Old Dec 06, 2009, 04:02 PM
Zbig_T is offline
Find More Posts by Zbig_T
Joined Jan 2009
Mini-HowTo
Walkera 4#3B double brushless on diet - how I got +100% of flight time
Hello
I've started with basic Walkera 4#3B version, which I've soon upgraded to brushless main motor. Recently, after some frustration with brushed tail motors failing one after another after replacing the first one (which lasted quite long), I decided to go for a brushless tail as well. Altough equipped with both brushless motors (all Walkera accessories) my heli looks like some Dr. Frankenstein's creation, with all these ESCs and cables, everything worked quite fine with one exception: flight times. Using 600 mAh 15C LiPos I was only getting mere ~5-6 minutes of flight times on average, 8 minutes tops. Most presumably that was because of the increased weight. My fully upgraded heli weighted about 51 grams without battery. I've decided to do a few minor tweaks in an attempt to reduce some weight. After that my 4#3B ended up weighting some ~2-2.5 grams less (49g without a battery) which I was afraid wasn't enough to yield noticeably longer flight times but to my surprise, I've suddenly got consistent flight times of over 11 minutes which in some cases is over double the original times!
Here are the photos of my modifications, along with some comments:
First of all, I've cut the redundant power cable with the battery plug (no longer used with brushless main) from the 4in1 module:
We're getting a little less clutter as an added benefit. Take care not to short the wires accidentally by non-clean cut.
Then, I've got rid of the power connector between the main motor ESC and the motor itself and carefully soldered the wires directly, securing the joints with some shrink tube:
Do not mix the cables and do the soldering well as there's some serious current involved.
Similarily, I've replaced the tail motor connector with a soldered connection:
Note the cable colors and take care not to break the delicate wires while removing the original plug.
Lastly, I've also replaced the battery to ESCs (both main and tail) Y-cable plugs with - yes, you've guessed it - good ol' soldering:
Triple-check the polarity (black to black, red to red), insulate properly! And again - do the soldering well so it could pass all these amps without problems.
A word of comment here: I suspect that my surprisigly good performance gain could be accounted not to the weight reduction alone. It could be that the original power connectors (ESC to main, battery to ESCs) don't cope with high currents well enough and by replacing them with a reliable soldered connections, we eliminate a possible weak link in the power transfer circuit. It is quite hard for me to believe that mere ~4% weight loss resulted in such a difference in flight times so I strongly guess it could also have something to do with the resistance of the original connectors. Especially the Molex-type one used for powering the main motor was definitely designed for conducting way smaller currents (they're very common as the PC case LED connectors and such).
I hope it helps someone unleashing the full potential of their 4#3B - in my case it was definitely worth the effort (but needless to say, I take no responsibility for any improper implementation of any of my tips). You don't replace your motors and electronics every few flights so I guess the loss of the connector-type cable joins is a completely reasonable tradoff.
Regards
Zbig
Zbig_T is offline Find More Posts by Zbig_T
Old Dec 06, 2009, 09:44 PM
XXXmags is offline
Find More Posts by XXXmags
Push
XXXmags's Avatar
Wow that's a big difference! may I ask do you have a 500mah battery to try your flight time on? I'm curious to know. (might get a double brushless 4#3)
XXXmags is offline Find More Posts by XXXmags
Old Dec 07, 2009, 08:25 AM
Zbig_T is offline
Joined Jan 2009
Just checked - now I'm getting solid 7:something minutes from 500 mAh LiPos (already worn out to some degree) instead of the average 4-6 minutes from before.
Old Dec 07, 2009, 01:11 PM
Martyn McKinney is offline
Find More Posts by Martyn McKinney
Toronto Canada
Joined Dec 2002
Just for interest, for the same rotor system, the Power required to fly is proportional to the weight to the three halves power.
POWER ~ WEIGHT^3/2
Using this formula will indicate how much of your increased flight time is due to a weight decrease.
Martyn McKinney is offline Find More Posts by Martyn McKinney
Old Dec 08, 2009, 01:25 PM
finallyaheli is offline
Find More Posts by finallyaheli
Cornwall,Ontario,Canada
Joined Mar 2002
moving comments
finallyaheli is offline Find More Posts by finallyaheli
Discussion Question about tail stability on Walkera 4#3B Double Brushless Glasswalker Micro Helis 5 Nov 20, 2009 04:18 PM
Sold Walkera 4#3B RTF, spare parts and w/micro-flight upgrades..... cerralvo78 Aircraft - Electric - Helis (FS/W) 1 Sep 02, 2009 10:59 AM
Sold Walkera RTF 4#3B BRUSHLESS $100 delivered Z06 Tony Aircraft - Electric - Helis (FS/W) 2 Jul 09, 2009 04:20 PM
For Sale Walkera 4#3B Brushless - $100 shipped! satl Aircraft - Electric - Helis (FS/W) 3 May 12, 2009 06:11 AM
Mini-HowTo Walkera 4#3b - Extreme Servo Mods/Diet Dark-Angel Micro Helis 19 Aug 18, 2008 04:07 PM
