Old Dec 29, 2012, 08:14 AM
Waldopepperaxe is online now
Find More Posts by Waldopepperaxe
Walk of Shame Season :)
Waldopepperaxe's Avatar
NY
Joined Jun 2008
Man that lools fantastic !!! Very nice, and yeah monocote has been bugging me since they changed their formula it works alright but a huge pain in the butt to get it perfect it use to work with ease my new favorite covering is coverite its more of a fabric covering but goes on perfect, I use ultracote now where i can instead of monocote but I thin ultracote isn't as strong and you have to use a lower heat setting as it over shrinks. You'll find your favorite type as you try different things like anything people like what works best for them.
Great job and yes the finish line is in sight
Waldopepperaxe is online now Find More Posts by Waldopepperaxe
Old Dec 29, 2012, 01:21 PM
3DNater is offline
Find More Posts by 3DNater
3d NOOBular
3DNater's Avatar
United States, NV, Las Vegas
Joined Aug 2010
I think it looks great and I would have no trouble at all seeing it for orientation. I like ultracote as well but waldo is right... you have to use a really low heat setting. It shrinks at an unmanageable rate when the heat is higher. Reading on hangar 9's website about it you find that they use very low heat to activate the adhesive and then turn up the heat afterward to shrink the areas that need tightening up.
3DNater is offline Find More Posts by 3DNater
Old Jan 07, 2013, 09:21 AM
Mohan Sharma is offline
Find More Posts by Mohan Sharma
Joined Apr 2012
hello all,
i want to make this model in 58 inch wing span from coro ( expected AUW 2500-2700 gms ) and wants to put OS .46 glow engine , pl suggest , that power setup is ok ?
Regards
Mohan
Mohan Sharma is offline Find More Posts by Mohan Sharma
Old Jan 07, 2013, 01:56 PM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
I think you may want a larger engine for that size.
The 48 incher is the 40 size.
kerwin50 is offline Find More Posts by kerwin50
Old Jan 07, 2013, 05:34 PM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
I could be completely wrong... but I think he is hoping to be able to build it lighter using coroplast. Is that what you meant by coro?
Old Jan 07, 2013, 09:21 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
It'll be interesting to see for sure.
One thing in mind is the drag induced by that thick blunt wing.
If you do please post the build.
Old Jan 07, 2013, 10:18 PM
NY
Joined Jun 2008
Howdy Mohan and it all depends on what your looking to do with the plane, 3D, fun fly etc... But as mentioned most of us are using a 61 on the 48" wing and that's the 40 sized version a 91 has been used on the 60 sized versions but if you think it will be light enough to do what you want with the 46 by all means give her a try if anything the people involved with this bird have tried just about everything under the sun with this bird so you have all the help you could ever imagine here, I think you'd be the very first that we have ever heard of to try it with coroplast, so we would really love to see your progress. Check out the thread "Twistaholics" and the "Twistaholics Mods page" also you'll love the group and we are always looking for a new twist on the twist good luck
Old Jan 08, 2013, 01:30 AM
Joined Apr 2012
Thanks to all for support and guidance.
Yes , I want to build this model from COROPLAST ( Plastic flute Sheet) , expecting AUW 2500 gms maximum for 58 inch wing span.
I can build the sharp leading edge of wing from Coro , pl suggest , which will be better blunt curved or sharp?
For 48 Inch , expected AUW is 1500- 2000 gms.
Since I have only OS .46 glow engine and expecting all fun which this model can perform , wants to make this model for 3D fun , so pl suggest the wing span for OS .46 Glow Engine.
Regards
Mohan
Old Jan 08, 2013, 06:48 PM
3DNater is offline
3d NOOBular
3DNater's Avatar
Joined Aug 2010
The stock plane will hover with that motor... barely. If yours comes in significantly lighter then it shouldn't be too big of a problem.
Old Jan 08, 2013, 07:25 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
Go with the 48 inch and enjoy.
Old Jan 13, 2013, 06:05 PM
Billytown is offline
Find More Posts by Billytown
Joined Sep 2012
Build update
[deleted]
Billytown is offline Find More Posts by Billytown
Old Jan 13, 2013, 08:43 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
Billy your making me soooo jealous.
I need to get my twist finished
Old Jan 14, 2013, 11:30 AM
NY
Joined Jun 2008
Mohan I'd say go 48" too you will love the extra power you'll have
Billy Man you did a fantastic job I can't wait to see the maiden Hopefully you'll be able to post it here for us all to enjoy.
The Saito 72 is going to be sick on this bird. Loved my OS70 4 stroke on mine as well as the 61 2 stroke
Old Jan 14, 2013, 03:51 PM
Joined Sep 2012
I fired the motor up this afternoon (in the freezing cold) to check the setup of the gas tank and throttle control and what not... So. Much. Power. Sounds great, too! I bet it'll fly over 20 minutes on that 10oz tank.
I did screw up something, though. I forgot to round off the leading edges of the fin and stabilizer/elevator. Will this have a noticeable effect on performance or handling? Seems like a little thing... but I've been in this hobby long enough to know a little thing can make a big difference.
Thoughts? Should I fix it? If so, what would be the best way now that those surfaces are epoxied? Or just forget about it?
Old Jan 14, 2013, 04:37 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
I think it'll be fine.
Discussion Guillows P-40 warhawk build log Truckerboy Scratchbuilt Indoor and Micro Models 77 Apr 20, 2012 07:55 AM
Discussion Kalteisen Katana 40 - Build Thread Brg34 3D Foamies 634 Jan 07, 2011 11:15 PM
Build Log Build Log - The World Models - SPITFIRE EP (40) djmoose Electric Warbirds 30 Jun 28, 2010 11:38 AM
Build Log Comet P-40 Build scigs30 Free Flight 47 Dec 09, 2009 09:21 AM
Question Slow Poke Sport 40 Build? modelmaster2001 The Builders Workshop 2 Oct 07, 2009 05:47 PM
