Old Nov 08, 2010, 05:55 AM
mdennis is offline
Find More Posts by mdennis
More Pile-it than Pilot
mdennis's Avatar
Shawnee, Kansas
Joined Nov 2002
[QUOTE=xan;16421934] Has anyone here successfully used an onboard mixer on the Alula? I found a few online which were pretty small and light, and even found one lying around at home from a crashed-abandoned model we found, but without instructions etc. I'm not sure how to adjust it etc. for the throws the Alula needs. A mixer would be great as he could just use his existing radio.QUOTE]
I have never used a mixer on an Alula, but I have used them in the past on other models. It should work fine.
If you can get any info off of the mixer you can probably find instructions on the internet. Most of them work the same anyway, so any instructions you can find will give you a good start. I have never seen one that was electronically programmable, so it shouldn't be that difficult to figure out.
I would recommend hooking your battery, switch, receiver, mixer and servos up on the bench in the layout that they will go onto the plane before you install them in the plane. This way you can be sure everything works and moves the way you want. (elevator- same direction -both up or down, aileron-opposite directions -one up and one down) Mark them for location and install them that way. I do this before I install any gear in any plane. It's always better to find any problems on the bench and fix them there rather than have to take apart your plane or tear out freshly glued in components.
Mark
mdennis is offline Find More Posts by mdennis
Old Nov 09, 2010, 05:37 AM
Rusty Nail is offline
Find More Posts by Rusty Nail
Rusty
Rusty Nail's Avatar
Auckland, New Zealand
Joined Feb 2006
Most receiver mixers are useless on flying wings.
You need very little elevator and lots of aileron and these mixers give equal throw to both surfaces.
There are programmable mixers that allow any throw you like and reversing but they are expensive - compared to buying a radio with mixing on board.
http://www.flycs.co.nz/index.php?pag...mart&Itemid=55
You can also wire a potentiometer in parallel to your elevator pot to give expo on even a two channel AM set.
Rusty Nail is offline Find More Posts by Rusty Nail
Old Nov 09, 2010, 01:23 PM
flyingj is offline
Find More Posts by flyingj
Jeremy D Stott
flyingj's Avatar
Ogden, Utah
Joined Nov 2004
[QUOTE=mdennis;16496214]
Couldn't you almost buy a 72 mhz radio on ebay or somewhere with mixing for as cheap as a mixer now? He's bound to need mixing on other planes in the future.
flyingj is offline Find More Posts by flyingj
Old Nov 09, 2010, 04:04 PM
cornel4web is offline
Find More Posts by cornel4web
cornel4web's Avatar
Romania
are the Alula still on production?...still shipped? wanna order one, is it ok to buy the fly pack from their site (with servos and battery pack) ?
cornel4web is offline Find More Posts by cornel4web
Old Nov 09, 2010, 04:56 PM
mangtronix is offline
Find More Posts by mangtronix
USA, CA, San Francisco
Joined Dec 2008
Yep still going strong, and the ship time is nice and short right now.
http://www.dream-flight.com/alula.html
I bought the flight pack with battery and servos and have been happy. Buy some extra gear sets. I stripped two sets early on while learning to fly but haven't since then. Some people go with a larger battery pack since you will otherwise end up putting dead weight in the nose.
mangtronix is offline Find More Posts by mangtronix
Old Nov 10, 2010, 02:38 AM
Bakkie is offline
Find More Posts by Bakkie
I think I'm Mode 2
Bakkie's Avatar
South Africa, Eastern Cape, Port Elizabeth
Joined Sep 2010
Yip!!! Alula's and Weasel's are being shipped to South Africa all the time
If not the servo's get the batteries with your order they are small and fit 100%
Bakkie is offline Find More Posts by Bakkie
Old Nov 10, 2010, 01:20 PM
cornel4web's Avatar
Romania
how much weight you put in alula nose for the right ballance?...what other bttery are you using?...I plan of using some small 2s lipo...with an FrSky 2.4 small receiver...
Old Nov 10, 2010, 01:24 PM
Bakkie is offline
I think I'm Mode 2
Bakkie's Avatar
Joined Sep 2010
I have 4 x AAA rechargebles in the nose with a spektrum parkflyer 2.4.
There are 2 dimples under the wing which is where the CG must be. My flies better a little nose heavy.
Old Nov 10, 2010, 02:38 PM
lebenj is offline
Find More Posts by lebenj
flying is not a dream
lebenj's Avatar
Spain, CT, Cardedeu
i use a 2S 360mah RHINO with AR6100 and a 5V regulador,
and i still need few grams in the noise!
lebenj is offline Find More Posts by lebenj
Old Nov 10, 2010, 03:05 PM
flyingj is offline
Jeremy D Stott
flyingj's Avatar
Ogden, Utah
Joined Nov 2004
I use a 1s2p 500 lipo (3.7v 1000 mah) with Assan RX and single cell lipo blue bird servos. It runs forever and the total weight balanced is 5.55 oz.
Old Nov 10, 2010, 11:39 PM
cornel4web's Avatar
Romania
are those Blue-Bird BMS-306BB working if I intend to use only one cell Lipo 1s ?
Old Nov 11, 2010, 01:24 AM
flyingj is offline
Jeremy D Stott
flyingj's Avatar
Ogden, Utah
Joined Nov 2004
Just checked hobbyking.com
They are these single cell servos. They work great and are super smooth for this plane. I thought they'd be to small but no problems at all.
http://www.hobbyking.com/hobbyking/s...idProduct=9903
Old Nov 12, 2010, 08:29 AM
spadforme is offline
Find More Posts by spadforme
FOAMYHOLIC
spadforme's Avatar
Weatherford, Texas
Joined Jul 2003
Finally got mine done. AUW is 5.9 oz. I went with CR2 batterys, Hitec HS-45's, top drive servo mod, installed carbon throwing blade, and paint. I had to add almost a 1/2 oz of nose weight to get it to balance on the dimples. I am going to maiden and slope it this weekend, after dialing it in of course. The hardest part of this build was laying out the color scheme. Its kinda hard to tell from the pictures but the orange is florescent.
spadforme is offline Find More Posts by spadforme
Old Nov 12, 2010, 08:26 PM
cornel4web's Avatar
Romania
wow...nice...I also ordered mine...:P
Old Dec 01, 2010, 09:43 PM
Joffa_Dan is offline
Find More Posts by Joffa_Dan
Crash land!
Joffa_Dan's Avatar
Geelong Vic, Australia
Joined Sep 2009
Had a nice flight with my new Alula last night.
I'm new to slope and have spent most of my stick time messing with AP/AV. Inspired by some vids I've seen on this forum I decided to make a hat cam and try to get some video of me flying.
The hat cam was a complete failure (wrong angle) and I managed to get around 5 seconds of decent footage, the GoPro behind me caught most of the action but it's a bit too far away I think.
Oh well, I'm planning on making some more vids over teh summer so at least I'll learn from my mistakes. Think I'll swap the cams and have the GoPro on the hat and my other cam behind me.
Here tis
http://www.youtube.com/watch?v=2CMkIZr64bU
Joffa_Dan is offline Find More Posts by Joffa_Dan
Discussion Dream-Flight dealers in So. Calif. fourxguy Slope 3 Sep 27, 2009 04:24 PM
Found Dream Flight Alula let1fly Aircraft - Sailplanes (FS/W) 1 Dec 21, 2008 04:30 PM
Dream flight Alula? Electrified maybe?! bigandy Hand Launch 6 Jun 12, 2005 02:48 AM
