Old Dec 17, 2009, 05:40 PM
BillHones is offline
Find More Posts by BillHones
BillHones's Avatar
Sussex, NJ
Joined Oct 2009
trees: thanks for those links! i have a couple possible locations, just depends on how many trees are around. well just have to see. ill post em if they are successful!
TD: ill have to come down some time! most likely after mid january though. gonna be pretty busy.
and to all!: so im 99.9 percent done with my build. just waiting on some glue to dry in the nose. ill post some pics and more details later. i wish i had a scale! what i can say is that i have far less than 12 grams of nose weight. when i did a dry fit and places quarters on top, it took two about an inch and a half from the tip of the nose. two quarters weight roughly 12-13 grams. i did a custom lead sinker job in the very very tip of the nose. not sure how much weight i saved but its balanced, ready for trimming!
BillHones is offline Find More Posts by BillHones
Old Dec 20, 2009, 11:50 PM
schamberlin is offline
Find More Posts by schamberlin
Steve Chamberlin
schamberlin's Avatar
Bay Area, CA
Joined Oct 2009
Hi folks,
I'm getting an Alula for Christmas, along with the servo+battery package from Dream Flight. This will be my first glider. Any potential gotchas, or recommended changes/additions from stock setup? I see a lot of people reinforcing with CF and piano wire in various spots...
schamberlin is offline Find More Posts by schamberlin
Old Dec 21, 2009, 12:33 AM
trees is offline
Find More Posts by trees
Slope Sauce
trees's Avatar
White Salmon WA
Joined Oct 2009
I would advise against sanding the "nubs" off. CF reinforcement for the nose is a nice mod. Heed the instructions and tape the nose carefully and completely for nice strong support from the belly pan (and the tape). Be careful not to accidentally force the BB servos as you may strip the delicate gears.
trees is offline Find More Posts by trees
Old Dec 21, 2009, 01:09 AM
RCPC is offline
Find More Posts by RCPC
Throw it like you hate it
RCPC's Avatar
United States, CA, Castro Valley
Joined Apr 2007
Originally Posted by schamberlin View Post
Hi folks,
reinforce the sides of the pod with some carbon stringers. slice the sides of the pod with a knife maybe 1/8" deep from about an inch behind the tip of the pod, and about an inch past where the wing and pod join. push some carbon rods in the slits and hit it with thin CA.
on strong throws the pod takes a lot of abuse since it houses the battery. the carbon reinforcing while mitigate any potential failures.
cheers
paul
RCPC is offline Find More Posts by RCPC
Old Dec 21, 2009, 01:41 AM
skyboyken is offline
Find More Posts by skyboyken
I do this for fun!
Sunshine Coast, Australia
Joined Sep 2004
What RCPC said!
I stripped a bb306 last outing, for no reason I can see. As I'm no longer using the Alula on the flat I'll just put in HS-65's.
For those with less than 50secs of hang time, the biggest killers of flight time on any DLG and the Alula in particular are:
- smooth transition from climb to glide
- glide at VERY close to stall speed (in smooth air)
- absolutely minimal control inputs - NO turns unless absolutely necessary
- note that a CG slightly ahead of neutral helps a lot for minimising control inputs
I use Flight Modes with mine (because I can ). The thermal mode has lots of expo on both elevator and aileron, and is trimmed to just barely fly above stall speed. I get 45-55 secs every time unless it's turbulent.
Go Great!
Ken.
skyboyken is offline Find More Posts by skyboyken
Old Dec 21, 2009, 02:16 AM
RCPC is offline
RCPC's Avatar
Joined Apr 2007
Ken,
this should be a sticky post at the top of the HLG forum! great advice!
cheers
paul
Old Dec 21, 2009, 09:52 AM
Steve Chamberlin
Bay Area, CA
Joined Oct 2009
In an earlier thread, I saw some speculation that the skin of the foam was under tension, and that cutting into the pod to add CF would actually weaken it. What do you guys think?
Old Dec 21, 2009, 10:51 AM
Mr._Mulligan is offline
Find More Posts by Mr._Mulligan
Corona, CA
Joined Sep 2007
Perhaps it is because of my experience flying the AG series, but I usually fly pretty fast. Maybe, I'll try slowing down the flight.
Mr._Mulligan is offline Find More Posts by Mr._Mulligan
Old Dec 21, 2009, 10:52 AM
Corona, CA
Joined Sep 2007
I don't really see much of a skin on Arcel foam. I doubt this is the case.
Old Dec 21, 2009, 11:10 AM
flyingj is offline
Find More Posts by flyingj
Jeremy D Stott
flyingj's Avatar
Ogden, Utah
Joined Nov 2004
They also recommend in the instructions that sanding the mold marks off can help performance a bit.
flyingj is offline Find More Posts by flyingj
Old Dec 21, 2009, 12:18 PM
BillHones's Avatar
Sussex, NJ
Joined Oct 2009
i thought about doing so too (actually shaving them off with shaving cream and a razor) but chose not to. i think it is only a marginal gain in the flats. cant see it adding more than a second or two on average. plus if you sand to much i think the foam becomes weaker as someone noted, the "skin" holds it together a bit. also if you sand it, you limit yourself to finishing options. you can paint but with marginal coverage and with sharpies or paint pens it may take some extra extra extra time! if you sand it you may consider covering in the good'ol fashioned packing tape.
Old Dec 21, 2009, 02:04 PM
trees is offline
Slope Sauce
trees's Avatar
White Salmon WA
Joined Oct 2009
I sanded mine and regret it. The surface became very porous/fuzzy and sucked up a lot of paint. If I build another Alula in the future it will not be sanded.
Old Dec 21, 2009, 11:10 PM
BillHones's Avatar
Sussex, NJ
Joined Oct 2009
my b u i l d
so here is the shot of the nose weight i used. should have weighed it before i put it in. no scale though... ill find final flying weight eventually.
Old Dec 22, 2009, 05:40 AM
TDisaster is offline
Find More Posts by TDisaster
"See and Sea" Pro
TDisaster's Avatar
United States, MO, Knob Noster
Joined Jun 2006
Just let me know when. I'll have to go an unlock the gate for ya.
TDisaster is offline Find More Posts by TDisaster
Old Dec 22, 2009, 11:54 AM
flyingj is offline
Jeremy D Stott
flyingj's Avatar
Ogden, Utah
Joined Nov 2004
I wasn't too happy sanding mine at first, but I got 600 grit sandpaper and now there are no fuzzies. I also didn't paint mine as I wanted to keep mine as light as possible, 5.6 oz. AUW. But I could see it sucking up a lot of paint if I did. I put a few pieces of trim tape on mine for decoration, but that's it.
Discussion Dream-Flight dealers in So. Calif. fourxguy Slope 3 Sep 27, 2009 04:24 PM
Found Dream Flight Alula let1fly Aircraft - Sailplanes (FS/W) 1 Dec 21, 2008 04:30 PM
Dream flight Alula? Electrified maybe?! bigandy Hand Launch 6 Jun 12, 2005 02:48 AM
