Video up. Silent movie....both of us had camera batteries problems.
http://www.rcgroups.com/forums/showt...php?p=13831276 |
Making progress, she should be done by Christmas. I covered the butane gas tank (taken from an Accucraft 4-4-0) with pine logs. Easy to get boughs this time of year :-). The boat needed more weight forward for trim, so the weight of the logs should not be a problem. 4' logs were the standard steamboat size. You can see the cords of wood stacked for easy measurement and loading in photos of the Yukon. A boat might burn as many as 3-4 cords an hour breasting swift water, and as little as 1 cord an hour on the downstream passage. The real Goddard had a beam of 10'; she could barely load an 8'x4'x4' cord of wood on the foredeck. Even though she had a smaller boiler and engines than the boats cited above, I bet she had to make frequent wood stops on the way up from Dawson to Whitehorse.
Head of navigation, when she was launched, was actually Bennett (on Lake Bennett). Miles Canyon, between Bennett and Whitehorse, would be exciting in a kayak, hard to believe that they actually took steamboats thru it. A.J.Goddard must have gone thru at least once, as she was assembled on Lake Bennett. When steamboats went downstream, they'd point downstream, naturally, but run the paddle in reverse. This slowed the boat, and perhaps even more importantly, pushed fast water over the rudders. Since the rudders were located ahead of the sternwheel, they were more effective when the paddle was running in reverse. To assist forward steering, monkey rudders were developed later - they hung off the paddle beam spreader bar,aft of the paddle, and worked in fast water slung by the paddle when it was running in forward. A tramway was constructed to skirt the worst of the canyon, but prior to that, some boats did traverse the canyon, up and down. A railroad was constructed in 1900 from Bennett to Whitehorse, allowing boats to skip Lake Bennett, Miles Canyon, and Whitehorse rapids. After the RR, the normal upper river trip was between Dawson and Whitehorse. The lower river trip was between St. Michael, at the mouth of the Yukon, and Dawson. It took 120 cords of wood to go from St. Michael to Dawson. In some places on the Dawson-Whitehorse route, eg. 5 Finger Rapids, there was a line strung from upstream down through the favored channel. A upstream bound steamboat would pickup the line, and winch it's way through the passage. That's why the A.J. Goddard had such a large winch forward, for traversing rapids, not because she needed to haul an anchor (unlike the Nat. Geographic commentary). The photos are from "Yukon river steamboats, a pictorial history" by Stan Cohen. I'm also including a photo of the boiler&burner system. The galvanized mesh works well as a boiler wrapper for potboiler firing. But you need to do the first few firings in adequate ventilation, because part of the galvanizing oxidizes when first heated. The windscreen is aluminum flashing, with a ceramic insulation blanket (McMaster-Carr). The insulation increases burner effectiveness, and also protects hands that might touch the windscreen while loading Army men :-).
A nice Yukon steamboat website, by Parks Canada. Unfortunately, neither John nor I can get the flash videos to play - one is lining thu rapids, the other is launching a ship, sideways, in springtime.
http://www.pc.gc.ca/lhn-nhs/yt/ssklo...l/natcul5.aspx |
You can't get them to run because they screwed up their links. I had to wade through the French HTML to get a chance to guess at where they goofed. I guessed correctly (it was just an educated guess folks). Try this:
Spring Launch: http://www.pc.gc.ca/lhn-nhs/yt/ssklo...cul/video1.swf Lining Rink Rapids: http://www.pc.gc.ca/lhn-nhs/yt/ssklo...cul/video4.swf Paddle Wheel shots: http://www.pc.gc.ca/lhn-nhs/yt/ssklo...cul/video2.swf Massive amounts of Wood to burn: http://www.pc.gc.ca/lhn-nhs/yt/ssklo...cul/video3.swf I'd love to get ahold of the original footage, set it to music and do something of a "Silent Movie" style interleave with information and made up quotes... would be fun. |
Doug Davidge looking for information
I wrote Doug Davidge, discoverer of the A.J.Goddard wreck. Here's his reply:
"Hi Brooks, Thanks for your note. You have done an excellent job on the steam powered Goddard replica. I like the idea of building a scale model of the Goddard. I noticed on your web link an old photo of the "Rose"...it looks very similar to the Goddard. Coincidentally, Mr. Goddard - the man who built the steamer here in the Yukon - came from Iowa originally. We are trying to track down any information on the builders of such vessels, where they originated from and if there are any examples of these boats still surviving. Any help you can provide would be appreciated. All we know is that Mr. Goddard brought the "A.J. Goddard" and the F.H. Kilbourne" up from San Francisco but that is all we know. The photo of the Rose shows that this type of small steamer was used elsewhere so there must be more photos out there somewhere. I found this on the web recently: http://stanleysteamers.com/steamboat...steamin-sm.JPG A nearly identical replica of the Goddard. The Goddard had a little more free board than this vessel but you can see why it would not do very well in heavy seas. Take care, Doug Davidge" The url for a series of photos of the modern steamboat Doug mentions above. http://www.stanleysteamers.com/b&w_2006.htm |
| Thread Tools | |
| Off Site Live Steam Pop Pop Boats. a lot of 19 boats! | 1987tc | Boats (FS/W) | 0 | Nov 08, 2009 05:16 PM |
| Idea Live Steam | tdonily | Dock Talk | 17 | Feb 03, 2005 03:30 PM |
