Old Jan 17, 2010, 05:45 PM
TyFlies is online now
Find More Posts by TyFlies
And Repairs
TyFlies's Avatar
Grapevine, TX
Joined Jan 2009
How much flight time should I expect to get with the stock 300 mAh battery? Mine took a 220 mAh charge after 2 hours of hand launch. Is that normal? Charged within 2 days of flying. New batt, but something hasn't seemed right since the first charge.
TyFlies is online now Find More Posts by TyFlies
Old Jan 17, 2010, 07:29 PM
SrWade is offline
Find More Posts by SrWade
Gravity sucks
SrWade's Avatar
United States, WA, Richland
Joined Mar 2006
For a 2 servo plane I usually (conservatively) estimate about 100 maH discharge rate for active flying. So your numbers look pretty good. I would not fly more than 2.5 hours before recharging.
SrWade is offline Find More Posts by SrWade
Old Jan 17, 2010, 08:12 PM
schamberlin is offline
Find More Posts by schamberlin
Steve Chamberlin
schamberlin's Avatar
Bay Area, CA
Joined Oct 2009
still getting the hang of it
I've been flying the Alula as time permits this week, which hasn't been too often. I had a great afternoon on Thursday, played with the CG a bit, and thought I'd finally figured out how to fly the plane well. But then Saturday and Sunday, with the same setup, I was suddenly back to the same wildly oscillating flights.
This is probably just coincidence, but I always seem to do well at one nearby park, and poorly at another. I'm starting to wonder if there's something strange about the wind patterns at the second park. If nothing else, it's usually a little windier there, maybe that's part of it.
In playing with the CG, I've been surprised at how insensitive to CG the Alula seems compared to what I was expecting. I've taped a 7g weight to various spots from about 30mm forward of the dimples to 50mm backward, and while the flight characteristics change some, they all seem flyable to me. Maybe I'm so bad, I can't tell the difference between good flight behavior and bad.
One other thing I've been experimenting with is thumb-on-top vs. fingers-on-top launches. The thumb on top definitely feels more natural and comfortable to me, and that's what I've been doing up until today. But after reading a bit more, it seems like most people launch with fingers on top, so I tried that today too. I think I was getting consistently higher launches with fingers on top, but they were also closer to vertical, and they left my shoulder sore.
Here's a video of on a thumb-on-top launch at the park where I always seem to have problems. I tried to steer it around and back to myself, but totally failed.
Alula bad throw (0 min 19 sec)
Here's a second video at the same spot. This time I successfully flew the Alula back and caught it, but it was swooping around pretty wildly, which was definitely not intentional.
Alula throw and catch (0 min 19 sec)
Any suggestions on how to improve?
schamberlin is offline Find More Posts by schamberlin
Old Jan 17, 2010, 09:09 PM
SrWade is offline
Gravity sucks
SrWade's Avatar
Joined Mar 2006
You might still have more elevon travel than you need and that's causing over control which can lead to swooping and stalling. Suggest you turn them down a bit more and see what happens. Once your cg is nailed you need very little throw.
Old Jan 17, 2010, 10:09 PM
cvlex is online now
Find More Posts by cvlex
practice, practice, practice
cvlex's Avatar
Japan, Tokyo
Joined Mar 2005
My friend Takaya flew his Alula evo under 10m/s wind at slope:
笹山RCグライダークラブ/DD 2010.1.16 (2 min 44 sec)
Landing:
笹山RCグライダークラブ/DD 2010.1.16 (0 min 29 sec)
cvlex
cvlex is online now Find More Posts by cvlex
Old Jan 18, 2010, 12:23 AM
ClayH is offline
Find More Posts by ClayH
ClayH's Avatar
92840
Joined Mar 2003
To anyoe whose flown both the original and the new Evo Alula's, which plane thermals better in light lift situations? Is launch performance different?
Clay
ClayH is offline Find More Posts by ClayH
Old Jan 18, 2010, 01:24 AM
cvlex is online now
cvlex's Avatar
Japan, Tokyo
Joined Mar 2005
Clay
Although Alula evo is much better, it is very very difficult to catch thermal at flat field with Alula or Alula evo. Both are essentially for light to moderate wind slope.
Old Jan 18, 2010, 09:27 AM
Steve Chamberlin
Bay Area, CA
Joined Oct 2009
Thanks. Can you tell anything about the CG position from watching the video? I'm finding it difficult to tell when that's right.
Old Jan 18, 2010, 11:20 AM
areid is offline
Find More Posts by areid
Auckland New Zealand
Joined Aug 2007
But it can be done -- I all but specked out my Alula evo 4-5 times launching off the flat field last weekend. Admittedly it was a "boomer" day, but still pretty amazing to hand chuck a little foam plane and a couple of minutes later see it way up in the sky...
areid is offline Find More Posts by areid
Old Jan 18, 2010, 11:55 AM
BillHones is offline
Find More Posts by BillHones
BillHones's Avatar
Sussex, NJ
Joined Oct 2009
schamberlin: did you use that grip tape provided for sals? i put it on mine. helped out tremendously! also, if your cg is correct, the throws need to be very little as SrWade said. i also put in expo rates on mine so i can do some aerobatics when i please, and soar nice and gracefully any other time. there is the dive test mentioned in the manual. during a 45 degree down, the plane should not climb nor dive. each one tells whether the bird is tail or nose heavy. i forget which says which! lol. also, try throwing the bird up more. i know it seems scary as smacking the ground would be bad, but it helps so much in flight times. gradually aim higher, gaining more confidence in your throw that your not going to hit the ground.
yakhakker and all: i will post my throttle-elevator mix soon! i did not forget!
