Old Dec 04, 2009, 12:17 PM
shifteroo is offline
Find More Posts by shifteroo
Joined Oct 2009
Question
2.4 Ghz Technology based on..?
Just out of interest, with all the new 2.4Ghz RC systems, are they loosely based on any 802 protocols, (802.11 WLAN / 802.15 WPAN) or are the systems completely proprietary to each manufacturer?
I'm mostly interested in the hardware behind it, and have been assuming it might be built on top of 802.15.4 lower layers as they'd be perfect for the task i.e. low bandwidth (not much needed to send a few servo position bytes) and low-power consumption and can have very good range.
Don't imagine Spektrum and Futaba tell any old tom dick or harry about the specifics of their designs but if anyone can clear this up for me I'd appreciate it,
Cheers,
shifteroo is offline Find More Posts by shifteroo
Old Dec 04, 2009, 12:22 PM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Hi!
There are some systems based on the ZigBit protocol (xps, Jeti), but most of the system have nothing in common, be it bandwidth, data rate, FHSS or not, number of channels used simultaneously, etc.
Julez is offline Find More Posts by Julez
Old Dec 04, 2009, 02:03 PM
darkith is offline
Find More Posts by darkith
Canada, NB, Fredericton
Joined May 2002
Most of the other 2.4ghz systems (other than Jeti & XPS) are one-way transmissions...so they don't need the overhead of a link layer/protocol stack. So, they've basically written their own simplex protocols and defined their own signal properties (w.r.t. spread spectrum, channels, and bandwidths) within the limitations of the chipsets their each using.
D.
darkith is offline Find More Posts by darkith
Old Dec 04, 2009, 05:13 PM
Andrew McGregor is offline
Find More Posts by Andrew McGregor
Christchurch, New Zealand
Joined Jun 2006
XPS use 802.15.4 radios, but with their own custom protocol. Spektrum use Cypress wireless USB chipsets, with their own custom protocol and much more power on the transmitters. Futaba went full-custom, and built their own chips. The others I don't know, but it wouldn't be surprising if many of them are using radio chips made for 802.15.4.
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old Dec 05, 2009, 02:47 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Jeti uses the premade ZigAmp transmitter module in their modules.
Old Dec 05, 2009, 02:56 PM
teamdavey is offline
Find More Posts by teamdavey
Sunnyvale, CA, USA
Joined Apr 2000
"XPS use 802.15.4 radios, but with their own custom protocol."
Andrew, have you personally confirmed that there is anything unique going on there - not pushing you just interested.
teamdavey is offline Find More Posts by teamdavey
Old Dec 05, 2009, 04:39 PM
12ten is offline
Find More Posts by 12ten
United States, IN, Indianapolis
Joined Aug 2007
An Introduction to Spread-Spectrum Communications
http://www.maxim-ic.com/appnotes.cfm/an_pk/1890
12ten is offline Find More Posts by 12ten
Old Dec 05, 2009, 04:46 PM
XJet is offline
Find More Posts by XJet
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
Bzzt. Wrong.
Protocol analysis shows that the XPS systems used stock standard protocols. The latest versions may move away from that but the originals were not a custom protocol at all.
XJet is offline Find More Posts by XJet
Old Dec 05, 2009, 04:49 PM
Joined Jun 2006
Jim Drew is on record on this site saying they did something to the firmware.
Now maybe that was just tweaking for latency, rather than protocol changes, but they did do something; their modules are XBee hardware, but with firmware changes.
Or at least, that's what Jim said.
Old Dec 05, 2009, 05:01 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
We definitely have never used the stock 802.15.4 protocols. In fact, the XBEE modules have to be put into pure 802.15.4 compatibility mode if you want to use them on a normal 802.15.4 network, and we don't do that. Also, our backoff exponent and other features are not the same as true 802.15.4.
802.15.4 protocol has been used in everything from water control systems to hospital inter-communications. This technology predates 2.4GHz for R/C, so it has a long history of success in numerous other industries.
JimDrew is offline Find More Posts by JimDrew
Old Dec 05, 2009, 05:50 PM
Joined Jun 2006
Ah, here's Jim
Yep, protocols are more than just frame formats.
Old Dec 06, 2009, 04:19 PM
Sunnyvale, CA, USA
Joined Apr 2000
Hmmmm
Discussion HK 2.4 GHz radio 6ch stuck on T6 config software mrk Radios 5 Jan 21, 2010 07:13 PM
Discussion 2.4 Ghz technology? kyle7119 Radios 5 Sep 24, 2009 11:43 AM
Sold FS E-flight LP5DSM TX LIKE NEW 2.4 GHZ w/Spektrum Technology ov10mech Aircraft - General - Radio Equipment (FS/W) 0 Mar 05, 2008 09:22 PM
Discussion 2.4 Ghz technology in Japan. seric Japan 1 Aug 05, 2007 02:28 AM
Discussion 2.4 Ghz technology limitations? khaoz Radios 5 Feb 23, 2007 03:21 PM
