Old Jan 11, 2010, 02:41 PM
WTurbiasz is offline
Find More Posts by WTurbiasz
Tree Flyer
WTurbiasz's Avatar
Albany NY
Joined Feb 2005
you must have paper laced with Gold or something.
No but the girl was cute so Ill settle for that
WTurbiasz is offline Find More Posts by WTurbiasz
Old Jan 12, 2010, 11:02 AM
Waldopepperaxe is online now
Find More Posts by Waldopepperaxe
Walk of Shame Season :)
Waldopepperaxe's Avatar
NY
Joined Jun 2008
Elevators Items needed
you can use whats left over from the Stabilizer first on all the wood needed
1/4 x 1/4 x 36 Balsa Sticks
1/8 x 1/4 x Balsa Sticks
1/4 x 3 piece left over from the Stab Center
1/8 Elevator joiner wire about 5 5/8" long total OR 1/4" dowel about 3 1/4 - 3 1/2 long
4 CA Hinges or hinge of your choice
CA glue and Epoxy
Scrap wood,, either 1/16 or 1/32 thick or a piece of cardboard equivalent in thickness
This is a Video of the elevator build steps 1 - 3
Elevator Frame part 1.wmv (3 min 56 sec)
Waldopepperaxe is online now Find More Posts by Waldopepperaxe
Old Jan 12, 2010, 11:12 AM
NY
Joined Jun 2008
Elevator (Ele) Step 1
Pin the Stabilizer back down over your plan lining up the Center marks again
We are going to use a spacer between the Stab and Elevator to keep the elevator from rubbing or binding on the Stab after its built and wrapped. it should move freely and easy when your flying.
Using a scrap piece of 1/16 or 1/32 or a piece of cardboard as a spacer, put the spacer between the edges of the Stab and the elevator tips, then cut and pin a 1/4 x 1/4 piece of balsa up tight against the spacer to the outline on the plan.
Do this on both sides of the Stab
Old Jan 12, 2010, 11:27 AM
NY
Joined Jun 2008
Elevator Step 2
Once the 2 sides are pinned in place, remove the spacers.
Then cut to fit snug the leading edge of the elevators from one end to the other, don't make 2 halves, use 1 piece of 1/4 x 1/4 balsa stick (preferably one of the stiffer pieces of stock you have) to span the distance. pin this piece down once you know it fits nice.
Remove all the spacers
we will cut the center part connecting the elevator halves out later.
You can now remove the Stabilizer from the plan sheet
Old Jan 12, 2010, 11:35 AM
NY
Joined Jun 2008
Elevator Step 3
Frame the rest of the outside of the ele with 1/4x 1/4 sticks until the entire outside is framed
take your time and make sure everything fits snug
Old Jan 13, 2010, 10:14 AM
NY
Joined Jun 2008
Elevator Step 4
Using the left over stock 1/8 x 1/4 balsa sticks first, do the inside 4 straight braces.
This video is for steps 4- 8
Elevator Bracing.wmv (2 min 7 sec)
Old Jan 13, 2010, 10:19 AM
NY
Joined Jun 2008
Elevator Step 5
Starting on the outer tips, left and right sides, cut and place the diagonal bracing in
(the reason to do it this way is the angle of the cut you make should work on both sides.)
Then go across the bottom filling in the rest of the bracing.
Old Jan 13, 2010, 10:25 AM
NY
Joined Jun 2008
Elevator Step 6
Now lightly glue all the joints. Wipe excess glue and let dry.
Old Jan 13, 2010, 10:50 AM
NY
Joined Jun 2008
Elevator Step 7
Once dry, take out all of the pins and use your finger to hold down the plan protector or wax paper and slowly unstick the ele from the plan sheet.
We will be using the 1/4 x 3 sheet you used on the Stab Center piece to make 2 Control Horn blocks
You can either transfer the measurements onto the wood or trace the part you need from the elevator, the video explains how to take 1 measurement and then trace the ele over the wood for the control horn blocks.
This video is Steps 7 - 8
Elevator blocks part 3.wmv (3 min 21 sec)
Old Jan 13, 2010, 11:01 AM
NY
Joined Jun 2008
Elevator Step 8
Measure the distance between the bottom and the top of the control horn block
(going from the leading edge towards the trailing edge)
Transfer the mark onto the 1/4 x 3 using the flat edge of the balsa as the starting point.
(run the grain of the wood parallel with the leading edge of the ele.)
Take your Ele and place the inside center triangle over the 1/4 x 3 piece of balsa and trace it up to your line. then cut it out and sand lightly until it fits snug into the triangle.
(don't make it so tight it bows the bracing)
Using the same procedure or the block you made for the left side, make another for the right side.
Glue the blocks in once they fit snug
Old Jan 13, 2010, 11:06 AM
NY
Joined Jun 2008
Elevator Step 9
Now flip over the ele and draw a "B" for bottom on the control horn blocks, glue all the joints and the control horn blocks again and let dry.
Old Jan 13, 2010, 11:11 AM
NY
Joined Jun 2008
Elevator Step 10
Lightly sand the ele smooth all the way around on top and bottom sand all outside edges smooth.
Do not cut the Center piece out of the Elevators yet
Old Jan 13, 2010, 02:20 PM
NY
Joined Jun 2008
Elevator joiner wire Or dowel option
We are going to prepare the Ele And Stab for hinges during these steps also, just take it step by step its very easy
Mark the Center of the Stabilizer trailing edge and the Center of the Leading edge on the Elevators
If your using a Center tool go ahead and mark the centers of both the elevator and stabilizer just score the whole length of the pieces
you can use a Piece of 3/32 scrap balsa by laying the balsa down next to the stab trailing edge then draw a line across the center.
Or use a ruler and get the half mark that way.
This vid is for getting the center marks and choosing the joiner wire or dowel
Centers and Joiner 1.avi (3 min 25 sec)
Old Jan 13, 2010, 02:34 PM
NY
Joined Jun 2008
Joiner or Dowel choice
We want to use either a joiner wire or wooden dowel to lock the elevator halves together.
Joiner wire
To use a elevator joiner wire you'll need a piece of 1/8 rod, about 3 1/8" long from outside end to outside end it can be a little longer.
The 2 ends need to be about 1" - 1 1/8" long
If your using a Wooden dowel you need a piece of Dowel 1/4 round x 3 1/4 inches long
Old Jan 13, 2010, 03:17 PM
NY
Joined Jun 2008
Joiner and Hinges Step 1
Center Joiner wire or dowel 2.wmv (6 min 59 sec)
Mark the 4 approximate locations for the hinges on the Stabilizer on your center mark across the trailing edge.
We'll get more exact in a few steps
Discussion Guillows P-40 warhawk build log Truckerboy Scratchbuilt Indoor and Micro Models 77 Apr 20, 2012 08:55 AM
Discussion Kalteisen Katana 40 - Build Thread Brg34 3D Foamies 634 Jan 08, 2011 12:15 AM
Build Log Build Log - The World Models - SPITFIRE EP (40) djmoose Electric Warbirds 30 Jun 28, 2010 12:38 PM
Build Log Comet P-40 Build scigs30 Free Flight 47 Dec 09, 2009 10:21 AM
Question Slow Poke Sport 40 Build? modelmaster2001 The Builders Workshop 2 Oct 07, 2009 06:47 PM