BillHones is offline Find More Posts by BillHones
Old Jan 18, 2010, 12:45 PM
SrWade is offline
Gravity sucks
SrWade's Avatar
Joined Mar 2006
From the second video, I'd say you are pretty close. The launch looked smooth, if a little flat. That might indicate that you are a tiny bit nose heavy, but not necessarily. Maybe try aiming a few degrees higher on launch so you get more height without having to use your elevator. Doing the dive test is a good way to tell, but hard to do without a good bit of altitude. Much easier to do if you are at the slope where you can make sure your trims are correct for level flight before you perform the dive.
Old Jan 18, 2010, 02:44 PM
chapped is offline
Find More Posts by chapped
Tucson, AZ
Joined Jan 2010
Well I had an interesting first weekend with my Alula! LOL
Got her built Friday night, setup the dual rates(60% aileron, 20% elevator), CG was good, etc, etc. I was going to wait until Sunday to trim her, since that's when the "group" meets up at a local school and I know a couple of guys that would help me. But... I just couldn't resist. So Saturday me and the GF go to a local school to test it out. Well, the first light overhand toss went fine, another, went fine, so I decided to give her a little side arm lauch, again, that went fine. Being this was the first wing I've flown, it became very apparent how touchy the control surfaces were, even with the dual rates. Anyways, the belly pan started coming off, no biggie, I would just add some more tape. Well that's when I realized in all my excitement, I forgot my flight box with all my goodies. So I go back home and pickup the flight box. Well then I decided to go to another school, one that was closer but not as much open space... I give it a few moderate SAL's and I'm getting around 10-15 second flight times. So then I get careless and not take into account my surroundings and the wind. I give it a pretty strong SAL and sent the Alula noticably higher. Well then the wind picked up a little and now all of a sudden, I'm fighting, trying to keep it from flying over the school building. I start panicing and end up crashing it on top of the school building. Now I'm extremely angry with myself for being so careless. I've only been flying my Alula for a few minutes and now it's gone, maybe permanently. It's Saturday, the school is closed and even when it opens on Tuesday(closed Monday for MLK), what is going to be involved in trying to get my Alula back. All this is going through my head and I'm just getting angrier and I'm to the point where I'm thinking "screw it, it's gone." Thankfully I have an awesome GF who looks on the bright side and she was able to find a couple of utility boxes on the side of the building. It was a little scary, as I haven't climbed like that in over a decade, but I was able to get on the roof and get my Alula back. No major damage, just a little bend at the nose of the belly plate. So we leave and decide to go to a different school, one that has more room. I do a couple of pretty strong launches and I'm noticing that most of the time, the Alula goes straight up and I'm having to do a loop to bring it around. So I decide to put a little down trim and see what happens. Well, I guess I gave it too much and ended up launching right into the ground, breaking the nose in half. And that's how Saturday ended. I get home, throw some Goop on the Alula and let it set overnight. Sunday morning, the nose of the Alula looks and feels strong, although a little bit crooked. Meet up with the guys and get it trimmed right and she flys great, nice and lofty. All in all, it was a great weekend, filled with a few learning experiences.
One thing I will say, I figured I was going to get at least 30 second flights in dead air but I'm lucky to get 15. I am trying to minimize input as much as possible but I launch it and am able to get it back to me just before she lands. I'm thinking it has to do with my launch. I am launching with my thumb on the top of the wing, I haven't tried with my thumb on the bottom yet. What angle do you guys launch at? I think mine is around 30 degrees or so. Do you guys have any tips for longer flights?
chapped is offline Find More Posts by chapped
Old Jan 18, 2010, 04:08 PM
BillHones's Avatar
Sussex, NJ
Joined Oct 2009
yakhakker: here are the steps to set up the throttle as an elevator trim stick on a dx6i:
i went to mix 1. set up throttle to move the elevator. thro-> elev act (what is displayed) then the rate is down +25% and up +10 percent. the rates are up to you. i probably dont need that much down. i also have throttle travel adjust set up too. down is 50% and up is 25%. my expo rates are aileron 50% and elevator 65%. aileron travel is 125% and elevator is 100%. she flies like a dream! good luck!
schamberlin: i have some videos of my launch too. they will posted sometime tonight.
Old Jan 18, 2010, 06:05 PM
jcats is online now
Find More Posts by jcats
Launch high. Fly low.
United States, CA, Lake Elsinore
Joined Aug 2003
Clay
I want an Alula, too.
Jun C.
jcats is online now Find More Posts by jcats
Old Jan 18, 2010, 06:21 PM
ajroahkni is offline
Find More Posts by ajroahkni
PWP!
ajroahkni's Avatar
USA, HI, Makawao
Joined Oct 2002
Clay
The original has a lighter wing loading and is more nimble/agile. I also feel that it launches higher. It's "flicky" while the evo's more of a "driver" if that makes sense.
One vid of the old, one of the new.
Old
"Old" Alula Action (3 min 31 sec)
New
Flock Dreams (5 min 22 sec)
John
ajroahkni is offline Find More Posts by ajroahkni
Discussion Dream-Flight dealers in So. Calif. fourxguy Slope 3 Sep 27, 2009 04:24 PM
Found Dream Flight Alula let1fly Aircraft - Sailplanes (FS/W) 1 Dec 21, 2008 04:30 PM
Dream flight Alula? Electrified maybe?! bigandy Hand Launch 6 Jun 12, 2005 02:48 AM
