Old Feb 18, 2011, 03:55 AM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
wowow you can do loops :P that is way far for me but I can make my planes do loops, rolls, wingovers......... LOL
EZ
Edwinzea is offline Find More Posts by Edwinzea
Old Feb 21, 2011, 09:25 PM
jzanutto is online now
Find More Posts by jzanutto
AMA 73386
jzanutto's Avatar
Fresno, CA
Joined May 2005
Originally Posted by sky_surfer_fra View Post
Great design! How did you do it?
there is a picture of a red tail hawk that we copied
jzanutto is online now Find More Posts by jzanutto
Old Feb 23, 2011, 07:18 PM
AMA 73386
jzanutto's Avatar
Fresno, CA
Joined May 2005
got 90 mins in on our local slope with the alula. on my first flight I had the CG set so it just balanced on the 2 balance dimples below the fuselage. It was too pitchy, almost uncontrollable. So I added another ounce up front, its perfect now.
Our slope has a lot of rotor, its a step slope and sometimes down low close to the slope you get hammered pretty good. I have the controls set up for a lot of throw. I just use a little control while flying normally, but definitely need it for recovery from the rotor.
a couple of hawks came by but they didnt give it a second look
Old Feb 23, 2011, 09:24 PM
acmeair is offline
Find More Posts by acmeair
so cal
Joined Oct 2003
first flights
tried first flights side arm lanch very easy but i was getting a porpus type glide
small bumps up and down, i am open for suggestions
thanks charles
acmeair is offline Find More Posts by acmeair
Old Feb 23, 2011, 09:42 PM
thumbhead is offline
Find More Posts by thumbhead
altitude adjustment
thumbhead's Avatar
USA, CA, Irvine
Joined Mar 2005
Porpoising usually means it's nose heavy. Or too much elevator throw.
mark
thumbhead is offline Find More Posts by thumbhead
Old Feb 23, 2011, 10:09 PM
acmeair is offline
so cal
Joined Oct 2003
thanks mark, i fly every morning 7-8 at fairview park in cm. i will get one of the guys to program my dx7 i need to cut the elevator way down. years ago i had a redherring and a highteck tx with mod for that.
charles
Old Feb 23, 2011, 11:49 PM
AMA 73386
jzanutto's Avatar
Fresno, CA
Joined May 2005
how does the nose hang when you prop it up on the balance points?
Old Feb 24, 2011, 12:37 AM
7rider is offline
Find More Posts by 7rider
7rider's Avatar
USA, CA, Mountain View
Joined Dec 2007
Here's the pod set up I have for my Alula:
OrangeRX receiver with case removed.
PLD-BAC-004 http://nqrc.com/?vp=PLD-BAC-004
2S 280 LIPO also from NQRC (doesn't look like they carry these lipos anymore)
I had to attach three 7g lead weights to the battery to get correct CG.
I shouldn't have made the suggested cutout for the belly covering since as you can see from the photo, the belly has to be cut further forward for me to access the charge and balance plug for the Lipo battery.
Weight came out to 6 oz. Still trying to get CG dialed. The Alula tends to loop if I throw it at too steep of an angle. Tried to slope it earlier today, but the winds were too strong where I went (15 mph with gusts).
7rider is offline Find More Posts by 7rider
Old Feb 24, 2011, 07:17 AM
acmeair is offline
so cal
Joined Oct 2003
the plane is balanceing right on the marks
charles
Old Feb 24, 2011, 07:39 PM
AMA 73386
jzanutto's Avatar
Fresno, CA
Joined May 2005
doesnt sound nose heavy. you sure you werent a little slow on the airspeed?
When mine was balanced so it hung "flat" on the points it was too pitchy, would loop when thrown like the previous post mentioned. Thats tail heavy.
when I added just a little more lead up next to the battery it smoothed out. I can throw it and it climbs straight up without wanting to pitch up or down.
It will hover in one spot without porpoising. But when I got too slow it did porpoise some
Old Feb 24, 2011, 09:09 PM
acmeair is offline
so cal
Joined Oct 2003
i finely figured how to cut the elevater throw down and ill try it to morrow
i played with it to day and almost screwed myself into the ground i am 73 and will be using a bunje soon
charles
Old Feb 24, 2011, 10:32 PM
AMA 73386
jzanutto's Avatar
Fresno, CA
Joined May 2005
or just set up some differential throw to desensitize around center stick. I need the travel because there is BAD rotor on our hill and I need it to stay in control
Old Feb 26, 2011, 05:06 PM
Ron Williams is offline
Find More Posts by Ron Williams
slow but inefficient
Ron Williams's Avatar
Riverhead NY USA
Joined Dec 2000
Another Alula
Just finished my first Alula. It's the plane in the middle in case you're wondering.
Ron Williams is offline Find More Posts by Ron Williams
Old Feb 26, 2011, 07:12 PM
AMA 73386
jzanutto's Avatar
Fresno, CA
Joined May 2005
good job Ron. got a few flights in today, but the wind was blowing parallel to the slope and it was kinda weak
Old Feb 28, 2011, 01:14 AM
rockyabq is online now
Find More Posts by rockyabq
Envies his own avatar
rockyabq's Avatar
Albuquerque, NM
Joined Apr 2008
Ron,
Gorgeous! What type of paint or marker did you use?
rockyabq is online now Find More Posts by rockyabq
Discussion Dream-Flight dealers in So. Calif. fourxguy Slope 3 Sep 27, 2009 04:24 PM
Found Dream Flight Alula let1fly Aircraft - Sailplanes (FS/W) 1 Dec 21, 2008 04:30 PM
Dream flight Alula? Electrified maybe?! bigandy Hand Launch 6 Jun 12, 2005 02:48 AM
