Australia, QLD, Redland Bay
Joined Oct 2006
Launch preset and throwing peg
I have a launch preset setup on mine. 6% up when the launch button is pressed on my TX. Helps A LOT to transfer your launch power instead of trying to launch it at a higher angle without the launch preset. I now just press the launch preset button on my TX and launch between the horizon and 45°, then release the button when the bird pitches straight up to the sky, and away it goes.
Here's a video demonstrating launches with a launch preset and also using a throwing peg on the wingtip:
(This is a cross-post from the Alula Teaser thread. My apologies to the OP if that's frowned upon, but figured it might be useful to those that don't follow that thread) |
Before the peg, I installed the 3x1mm carbon strip "spar" that spans from wingtip to wingtip and goes through the original wing attachment tubes: - I simply cut a slit deep enough for that strip - Made small holes in the pod so the strip goes right through it. - Used CA to glue the strip into the slit I cut. - Epoxied the wing tubes to the new carbon strip using an epoxy mix with a healthy amount of microbaloons so the resin is lighter and has more flex than just pure. See the photos. For the peg, it was pretty easy: 1.- I made a small hole through the wingtip close to the original wing spar and new carbon spar. 2.- using that new hole, I roughly measured the smallest length of CF tube peg my fingers could be comfortable with, and cut it with a dremel. 3.- I epoxied the peg into place making sure it's straight (could have used CA instead of epoxy in this step). 4.- Once that dried, I then cut out 2 oval patches of very light fiberglass cloth and started at the bottom of the wing. 5.- Made a hole in the FG cloth a bit off center so the peg can go through the cloth and the larger part of the cloth can sit inwards to anchor the peg down to the CF spars. 6.- Used 30 minute epoxy (warmed up for about 3 or 4 seconds in the microwave to thin it out) to wet out the fiberglass using my finger (with a rubber glove on). 7.- Spread the resin as much as possible making sure all fibers were wet and as little resin as possible is used making sure to leave a fillet of resin on the base of the peg. 8.- Tried to blot out any excess epoxy with a paper towel, but by that point not much was picked up because epoxy was already curing. (cures faster when thinned out in the microwave) 9.- For the top of the wing repeated steps 5 through 8 with a new batch of resin and using the other piece of FG cloth from step 4. Hope that helps. It's actually simpler than it sounds with all these steps. Just wanted to make sure all details are captured here.
Before getting the glove and after throwing using the peg for a while bare handed, I've had raw and swollen fingertips (index and middle), and a day or two afterwards, I've gotten blood clots that look like little brown birthmarks inside my fingertips. Definitely more comfortable throwing with a glove when you use a peg. One thing I ave to say about wearing a glove is that it does take some getting used to holding the TX stick, but you quickly adjust. I'm thinking of trying out a golf glove next. It might have a more direct feel when operating the TX. I guess I'll take my TX to the store and try one out. The single glove cost me $7 at Sports Authority BTW. |
Lake Elsinore, California, United States
Joined Aug 2003
Nice launches!
One thing about having a peg/blade on the Alula is that you can put more power into the launch. I always thought the Alula's weakspot is here (your pic, eosglider): http://www.rcgroups.com/forums/attac...mentid=4915863 Without reinforcement, I've ripped that nose cleanly off the Alula. And I'm pretty easy on my planes. Jun Quote:
Thanks Jun! That means a lot coming from you. Anything you can see in my technique to improve on? Reason I ask is I also launch my Taboo GT in the same exact way. Any criticism is appreciated. My wife thinks I launch with a "ballerina step", but what does she know.
![]() Quote:
Probably a good idea to check that the elevons are in fact moving up when you pull the flap switch down....don't want to throw it hard into the ground on the first launch. Just set the number to something much higher, like "up 20", so you can see them move when you move the stick. Just be sure to put it back to 3 before you throw! |
I find throwing the alula so very complimentary to what I usually fly - which is mostly homebuilt tricopters that are completely dependant on onboard computers requiring lots of tweaking. Today I had to quit only because my arm felt tired and the CF-tube in the wing began to get loose. Love it. |
| Thread Tools | |
| Discussion Dream-Flight dealers in So. Calif. | fourxguy | Slope | 3 | Sep 27, 2009 04:24 PM |
| Found Dream Flight Alula | let1fly | Aircraft - Sailplanes (FS/W) | 1 | Dec 21, 2008 04:30 PM |
| Dream flight Alula? Electrified maybe?! | bigandy | Hand Launch | 6 | Jun 12, 2005 02:48 AM |
