Old Dec 01, 2009, 09:05 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Recommendation for an SWR meter
Can anyone recommend a good SWR meter for my 900 MHz system that won't break the bank? The only ones I can find cost about $250. One with a power meter would be a plus.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Dec 01, 2009, 09:36 PM
kist2001 is offline
Find More Posts by kist2001
Senior Gravity Checker
Tampa, Florida
Joined Mar 2001
Tap into the RSSI pin on your video receiver with a voltmeter. Higher the voltage the better the received signal. About $10 for a meter. Cheap enough?
-Ken
kist2001 is offline Find More Posts by kist2001
Old Dec 01, 2009, 10:35 PM
Thumb_number is offline
Find More Posts by Thumb_number
I think my wheels fell off.
Thumb_number's Avatar
Perth
Joined Oct 2009
Hi Alex,
Been looking at this problem for a while. The best device I've used for tuning a home made 900Mhz dipole was a satellite meter. (I just happened to have one laying around). This just gives a dB figure of signal for a given freq. I used this to trim the dipole until I got the best dB numbers (about 87dB at 20m with an RV500mw). This method gives no real indication of good SWR, it just indicates the strongest raw signal. If one is good, the other must be OK right?? I dont know.
You should be able to find a cheap second hand satellite meter for reasonable $$$'s, it doesn't have to have a pretty spectrum display, just a level indication.
I've looked for SWR meters covering 900, and there's not much about. I've started looking at mobile phone companies to see what they use to tune antennas. I will post if anything comes up.
Have you a link to the one you found for $250?
Good luck.
Thumb_number is offline Find More Posts by Thumb_number
Old Dec 02, 2009, 10:51 AM
Tom in Cincy is offline
Find More Posts by Tom in Cincy
Tom Para
Tom in Cincy's Avatar
Cincinnati, Ohio, United States
Joined May 2003
If you want to do it right and on the cheap you need a directional coupler, a microwave detector (diode) , a load resistor and a voltmeter.
Look on Ebay for the above items. you will need to decide which connector system you will use. All up costs should be between $50-$80. I built a swr meter out of these components and it is accurate thru the 5.8 Ghz band.
I have found the pre built antennas to be very well matched. However the high gain patch antennas are pretty narrow and your channel selection will make a big difference in the SWR. BTW you can measure the voltage across the resistor and get an idea what the power outputs are.
Here is a link for a typical directional coupler http://cgi.ebay.com/narda-Model-3041...item45ef8263d2
tp
Tom in Cincy is offline Find More Posts by Tom in Cincy
Last edited by Tom in Cincy; Dec 03, 2009 at 12:10 AM. Reason: no need for a special resistor/power is calculated across the resistor
Old Dec 02, 2009, 12:03 PM
JettPilot is online now
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
tp
That is a great find, that coupler probably cost over 500 dollars new An swr meter that would read though 2.4 GHZ would be great
JettPilot is online now Find More Posts by JettPilot
Site Sponsor
Old Dec 02, 2009, 02:38 PM
stevekott is offline
Find More Posts by stevekott
Born to Live - Live to Fly !
stevekott's Avatar
Southern California
Joined Jul 2009
I know you can tune a piano but you can't tuna fish.
How can you tune a 900Mhz antenna even if you could read the SWR or RSSI ?
stevekott is offline Find More Posts by stevekott
Old Dec 02, 2009, 02:58 PM
EdHall is offline
Find More Posts by EdHall
Joined Feb 2009
http://www.rfparts.com/diamond/sx1100.html
900 - 2.5
http://www.wlanparts.com/product/CN-...00mW2W20W.html
Eham review for 900-2.5 SWR Meter
http://www.eham.net/reviews/detail/650
EdHall is offline Find More Posts by EdHall
Old Dec 02, 2009, 03:27 PM
JettPilot's Avatar
Miami
Joined Apr 2005
I make my own 900 MHZ antennas, I would adjust the leingth of the antenna to tune it. Right now, I just use calculated leingth, I have no idea how well its SWR is matched.
Site Sponsor
Old Dec 02, 2009, 03:58 PM
cmulder is offline
Find More Posts by cmulder
Ireland
Joined Apr 2001
if the transmitter remails fairly cool the swr is probbaly good enough if it gets hot it isn't
cmulder is offline Find More Posts by cmulder
Old Dec 02, 2009, 04:21 PM
VRflyer is offline
Find More Posts by VRflyer
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
so with a temperature probe glue on the tx and patience I would trim the antenna lenght to get the coolest temperature. I will get a try.
VRflyer is offline Find More Posts by VRflyer
Old Dec 02, 2009, 04:48 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The temp probe isn't necessarily a good idea. Granted temperature and SWR are related, but loosely. I would be willing to bet the TX stays cooler with no antenna at all than with a well tuned antenna.
I might try Tom in Cincy's idea. Granted, not truly SWR, but max power out will be found at best SWR.
Old Dec 02, 2009, 11:57 PM
Tom Para
Joined May 2003
Actually it is truly SWR. A measurement is made with the directional coupler hooked up. Then the input connection/output connection on the "DC" is reversed and another reading is taken. A ratio is then calculated between the 2 readings. Thats why its called a directional coupler.
The high gain patch antennas would be nearly impossible to tune. i used my set-up to verify the accuracy of a 4 bay 2.4Ghz patch. These are the ones claiming 14dbi. I can say they did a very good job building that antenna. They had it tuned perfectly in the center of the band. As the gain of an antenna goes up the bandwidth and beamwidth become much more narrow. My SWR meter showed the best signal would be achieved by using a center frequency on 2.4
Old Dec 03, 2009, 12:50 PM
stevekott's Avatar
Southern California
Joined Jul 2009
I have one of these ubiquiti frequency analyzers for 900Mhz and another for 2.4Ghz. They are relatively cheap at $59 and with a pc they give a lot of information.
I use it to check frequency use at a site and it helps determine if I use 900Mhz or 2.4Ghz based on the frequency use footprint.
It does give a peak power at a given freq in db. You might be able to use that in tuning an antenna to peak power.
It was also helpful to me at finding out the problem with an 'off frequency' transmitter that was always giving me bad performance. I had no clue how to fix it but I quit using it.
http://www.streakwave.com/Itemdesc.a...w9-EXT&eq=&Tp=
Found recommendation for a substitute BL motor for Corona 120 AtTheCross Aircraft - Electric - Power Systems (FS/W) 5 Oct 26, 2009 06:17 PM
Discussion Need an advice for strong power combo for 2.89 meter sailplane eransa Power Systems 1 Oct 06, 2009 06:44 AM
Discussion Need an advice for strong power combo for 2.89 meter sailplane eransa Electric Sailplanes 0 Oct 05, 2009 03:28 PM
Question recommendations for an electric 3-meter? n2soaring Electric Sailplanes 20 Sep 07, 2009 11:01 AM
Discussion need battery recommendation for 2.5 meter sailplane Brian Courtice Electric Sailplanes 13 Mar 06, 2008 01:14 PM
