Hi Bill thanks again for the info, well the snow has gone for the moment and I am hoping to do some test glides before sloping off to do a contract(3 weeks away) I have come up with the same idea as you and injected some beli zell into the nose which I hope has beefed things up some. I like the idea of trim on the throttle and will try to dial that in tomorrow,spektrum7,any info would be appreciated as I am not the best with computers am impressed with the times you are getting and will be well chuffed if I can get near that cheers yak
i would like also half or quarter trim click!!!
but between 2 trim click i don't have a so much difference, it will not loop or going straight to the ground..... but when i'm fliying when i want to adjust for example the slowest speed in dead air, i meet the problem.. -> it's slow but i think it could go slower -> after trimming one clik "up" it starts going up/down up down.... in this case i would like to have an half trim click!!!! the "perfect" elevador trimmng, depence of the wind or speed you want and the CG.... so i tried in the past the gaz stick as a trim, but it's hard to always find the perfect throttle stic position between 2 throws.... 50 seconds in dead air??? WOUAAAA!!! actually in a strictly dead air, i'm 35 seconds. but my alula is 182 grams and has a very hard life..... |
Tucson, AZ
Joined Jan 2010
I just finished mine tonight! Going to go to the park in the morning and trim it. I haven't flown RC in over 15 years and I've never flown a wing, so I'm sure I'm in for a real treat!
Honestly, I hope I don't have too many problems. The CG is good, front/back and side/side. The weight is 6.25oz with everything. I have a Hitec Optic 6 and have programmed the dual rates for 20% elevator, 60% aileron. Does anyone know if I can program the "buddy" switch to do a preset trim for the launch?
NorCal
Joined Nov 2009
![]() On my JR, I can adjust the trim steps, I think default is 4 steps for each click. I can change it to 2 steps or even 1 step, but unless you use servos that have good resolution, it still may not help. I probably have too much throw setup on mine to begin with. Brian |
i think i remember someone else doing this also in the old alula teaser thread. im sure youll get times along there with mine! just need to get a good toss and level off smoothly with no stalls.
Maidened my Alula this A.M. I crunched the nose a bit, but not bad. I need to put 14 gram at the nose to balance it. This is my 1st attempt at SAL, so I still need to learn on how to launch it. I managed to circle around and 2 hand catch. This is fun!!!
The plane wiggle from side to side a little on launch..is it because I released it too late?THX |
for the moment i resolve the problem with small CG correction! |
| Thread Tools | |
| Discussion Dream-Flight dealers in So. Calif. | fourxguy | Slope | 3 | Sep 27, 2009 04:24 PM |
| Found Dream Flight Alula | let1fly | Aircraft - Sailplanes (FS/W) | 1 | Dec 21, 2008 04:30 PM |
| Dream flight Alula? Electrified maybe?! | bigandy | Hand Launch | 6 | Jun 12, 2005 02:48 AM |
