Old Apr 29, 2010, 12:18 PM
eagsalazar is offline
Find More Posts by eagsalazar
eagsalazar's Avatar
United States, NC, Winston-Salem
Joined Sep 2008
Different manufacturers assign functions to different channels from each other. They have little to no interest in being compatible with each other. If they are compatible it is a lucky coincidence. Uisng the Spektrum TX with the Bind N'Fly planes works because they are all the same system. But using a different brand causes problems when the channels do not match up. If you had a regular RX, you could simply plug the servos into whichever channel works for that function. But with the integrated servo RX blocks you have a problem. Sorry.
Well thanks for the bad news I guess. The incompatibilities between Tx/Rx manufacturers is pretty irksome. Hopefully some open firmware delivers a solution.
eagsalazar is offline Find More Posts by eagsalazar
Old Apr 29, 2010, 02:53 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
My older Airtronics Infinity 6 channel TX has the throttle channel way out there on channel six. Makes for a PITA as you have to mix the throttle (chnl 6) to the AUX1 channel (chnl 4), which is the 4th channel on a typical 4 channel RX.
So this goes way back to when RC first started.
earlwb is offline Find More Posts by earlwb
Old May 16, 2010, 05:05 AM
Promix is offline
Find More Posts by Promix
TH9X Firmware: Thus NG
Joined Mar 2010
The firmware from Thus is already your solution
Promix is offline Find More Posts by Promix
Old May 18, 2010, 04:36 PM
Thx1326 is offline
Find More Posts by Thx1326
Joined Jan 2010
Amp Draw
Can anyone tell me how many amps this TX will pull from a battery pack?
Thx1326 is offline Find More Posts by Thx1326
Old May 18, 2010, 08:12 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Rough guess: 250 mA or less (depends in part on what module you are using -- many of the new ones are very efficient).
EDIT: Wrong. More like 100 mA -- see below.
Daedalus66 is offline Find More Posts by Daedalus66
Old May 18, 2010, 09:25 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I think it probably pulls around 100ma or so. The alkaline dry cells last seemingly forever in them. I can run the alkaline batteries for a long time before I start to get nervous and change them out. But they still are working even then. I haven't bothered to put in rechargeable cells yet. I think the new low self discharge NMH cells is probably the way to go. You don't have to recharge them all the time.
Anyway, since the TX's have been so frugal on their power consumption, and running for a very long time, I have just gone ahead and used the alkaline batteries. I just carry extra ones in case I need them at the flying field.
Old May 18, 2010, 10:49 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
You are absolutely right. I just measured mine at 50 mA without module. The Fly Dream module that I'll be using draws 40 mA. So in total we are below 100!
No wonder it runs forever on a 2000 mAh Eneloop pack. And it certainly makes you think about using 6 cells instead of 8 or a Li-Ion battery. Recognizing that this gets you into a bit of messing around to adjust the LV alarm.
Old May 19, 2010, 06:32 AM
F-111 John is offline
Find More Posts by F-111 John
R.I.P, Aardvark.
F-111 John's Avatar
Holt, MI
Joined Jan 2009
And if you ever wish to begin messing around: http://www.rcmodelreviews.com/tendollarbattery.shtml
F-111 John is offline Find More Posts by F-111 John
Old May 19, 2010, 06:43 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
The old AM/FM radio systems used to draw a lot more power. Maybe over 250mah or more in some cases. I remember my old TX's only getting four to six flights before the battery pack was low using 450mah nicads or even 600mah nicad packs. All freshly charged overnight for that day's flying.
But it is most interesting how the 2.4ghz spread spectrum systems can get long range flying with so little power being used to output a RF signal as compared to the older AM/FM systems.
Old May 19, 2010, 06:47 AM
richard9999 is offline
Find More Posts by richard9999
richard9999's Avatar
Sydney, Australia
Joined Jan 2007
I have been using these twin Lithium batteries for nearly a year now and you don't really have to worry about a low voltage alarm since they run for about a day without recharging. I think they are also more secure as they don't have the multiple cell connections which I have known to fail in the past. Recommended.
richard9999 is offline Find More Posts by richard9999
Old May 27, 2010, 01:40 PM
Thx1326 is offline
Joined Jan 2010
Reprogramming?
So... if I have an early FlySky TH9x (this is the original manufacturer) and I buy a newer Turnigy unit from Hobby King, can I download the newer Turnigy firmware and flash it to the FlySky so everything is updated?
If possible, could someone post the step by step instructions on how to do this? Or would someone here be willing to do it?
Help, please?
Old May 28, 2010, 12:42 PM
Thx1326 is offline
Joined Jan 2010
TH9x Upgradability??
This is a quote directly from FlySky that I received via e-Mail regarding the update and firmware revisions - why Turnigy is different than FlySky:
"I (tech from FlySky) just learned that Hobbyking bought a facility to update the software and firmware as you said. But in fact we (FlySky)have no the facility to deal with the problem."
So there you have it. FlySky (the OEM manufacturer) has no ability or plans to offer updates to the firmware, but Turnigy (HobbyKing) does. Looks like HobbyKing would be the dealer of choice for this TX. It would be interesting to know just HOW HobbyKing is doing this - what their procedure and physical connections to the receiver would be???
Old May 28, 2010, 02:21 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Help, please?
Quick answer: No. You can't download it (yet, anyway) and even if you could you'd need a way to inject the new firmware (that isn't built into the transmitter).
There's an extended discussion about this over on the other thread. It's a work in progress but looking very promising.
Old May 28, 2010, 04:44 PM
Thx1326 is offline
Joined Jan 2010
FlySky TH9x 9ch TX/RX/2.4ghz - New - $72 shipped
I have two of these Transmitter Packages for sale with 2.4ghz module and receiver - Never used - brand new in original boxes.
Each TX Package includes TX / 9Ch Receiver / 2.4Ghz Module / binding cable
$72.00 each includes shipping in the US.
Email me or PM me if you have questions.
Old Jun 01, 2010, 07:14 AM
mcmatrix is offline
Find More Posts by mcmatrix
mcmatrix's Avatar
Estonia
Joined May 2007
Little tip for those who want to use TH9X radio silently.
My radio will powerup in silent mode when using simulator cable or just dummy
3,5mm jack. (I have second branch firmware, D/R and EXP are working)
Poweroff your th9x radio, put 3,5mm jack into trainer port and radio will automatically powerup in simulator mode: tx module is not active and radio is entirely silent.
No annoying beeping sound when programming radio
mcmatrix is offline Find More Posts by mcmatrix
For Sale JR XP6102, Turnigy 9x, Assan X8J heffe2001 Aircraft - General - Radio Equipment (FS/W) 10 Sep 21, 2009 02:50 PM
Discussion Anyone have a bad Turnigy Imax or Eurgle 9x Kev Radios 0 Sep 18, 2009 05:47 PM
Question iMax 9X generally and 2.4ghz for the iMax 9X specifically: How is it? JRexA Radios 30 May 11, 2009 04:25 PM
Discussion iMAX 9X transmitter Crow Program - how to use it??? John Kim Radios 1 Nov 22, 2008 11:00 AM
