Old Nov 30, 2009, 01:07 PM
Bowerz is offline
Find More Posts by Bowerz
No, I dont work for HH ;)
Bowerz's Avatar
Southampton, Hampshire, UK
Joined Sep 2009
Build Log
Mini/Micro 15" F22 Pusher Profile
We'll in my 3 planes, 1 power system quest, i came across the 18.8" WS F22 thread, I had to make one but didn't want to buy another motor and ESC, so i decided to incorporate it into my quest. I scaled it down to 15" and done some number crunching and it came out quite nice. I am making it out of 5mm EPP because it's so durable, but mainly because that's the only thing i have at the moment.
Motor: 4000kv AP05 5.4g BL motor Link to go here
Prop: 3050? Link to go here
ESC: Turnigy Plush 6A OR XP-7A Link for Turnigy to go here
Servos: Mystery SD-3.7 (weight 5g AUW) will lighten Link to go here
Receiver: Spektrum AR6110e Link to go here
I have most of the bits cut apart from the bottom plate of the air ducts as the plans didn't seem to match with all of the notches? So i only used the plans for shapes and came up with my own joining notches, but still guided by the shape of the plans. I'm using hot glue as it is the best type of glue for epp i have found.
Update 10 December 09: I have now installed the elevon servo's. I made a bit of a school-boy error with the first one and cut a hole for it to go where it would foul the prop. Once i extended it backwards and put a bit of EPP in the front of the hole to patch it back up. I have set my DX6i to do elevon mixing and also added a mix which sorts out the known issues the DX6i uses when elevon mixing is on. Next job - motor mount and waiting for the receiver to come
Bowerz is offline Find More Posts by Bowerz
Old Nov 30, 2009, 09:14 PM
olmstead25 is offline
Find More Posts by olmstead25
Parkzone connectors here!!
olmstead25's Avatar
Joined Oct 2008
Hey looks good! i cant wait to see it fly! make sure you take pics befor you fly, those noses get chewed up quick!
olmstead25 is offline Find More Posts by olmstead25
Old Dec 01, 2009, 10:46 AM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
I have already broken the nose gliding it to find the CG, but nothing a bit of hot glue didn't fix!
Old Dec 09, 2009, 07:12 PM
dylantorquerol is offline
Find More Posts by dylantorquerol
Love the sport, not the plane
Hawaii
Joined Oct 2009
Very cool. Your idea has inspired me. I am making my own plans, and getting general shape from my Yard Bird 30" F-22. Hopefully it will fly better than your avion! Just joking!
dylantorquerol is offline Find More Posts by dylantorquerol
Old Dec 10, 2009, 10:38 AM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
Added update to main post
Old Dec 10, 2009, 09:01 PM
Hawaii
Joined Oct 2009
very cool. Again. suspected AUW?
Old Dec 11, 2009, 01:16 AM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
Suspected auw is 90-110g
Old Dec 11, 2009, 06:38 PM
Hawaii
Joined Oct 2009
Why so heavy? COuld't you get below 40g? Actually 70 is more reachable. I don't know how many party you are using though.
Old Dec 12, 2009, 01:02 AM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
Its mainly because those are the numbers i need to get my wing loading. I am making it out of 5mm EPP so it will be durable. Also, the heavier it is, the more wind capable it is. I am using a 800mah 2 cell so things should be interesting.
Old Dec 12, 2009, 01:43 AM
Hawaii
Joined Oct 2009
WOW! BIG BATTERY! It is going to be super powerful.
Old Dec 12, 2009, 12:31 PM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
No, it's just going to have loads of flight time (fingers crossed). I am currently having trouble with my elevon mixing. When that is sorted, i'll sort out the motor and mount, install that with the ESC, then its flight time!
Old Dec 12, 2009, 03:14 PM
Hawaii
Joined Oct 2009
Very cool!
Build Log Profile F-35 JSF Mid Motor Pusher with Thrust Vectoring bdelapen Foamies (Scratchbuilt) 54 Oct 19, 2010 09:00 PM
For Sale GWS 15 Pusher jet Art Schmitz Aircraft - Electric - Airplanes (FS/W) 0 Oct 04, 2009 01:34 AM
Discussion F-16D/I Profile Pusher Blueangels4 Pusher Prop Jet Models 22 Oct 02, 2009 03:17 PM
Cool esing profile pusher jets inedesca Product Announcements 0 Sep 18, 2009 11:28 PM
mini F-16 pusher (profile) jaime_arenas Pusher Prop Jet Models 2 Aug 01, 2005 01:43 PM
