Old Feb 08, 2013, 06:12 PM
dougmontgomery is offline
Find More Posts by dougmontgomery
dougmontgomery's Avatar
Glendale,Az.
I don't really mind mods to Alulas and such but that has to be the worst mod ever.
The alula is a perfect as a glider- just chuck it and catch thermals when you can.
dougmontgomery is offline Find More Posts by dougmontgomery
Old Feb 08, 2013, 07:38 PM
extremewing is online now
Find More Posts by extremewing
A different attitude to RC
extremewing's Avatar
Draper, Utah
Joined Sep 2008
I tried a small ducted fan once. It was not powerful enough, but it flew!
extremewing is online now Find More Posts by extremewing
Old Feb 11, 2013, 12:41 PM
Capt. Gary is offline
Find More Posts by Capt. Gary
Joined Nov 2010
Sergey, Uri
I found a few more setup pic’s. Guys in Germany used the JETI DUPLEX R4 EX which is about the same size/weight and probably more readily available for you. We needed as clean/light an airframe as possible for our purposes. Only anomaly or protrusion we ended up with was the top linkage, post 1703. Fairing or “fill” added 1.1 gram. Hope pic’s answer your questions? Good Luck! We ended up using Dream Flight Weasels, now N/A, but the Alulas proved it was possible.
Capt. Gary is offline Find More Posts by Capt. Gary
Old Feb 11, 2013, 01:06 PM
SpeedsterDEN is offline
Find More Posts by SpeedsterDEN
DS will change your life
SpeedsterDEN's Avatar
Danmark, Nordjylland, Sæby
Joined May 2010
Not a Alula, but Wiesel HLG
SpeedsterDEN is offline Find More Posts by SpeedsterDEN
Old Feb 12, 2013, 07:06 PM
regalmat is offline
Find More Posts by regalmat
regalmat's Avatar
Ashburn VA
Joined Feb 2010
Well I'm hooked. Finally got some decent weather to try it on Suday. It was too windy and the cg was too far forward, but I threw it till my arm just about fell off. Today, I tweaked the cg--much better. Almost hands off flight with just a little porposing. My son also tried it and I think he is hooked also. I bought this as a trainer for a Blaster 3 that I picked used, but the Alula is really more capable than I thought. Thanks for the help in this thread!
regalmat is offline Find More Posts by regalmat
Old Feb 13, 2013, 02:07 PM
Backyard is offline
Find More Posts by Backyard
Backyard's Avatar
Tresure Coast Florida
Joined Feb 2004
Nose Job
To extend the nose, increase strength and durability and place any needed weight as far forward as possible I made a plaster cast of the nose and used PlastiDip to make a strong sheath with lead shot glued inside 1/2 inch of the tip. Careful use of a non-lubricated latex baloon like product commonly found in the pharmacy provided mold release and a perfect fit on the nose. Some experimentation is still needed but this prototype definitely works as intended.
Backyard is offline Find More Posts by Backyard
Old Feb 13, 2013, 02:20 PM
Zenmaniac is offline
Find More Posts by Zenmaniac
Building with TLAR precision
Zenmaniac's Avatar
near Madison, WI
Joined Jan 2009
Interesting project. I like the use of the PlastiDip.
To be most effective, the strength reinforcement needs to extend back to the juncture of the nose and wing, since that's where most of the breaks occur.
-= Dave
Zenmaniac is offline Find More Posts by Zenmaniac
Old Feb 13, 2013, 02:52 PM
Backyard is offline
Backyard's Avatar
Joined Feb 2004
Lateral strength
Port and starboard 0.5 mm X 3 mm flat carbon rod (0.061 g/in.) inserted to wing center and glued with E6000.
Old Feb 13, 2013, 09:51 PM
JimZinVT is online now
Find More Posts by JimZinVT
let's FLY!
JimZinVT's Avatar
United States, VT, Castleton
Joined Dec 2007
Nice. One question: lubed or unlubed?
JimZinVT is online now Find More Posts by JimZinVT
Old Feb 13, 2013, 09:53 PM
Zenmaniac's Avatar
near Madison, WI
Joined Jan 2009
Re-read the posting, Jim.
-= Dave
Old Feb 13, 2013, 10:24 PM
let's FLY!
JimZinVT's Avatar
Joined Dec 2007
noted.
Old Feb 14, 2013, 08:55 AM
Backyard is offline
Backyard's Avatar
Joined Feb 2004
...and size does not matter. By the way, happy Valentines Day.
Old Feb 16, 2013, 08:28 AM
arthur0903 is online now
Find More Posts by arthur0903
arthur0903's Avatar
Taiwan
Joined Aug 2005
E-Alula test flight.
E-Alula (0 min 56 sec)
arthur0903 is online now Find More Posts by arthur0903
Old Feb 17, 2013, 03:25 PM
Mr. Wood is offline
Find More Posts by Mr. Wood
Joined Apr 2009
What is the best way to monitor battery power when out on the slope with the small battery used on the HLG stuff? How long have you folks been able to fly before recharging. My GP sprit 2m with 600 mha will fly longer than I want. Will this 300 mah battery give me a 1/2hour?
Mr. Wood is offline Find More Posts by Mr. Wood
Old Feb 17, 2013, 04:08 PM
Zenmaniac's Avatar
near Madison, WI
Joined Jan 2009
The 300 should give you about 1.5 hrs. with some to spare. On a good day, that's not enough for me, which is why I have a 4xAAA.
My LMA has a low-battery alarm built in. It rarely goes off unless I forgot to charge!
Have fun!
Dave
Discussion Dream-Flight dealers in So. Calif. fourxguy Slope 3 Sep 27, 2009 05:24 PM
Found Dream Flight Alula let1fly Aircraft - Sailplanes (FS/W) 1 Dec 21, 2008 05:30 PM
Dream flight Alula? Electrified maybe?! bigandy Hand Launch 6 Jun 12, 2005 03:48 AM
