Old Dec 01, 2009, 02:29 PM
Coil is offline
Find More Posts by Coil
Coil's Avatar
Slovenia
Joined Mar 2008
Turnigy TR3536 rewind
Today i rewind TR3536, the stator is from SK3542 shortened and isolated, i bought new bearings and rewind with 5 turns 0,85 wire delta...
Coil is offline Find More Posts by Coil
Old Dec 01, 2009, 03:08 PM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi
Good work.
Is the small screw system to lock the lams/stator tube is from stock motor or DIY ?
Louis
Fourdan is offline Find More Posts by Fourdan
Old Dec 01, 2009, 03:14 PM
Coil is offline
Coil's Avatar
Slovenia
Joined Mar 2008
Thanks, it is DIY but i didn't cut the hole very good so i will do i again, with slightly larger screw.
Old Dec 01, 2009, 03:20 PM
Coil is offline
Coil's Avatar
Slovenia
Joined Mar 2008
Before i glued all my stators with some green smelly, temperature resistant glue. That i also use to glue magnets but it is impossible to remove the stator without destroying the motor. Now i use this method where i can.
Old Dec 01, 2009, 03:27 PM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi Sukalo
You have adopted a very good solution to avoid Turnigy lams to rotate/ tube and cause a failure to the windings on stator flange side.
Louis
Old Dec 01, 2009, 03:44 PM
Coil is offline
Coil's Avatar
Slovenia
Joined Mar 2008
When you get hands on Kontronik Kora motor, it is a pleasure to see how easy it to remove the stator They don't have fancy 0,2mm laminates but it is a well constructed motor.
Old Dec 01, 2009, 04:06 PM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi Sukalo
Yes sure but not the same price
Your pictures are showing DIY rewindings ? Y or Delta ? 7 turns per tooth ??
Picture of the rotor inside ? 10 or 14 mag ?
Size of stator (mm) ?
Kv obtained ?
Louis
Old Dec 01, 2009, 04:12 PM
Coil is offline
Coil's Avatar
Slovenia
Joined Mar 2008
They are relay not in same price class
Both motors are 14p12n wind delta top motor is Kora 15-14 bottom 10-16.
Old Dec 01, 2009, 04:29 PM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi Sukalo
It seems Kv are different (zero current rpm)
a) Stock Kora (continuous line)
b) your DIY Kora (dotted line)
Did you make windings same # of turns ?
Louis
Old Dec 01, 2009, 04:35 PM
Coil is offline
Coil's Avatar
Slovenia
Joined Mar 2008
Yes the kv is different dotted line is cora that i got in my hands and measure kv-1074 the dotted is Kora after rewinding 1 turn less kv-1218 so efficiency is of course a little better.
Old Dec 01, 2009, 04:40 PM
Coil is offline
Coil's Avatar
Slovenia
Joined Mar 2008
This will be better stock Kora continuous line mine dotted. Same number of turns.
Old Dec 01, 2009, 04:44 PM
Coil is offline
Coil's Avatar
Slovenia
Joined Mar 2008
Last time when i rewinded a chinese 6-pole outrunner with 0,2mm laminates 3026 size. I was amazed how efficiency climbed when i put on the bell from HK3026...
Old Dec 01, 2009, 05:22 PM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hi Sukalo
That is due to a stronger magnetic flux
A) from a higher "physical volume" of the magnets
B) or from a higher "grade" of the magnets
or both
For the same stator, same windings, Kv is lower, inducing a better Peakeff
(lower rpm for the same current)
Louis
Old Dec 03, 2009, 05:52 AM
Julez is online now
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Nice work!
How did you remove the stator from the stator tube the first time?
Julez is online now Find More Posts by Julez
Old Dec 03, 2009, 06:06 AM
Coil is offline
Coil's Avatar
Slovenia
Joined Mar 2008
Thanks, i heated the stator with solder iron and then screwed to my motor test stand, then i wrap cloth around the stator hold it with a pliers then turn and pull the stator off.
But with the heating you destroy the bearings, so you need to buy some new ones. That is the solution in some cases but not all the stators can be removed without damage. If i have a broken motor i try to remove the stator and then if everything goes well i can rewind. There is another way you can try knock the heated stator with a tub and a hammer. If all fails, then it goes in to trash
Discussion Rewind of a Turnigy SK 3530-1400 Knife Liddle Electric Motor Design and Construction 15 Nov 04, 2011 12:41 AM
Discussion 3350-11 rewind warhead_71 Electric Motor Design and Construction 17 Feb 21, 2010 06:46 AM
Discussion Rewind Turnigy SK4260-500 manuel v Electric Motor Design and Construction 52 Dec 20, 2009 06:37 PM
Discussion Rewind brush to brushless motor(HELP!!!) nak25 DIY Electronics 7 Nov 10, 2009 01:47 AM
Discussion HXT 2712 24g ABC Rewind ggjj Electric Motor Design and Construction 8 Oct 06, 2009 03:50 PM
