Old Oct 12, 2010, 08:14 AM
MichaelConnally is offline
Find More Posts by MichaelConnally
flutter!
MichaelConnally's Avatar
TX
Joined Jul 2002
Mark,
Some leaves are starting to fall.
I put the mix in to all my gliders. The amount you use will depend on radio setup and CG. It kind of works like elevator trim in a full size plane. I set up mid stick throttle for normal comfortable flying. Low throttle stick (just a bit of up elevator) is slowest flight without stalling. Forward stick (a bit of down elevator) is for faster flight, but without tucking. If set up correctly (imho) it's like flying with a throttle. Throttle back to slow down and float or throttle up to move out. It really comes in to it's own in light slope conditions. I also like it for launching. I launch at just below mid stick then about half way up I go to full "throttle)... it almost pushes over to level by itself, and it's easy to get to the throttle stick quickly right after launch. Set the mix up on a switch so you can turn it on and off and give it a try... it's free The mix on mine is almost imperceptible on the ground. It may not work with a truly neutral plane.
Launch technique...
Are most people using the thumb on top grip? What launch angle are you aiming for? My launches are consistent with thumb on bottom, but I'd like a bit more height.
MichaelConnally is offline Find More Posts by MichaelConnally
Last edited by MichaelConnally; Oct 12, 2010 at 08:19 AM. Reason: forgot something
Old Oct 12, 2010, 11:41 AM
shah2003 is offline
Find More Posts by shah2003
Joined Sep 2008
My brand new Alula!
Here's my very first Alula! Can't wait for the maiden flight after work today!! I'm new to this so I hope the picture I attached comes through!
shah2003 is offline Find More Posts by shah2003
Old Oct 12, 2010, 12:12 PM
mdennis is offline
Find More Posts by mdennis
More Pile-it than Pilot
mdennis's Avatar
Shawnee, Kansas
Joined Nov 2002
Originally Posted by MichaelConnally View Post
Mark,
So you are basically using it on the slope, not on the flatland? Sounds kind of like reflex and camber on sailplanes or flaperons.
mdennis is offline Find More Posts by mdennis
Old Oct 12, 2010, 12:35 PM
B.Welwood is online now
Find More Posts by B.Welwood
Always in the Glue
B.Welwood's Avatar
Edmonton, Alberta
Joined Oct 2003
Nice colors, good luck on the maiden.
B.Welwood is online now Find More Posts by B.Welwood
Old Oct 12, 2010, 12:51 PM
shah2003 is offline
Joined Sep 2008
Thanks!! Let's hope she returns as pretty as when she left the house!
Old Oct 12, 2010, 01:01 PM
Bakkie is offline
Find More Posts by Bakkie
I think I'm Mode 2
Bakkie's Avatar
South Africa, Eastern Cape, Port Elizabeth
Joined Sep 2010
No wind on the slope so we got the Radian to give the Alula's a lift
Parkzone Radian Piggy-Back (2 min 59 sec)
Radian FUN (2 min 56 sec)
Bakkie is offline Find More Posts by Bakkie
Old Oct 12, 2010, 01:16 PM
delperena is offline
Find More Posts by delperena
Joined Feb 2006
Most Likely on a Flatland
It does not appear to be so per his post (#806):
"My shoulder is going to hate me tomorrow, but I had a blast. I'm catching about 90% of the time..."
delperena is offline Find More Posts by delperena
Old Oct 12, 2010, 07:37 PM
shah2003 is offline
Joined Sep 2008
had a great time "maidening" my Alula.. flew real well! One slight problem, I could throw it real high, but it would go into a steep nosedive right after reaching the highest point.. after each nosedive it would recover and fly quite well.. is it nose heavy or the opposite. Any input would be greatly appreciated!
Old Oct 12, 2010, 07:47 PM
flutter!
TX
Joined Jul 2002
throttle to elevator mix
I use it almost every flight on slope or or flat land. I went up to 2% mix today... still dialing everything in. I think it adds quite a bit to the flying experience and makes launches easier/more precise.
Old Oct 12, 2010, 07:48 PM
flutter!
TX
Joined Jul 2002
You need to push the nose over at the top of your launch. If you don't it will stall and lose altitude exactly as you describe.
Old Oct 12, 2010, 08:35 PM
shah2003 is offline
Joined Sep 2008
Thanks!! I will give it a try next time..
Old Oct 13, 2010, 04:29 AM
xan is offline
xan
Find More Posts by xan
xan
UK, Peel, Peel
Joined Aug 2010
Yup, I'm still getting used to this, and getting a good transition from launch to flight is the hardest thing. It's kind of ironic (I find) that the harder you launch, the longer it takes to recover (yourself onto the stick!) and the harder to get that smooth transition to normal flight .
Perhaps try deliberately flattening out sooner than you think she needs, then work it gently later and later until you've just got it right.
There's an awesome video early in this thread of a someone launching with a perfect transition at the top, will see if I can find it!
EDIT: Here it is:
Originally Posted by BillHones View Post
Wow - forgotten what a beast of a launch that is! I doubt I'm getting 1/3 that height .
EDIT2: Think this was the "transition" video I was originally thinking of, but both are just amazing
Originally Posted by RCPC View Post
alula launch with peg.
paul
http://www.vimeo.com/9080928
Inspiration!
(I think if I threw my 'lula that hard she'd come apart at the seams )
xan is offline Find More Posts by xan
Old Oct 13, 2010, 06:40 AM
shah2003 is offline
Joined Sep 2008
Thank you for posting these videos!! Now let's see how quickly I can get to the controls before the stall! It'll be fun practicing anyway...
Old Oct 13, 2010, 05:20 PM
xan is offline
xan
xan
UK, Peel, Peel
Joined Aug 2010
Here's some footage from my first flight with my new spycam. Thanks for all the advice, I got one of the "808" model keychain spycams and I'm really pleased with it. I think it comes in at only about 15g without the chain attached and I just taped it to the top of the wing over the CG.
I hope to get out on Peel hill soon with the camera this time and hopefully see if I can get some footage of the seagulls. Last couple of times I've got up on the slope they've appeared from nowhere and soared with me for a while! Hope to maybe get a few shots of the castle from the air too, if I'm lucky!
Here you go, a cheeky lunch-break fly on some scrub land 100 yards from my office.
Alula Evo Lunchtime Flights 1 (808 spycam) (3 min 47 sec)
Old Oct 15, 2010, 06:41 AM
shah2003 is offline
Joined Sep 2008
It worked!
EDIT: Here it is:
Inspiration!
Flattening it at the highest point worked like a charm!! What an amazing plane! The best lunch break I've had in a long time!
Discussion Dream-Flight dealers in So. Calif. fourxguy Slope 3 Sep 27, 2009 04:24 PM
Found Dream Flight Alula let1fly Aircraft - Sailplanes (FS/W) 1 Dec 21, 2008 04:30 PM
Dream flight Alula? Electrified maybe?! bigandy Hand Launch 6 Jun 12, 2005 02:48 AM
