comes with the struts, well with a little grinding you can easily fit the front tire that goes with the fixed gear that came with the plane, it looks more scale. Hey Matt an chance we could get u to post some pics from inside the plane, I'd like to see your retract and esc setups.
Brian
bri6672 is offline Find More Posts by bri6672
Old Jan 21, 2010, 03:22 PM
zach_dad is offline
TEXAS
Joined Sep 2005
Thankyou for weight numbers, now how about the thrust check, will the plane hover at full throttle or fall back?
I have a f18 from ejf, weight is 6.5lbs with batteries, jetscreamer 1400 on 6s and HET fan, wish I used the midi, or rc lander maybe Ill change, got a static thrust of 3.10lbs, made 1100watts, and drew only 52amps, Swicthed to 8s same setup made 5.6lbs of thrust and drew 82amps, made close to 2000watts. I'm over voltage on motor but drawin correct amps.
flew it with 6s setup the plane flys great but not a speed demon like in real life barely enough power to hand launch, Matt I'm thinkking your going to need more Crystals to have any type of fun. Of course all my test are done on a watt meter and static thrust on scale, Im going to out plane on scale with nose, zero scale, then hit the gas maybe I can see what thrust it will have installed.
Old Jan 21, 2010, 05:49 PM
MattinAZ's Avatar
Joined Jan 2005
I am running 7S at 1900+ watts 175mph+ efflux. Motor and esc are capable of 8S but not going there until I get some flight behind her. I do not have a way to measure thrust right now. Might buy a fish scale in the future but what I have found is that efflux v is more important for my jets than static thrust. I don't plan on hoovering my F-18.
Will get some more picutes up soon. Maybe even a vid of my mixing to enable 2 flight modes. Its pretty cool
Flight mode 1 std elevator and ailerons
Flight mode 2 tailerons, ailerons, plus flaps for landing.
Hope this helps
Old Jan 21, 2010, 05:50 PM
MattinAZ's Avatar
Joined Jan 2005
Yes, they do listen to there customers and have made some changes to thier planes.
Matt
Looks like they have made a recent design change to this plane, Matt's came with 9 gram size servo cutouts for the tailerons but mine has std size servo cutouts and the manual know states std size servos with metal gears are required. Sounds like the 9 gram setups didn't hold up. I worked on my retracts with the prodesign struts last night, some people complained about the size of the front tire that comes with the struts, well with a little grinding you can easily fit the front tire that goes with the fixed gear that came with the plane, it looks more scale. Hey Matt an chance we could get u to post some pics from inside the plane, I'd like to see your retract and esc setups.
Brian
Old Jan 21, 2010, 07:26 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Matt
Its nice to see that they are making an effort unlike some companies! So far I am pretty happy with my build, retracts are in and struts and they seem to work well. I am mounting the taileron bearing boxes, definitly a delicate process!
Old Jan 22, 2010, 09:19 AM
MattinAZ's Avatar
Joined Jan 2005
Beef that taileron install up. They dont get that us crazy americans like everything way overpowered. Good luck on yours. Its still raining here and I dont think I am going to get a maiden in this weekend might have to wait unitl Monday.
Matt
Old Jan 22, 2010, 12:53 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
So how did it fly on 8s, the thrust to weight ratio should make that thing an all out rocket!!! Also you have a jet screamer motor so are you running a 70mm fan instead of the 90mm or did you just decide to use the smaller motor?
Old Jan 22, 2010, 01:01 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Matt
Im on it man, they are really weak with the stock install, I used the little balsa blocks they give you for your aileron servos and epoxied them in key points to beef it up, I think I am going to get some different linkages because the stock ones are giving me some slop, oh and I ended up going with the hs-645mg high torque servos (I think you used these as well), they are a bit heavy but super powerfull at 106-133oz in torque. We are getting pounded on with rain in San Diego as well, bummed cause I thought I might be able to sneak out and fly my ME109
Old Jan 22, 2010, 02:28 PM
reinhoud is offline
Find More Posts by reinhoud
reinhoud's Avatar
Joined Sep 2004
Came across this video. Hopefully we will see here more soon.
http://v.youku.com/v_show/id_XMTQzOTEwMjAw.html
reinhoud is offline Find More Posts by reinhoud
Old Jan 22, 2010, 03:32 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Seen that one a couple of times, I would like to know what power system the are running cause it seems to be performing pretty well!
Old Jan 26, 2010, 01:33 PM
MattinAZ's Avatar
Joined Jan 2005
Finished the F-18 last night. Will take a few pics tonight and post them. The plan is to maiden it tomorrow or Thursday before the AZ Electric Festival.
Matt
New Product Silverlit Swiss Version F/A-18 (NEW and diff from AirHogs F-18!) xlcrlee Micro Ready-to-Fly 152 Oct 05, 2015 02:35 AM
Video New Pro-design 90mm F-18 video lavochkin Electric Plane Talk 5 Nov 19, 2009 05:57 PM
Discussion New RTF Jet BlitzRCWorks F/A 18 Hornet Pro V2, 130MPH Steam28 Banana Hobby 4 Oct 27, 2009 05:54 PM
Alert F-18 vs F-18 takeoff1 Fuel Plane Talk 0 Sep 13, 2009 09:00 PM
Discussion Art tech F-18 or Exceed rc F-18? RC-PlaneFan Foamy EDFs 6 Sep 12, 2009 05:27 PM
