Old Dec 01, 2009, 01:49 AM
Lissey is offline
Find More Posts by Lissey
Joined Nov 2009
plain retractable tx antenna 5/8 lambda for range improvement?
Hey guys,
I'm using 35 MHZ and have already read a lot about extending the length of the rx antenna to 4,07m and let it hanging out of the plane in order to achieve greater range.
Like every radio mine uses a retractable/teleskopic antenna with around a metre size. Now do you think if i attached 3-5 aluminium tubes of decreasing size like these
to a plain retractable antenna with 5/8 lambda or something ( roughly 3 metres), this would significantly increase my range over the stock antenna?
any advise appreaciated!
PS: Do you think this is a better antenna http://www.inesun.com/show-2051,ES500YAGI.html for my 1.2GHZ Video Receiver than a simple 6-8dbi patch?
Lissey is offline Find More Posts by Lissey
Old Dec 01, 2009, 02:49 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Originally Posted by Lissey View Post
...this would significantly increase my range over the stock antenna?
Yes!
http://www.rcgroups.com/forums/showp...68&postcount=7
That yagi surely is better, but for long range, not in proximity. And, mandatory with a tracker, the beam is too narrow !
renatoa is online now Find More Posts by renatoa
Old Dec 01, 2009, 03:14 PM
Lissey is offline
Joined Nov 2009
You're quite a ressource Renatoa! Thanks for your advise!
Discussion Help: antenna questions for Hobby King Tx Bob Chiang DIY Electronics 6 Nov 15, 2009 11:35 PM
Discussion What Cable Do I Need for My Hitec Flash 5 Tx and RealFlight G3.5? sstephenson61 Simulators 0 Sep 13, 2009 07:23 PM
Discussion RX TX antenna orientation and type for high altitude above field Matt Gunn FPV Talk 4 Sep 09, 2009 02:18 AM
Discussion Range check using old TX module (nub antenna) iflybyu77 Xtreme Power Systems 1 Dec 08, 2008 06:38 PM
Question How Should You Hold TX Antenna for Best Range? RCSMITH Radios 9 May 26, 2004 10:52 AM
