Old Feb 10, 2011, 06:47 AM
wijwoj is online now
Find More Posts by wijwoj
wijwoj's Avatar
United Kingdom, England, London
Joined May 2007
I've not glued mine in, and the blenderm tape has held them rock solid. I'm probably not throwing as hard as some, but it has taken a few *rough* landings in it's stride.
wijwoj is online now Find More Posts by wijwoj
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
hehehe sorry maybe I read to fast and my brain included the "glue" give a heads up to michael so he can correct the document. mmm maybe you are reading the section for the deatachable wings??? just doubble check
cheers and enjoy your Alula
EZ
Edwinzea is offline Find More Posts by Edwinzea
Old Feb 10, 2011, 07:28 AM
mdennis is offline
Find More Posts by mdennis
More Pile-it than Pilot
mdennis's Avatar
Shawnee, Kansas
Joined Nov 2002
Mine are glued on with a thin layer of Goop, (obviously not removable for transport ) I didn't put any tape over the joint. It's held up to thousands of launches and more than a few bad landings.
Mark
mdennis is offline Find More Posts by mdennis
Old Feb 10, 2011, 03:01 PM
Harrow is offline
Find More Posts by Harrow
Yes, I know it's upside down.
Sydney, Australia
Joined Dec 2008
Thanks guys, looks like I can go either way, and I'll shoot Micheal an email to see if it was an omission. 5 gram servos work okay?
Harrow is offline Find More Posts by Harrow
Old Feb 11, 2011, 03:40 AM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
5g are OK just make sure that they are straight mine are a bit twisted and make a buzzing noise all the time :P
EZ
Old Feb 11, 2011, 07:40 AM
mdennis is offline
mdennis's Avatar
Shawnee, Kansas
Joined Nov 2002
Make sure that your control surfaces move easily. You might need to bend them over and gently sand on the inside of the foam hinge if it is too thick.
If the hinge is too thick, the surface does not want to move easily. The control surface also will want to twist as it moves, so that it deflects more where the control horn connects than it does on the outside edge. Since it does not take much movement to make this plane turn that might not be a bad thing, but it will be hard on your servos and one side might twist more than the other.
Mark
Old Feb 11, 2011, 08:47 AM
knutb is offline
Find More Posts by knutb
Joined Nov 2008
Another thing when it comes to servos and control surfaces: To get as much leverage as possible, set up the controlhorns and servohorns to obtain mechanically as much throw as you need, but not (much) more. Eg. if you need 10mm throw, set up your link to get 10mm throw with the servo at (near) 100% deflection. If you instead set your links to obtain max 20mm, and then electronically limit it to 10mm, you end up with the same throw but less torque. Using long servo horns and/or short control horns gives large throws, but requires more torque, meaning that the servo works harder.
Setting up heaps of throw mechanically, and then adjust down on the transmitter may be convenient, but doesn't utilize the servos optimally.
knutb is offline Find More Posts by knutb
Old Feb 14, 2011, 09:48 PM
jzanutto is offline
Find More Posts by jzanutto
AMA 73386
jzanutto's Avatar
Fresno, CA
Joined May 2005
mine is ready to go, just waiting on a battery pack
jzanutto is offline Find More Posts by jzanutto
Old Feb 14, 2011, 10:19 PM
7rider is offline
Find More Posts by 7rider
7rider's Avatar
USA, CA, Mountain View
Joined Dec 2007
jzanutto, regarding your artwork: "We're not worthy!"
Just received mine today. I'm looking forward to the build and maiden.
7rider is offline Find More Posts by 7rider
Old Feb 14, 2011, 11:51 PM
jzanutto is offline
AMA 73386
jzanutto's Avatar
Fresno, CA
Joined May 2005
hey actually I had my daughter do it. I bought some wide tip permanent markers from a local art store.
I'm just waiting for the 1/3aa battery pack from a place in northern CA.
they sell two for 9.99. they are 300mah
my hitec 2.4g RX was a little long, and I had to dig out some extra foam to get it to set down into the rx slot. Where I fly there are a lot of hawks. Hope I dont get attacked!
Old Feb 15, 2011, 12:01 AM
Harrow is offline
Sydney, Australia
Joined Dec 2008
Believe it or not, as soon as I saw your photo, I decided to hand mine over to my daughter who is also quite handy with her art work, LOL.
Old Feb 15, 2011, 11:02 PM
mangtronix is offline
Find More Posts by mangtronix
USA, CA, San Francisco
Joined Dec 2008
Let us know how it goes. Hawks can be kind of territorial
mangtronix is offline Find More Posts by mangtronix
Old Feb 16, 2011, 02:12 AM
sky_surfer_fra is offline
Find More Posts by sky_surfer_fra
Always looking for lift...
sky_surfer_fra's Avatar
Germany, HE, Offenbach
Joined Oct 2003
Great design! How did you do it?
sky_surfer_fra is offline Find More Posts by sky_surfer_fra
Old Feb 16, 2011, 02:19 AM
Harrow is offline
Sydney, Australia
Joined Dec 2008
There's a couple where I fly. They just don't seem to be able to do a loop as tight as I can.
Old Feb 17, 2011, 10:27 PM
Joined Dec 2008
Yeah I've used that move too
Discussion Dream-Flight dealers in So. Calif. fourxguy Slope 3 Sep 27, 2009 05:24 PM
Found Dream Flight Alula let1fly Aircraft - Sailplanes (FS/W) 1 Dec 21, 2008 05:30 PM
Dream flight Alula? Electrified maybe?! bigandy Hand Launch 6 Jun 12, 2005 03:48 AM
