Old Dec 04, 2009, 05:45 PM
BosTom is offline
Find More Posts by BosTom
This is fun!
BosTom's Avatar
Winchester, MA
Joined Jan 2007
2.4 GHz Hitec Optic 6 + Optima Receivers
I am in the process of transitioning to 2.4 GHz. I have been using a 72 MHz Hitec Optic 6 with a Spectra module for the past 3 years and I am very happy with it. Having several planes, some will continue to fly on 72 MHz. However I want to move my newer planes to 2.4 GHz. So here are my questions:
1. What has the experience been with the 2.4 GHz Optic 6 radio with the Optima receivers?
2. Can the 2.4 GHZ Optic 6 work with other receivers? If yes, which ones?
3. What is the max range between the 2.4 GHz Optic 6 radio and the Optima receiver?
4. Are the Optima receivers good for high altitude thermal gliding?
Cheers,
Tom
BosTom is offline Find More Posts by BosTom
Old Dec 04, 2009, 06:32 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Cheers, Tom
1. Tested for some time pre-release - nothing untoward noticed.
2. Yes, currently the Optima 6,7 & 9 channel RX with a minima (smaller) to be released in due course.
Otherwise 2.4GHz is proprietary and cannot be interchanged between brands - except where same item rebadged.
3. Futher than you can see. Refer range testng and other reports from Aurora users (same Spectra Pro Module with same antenna = same range)
4. Yes, the telemetry is a great feature, with range and ease of installing the BODA antenna detailed.
Optima RX - Installation RX, BODA Antenna & Range Test Results.
see also:
Aurora A9 (Hitec) - Mixes, Setups, Tips, Undocumented Features -- includes FAQ re Spectra Pro Module and Optima receivers.
Further information under
"2.4 GHz RC Systems"
at
Alan's Hobby, Model & RC FAQ Web Links
Regards
Alan T.
A.T. is offline Find More Posts by A.T.
Old Dec 04, 2009, 08:19 PM
BosTom is offline
This is fun!
BosTom's Avatar
Winchester, MA
Joined Jan 2007
Thanks for the info. I will check out those links.
Tom
Old Dec 05, 2009, 07:16 AM
Rickochet is offline
Find More Posts by Rickochet
Card Carrying Old Fart
Rickochet's Avatar
Central Kentucky
Joined Oct 2006
Just to add something, the Optic 6 can also use the Spektrum DM8 2.4 module for Futaba. I have this as well as the Hitec 2.4 module so I can swap out the module and do 72mhz, Spektrum or Hitec 2.4.
Rick
Rickochet is offline Find More Posts by Rickochet
Old Dec 05, 2009, 12:46 PM
BosTom is offline
This is fun!
BosTom's Avatar
Winchester, MA
Joined Jan 2007
Rick - great info indeed.
I was wondering if the Hitec 2.4 could be used with the bind-and-fly planes and helis that are coming into the market. It turns out that these aircraft only support DSM2. So using the Spektrum DM8 2.4 module should take care of this issue. this is great.
Tom
Help! Where To Buy Hitec 2.4 Module For Optic 6 Rickochet Radios 8 Dec 03, 2009 04:29 PM
Sold Hitec Spectra 2.4GHz Module & 2-Optima 7Ch 2.4GHZ receivers $105 shipped flyingrandy55 Aircraft - General - Radio Equipment (FS/W) 3 Dec 02, 2009 12:56 PM
New Product Hitec TX Optic 6 2.4GHz with 2 optima 7ch RX's supi7 JR Indoor Electric Festival 0 Nov 06, 2009 07:15 PM
Discussion Anyone heard of a Hitec Optic 6 2.4 Ghz? redhotpearl Radios 3 Jun 06, 2009 08:23 AM
Help! Futaba 6ex 2.4 ghz or hitec optic 6 Noz Radios 5 Nov 11, 2007 02:04 PM
