Herer there are some measurements made both, in land and airborne, you can make your own conclutions:
http://www.rcgroups.com/forums/showthread.php?t=1101699 |
For a given prop, loading is really a function of blade angle of attack. Thus how much a plane unloads depends heavily on drag (both parasitic and L/D). Here's a page that describes what I'm talking about:
http://home.scarlet.be/comicstrip/En...Efficiency.htm ...and the key image from that page, which IMO embodies a lot of ideas an advancing hobbyists should know (TAS~aircraft velocity vector): ![]() When calculating such things, we usually speak of pitch in terms of degrees. Using trig you can easily convert pitch inches to pitch degrees (hint: slope of the helix). Given that hobbyists aren't equipped to accurately measure/estimate drag, trying to pin down an unloading factor is a long trip through muddy water. It's suffice to say: put setup X and prop Y on a bulky/draggy trainer, and it may not unload appreciably. Put setup X and prop T on a slippery pylon racing airframe, and you might see quite a bit of unloading. Cheers, Kev |
A 10x5 will drop to nearly half. But those with loggers on their planes show that the angle the plane is at makes a lot of difference. A full bore WOT climb is nearly full draw but flat out horizontal is a lot less unless the model is very steep on pitch. |
Toronto Canada
Joined Dec 2002
I don't know about all this.
According to NACA the power absorbed by a 10x6 prop at Pitch Speed drops to about (0.3/0.375 = 75%) of static, while a 10x11 prop drops to just a little less (0.55/0.8 = 68% ). The power absorbed at Pitch Speed is even less when expressed as a percentage of max power absorbed (which occurs at approximately 40% of Pitch Speed). Maximum power absorbed compared to static increases with P/D ratio and is about (0.0975/0.08 = 1.2) or 20% more than static for a prop with a P/D ratio of 1.1. The X-axis of the Advance Curves represent airspeed. Pitch Speed (RPM X Pitch) occurs at an Advance Ratio equal to the P/D ratio. Cp is the Power Coefficient which would be proportional to current for a constant RPM. In real life the RPM and Pitch Speed would increase because of unloading resulting from the lower current drain. |
Joined Jan 2004
This theory, of unloading based on props is strange. So if we static test a setup and are getting 95% effieciancy and then fly it we could get it to go better than 100%..
I dont know, I think this thread is more relevant and was more to do with how effiecent a motor is designed versus prop diameters. The less eff, the higher it could unload. the more eff, less unloading. all the experts weigh in here very interesting......... http://www.rcgroups.com/forums/showthread.php?t=662235 |
Joined Jan 2004
Read the link it ends up boiling down to an electric motors design and how effiecient it consumes energy as a constant resistance. Unlike like a fire breathing slimmer........
If a super effieceint motor/prop combo where to unload at significant values based on a prop/air/angles/attitudes etc it would turn into a generator to produce power , that aint happen as of yet........ |
Speaking from personal experience...
It all depends on the setup. It's hard to make a mathematical model. I have seen one setup unload more than 100% in the air. It was a 16x10 prop on an axi outrunner which drew close to 60 amps on the ground and less than 30 in the air on a slick pattern ship with a ground speed of about 60mph. That's an extreme case.. But most ofthe time I've sen about 20% decrease. |
| Thread Tools | |
| Help! Current drawn by Motor | Vinodh_aero | Power Systems | 6 | May 11, 2009 07:59 AM |
| Question How to measure how much current charger is pulling? | zaskarkid | Batteries and Chargers | 6 | May 08, 2008 10:31 PM |
| Unicorn Wing Prop & Current Drawn | Efilcon | Foamies (Kits) | 1 | Jul 06, 2003 08:27 AM |
| Problem on EPS 400C Vs EPS 300C for Slow Stick?? Amount of Current Drawn... | eta | Parkflyers | 1 | Feb 23, 2003 09:24 AM |
| Max Current drawn vs. delivered? | Martin Hunter | Power Systems | 18 | Oct 30, 2002 01:31 PM |
