Espritmodel.com Heli Air
Old Nov 30, 2009, 10:17 AM
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
Detrum GY48V Gyro
Please post your results with this gyro, setup information, tail servo selection etc. here.
The gyro I am referring to is available a the following US distributors:
http://www.hobbypartz.com/60p-dy-1017.html
http://www.xheli.com/60p-dy-1017.html
So far, the reports are mixed on its operational capability. However, some people appear to be having good luck, and the main advantage this gyro holds over the G401B is the low cost shipped from the U.S
samc99us is offline Find More Posts by samc99us
Old Nov 30, 2009, 12:09 PM
Pirouetting flip master
Malaysia
Joined Jul 2007
two links end with the same html page.... same vendor i presume
lyclyc is offline Find More Posts by lyclyc
Old Nov 30, 2009, 06:59 PM
crashs come easy patience dont
bad400's Avatar
USA, MI, Shelby Township
Joined Jan 2009
yes both xheli and hobbypartz are the SAME people, so is nitroplanes, nitrorcx, & radientech.
the ORIGINAL (US) distibutor of this gyro is www.helidirect.com
do a search on this forum for the DYNAM gy48v, i posted a few video`s and info on this gyro.
IT SUCK`S, i still have this gyro because i havent found a SUCKER to buy it.
i wouldnt waste a dime on this gyro.
bad400 is offline Find More Posts by bad400
Old Nov 30, 2009, 07:05 PM
Redjestird Youser
SidewaysLS4's Avatar
Joined Jan 2009
I fired mine up to replace a 401B that is too screwy at times. Works pretty good. Slight drifting depending on headspeed (it does get affected by vibes, so it isnt just like a $$$ gyro, but still very good). I noticed the piro rate is quicker than a 401B, I needed to turn down the travel adjust on the gyro channel a bit to match what I normally like on that heli. All in all for the short time I used it so far, well worth the $15.00.
Setup...GY48 on a 450 scaler with raised tail/cable tail actuation, driven by an Align DS420 (we'll see how long that lasts with the load of the cable actuated tail, lol. Will eventually be replaced with a bigger servo)
SidewaysLS4 is offline Find More Posts by SidewaysLS4
Old Nov 30, 2009, 07:08 PM
Axes & Blades-Cutlery & Helis
West Monroe NY
Joined Feb 2009
I hope they are good, for $15 I couldn't resist, I order 4
ewoodcox is offline Find More Posts by ewoodcox
Old Nov 30, 2009, 07:37 PM
No ! Your other left !
aramsdell's Avatar
United States, ME, Sanford
Joined Jun 2006
I have that gyro. I replaced a Gy 401 with it after a bad crash. TheDetrum worked ok for a while. Funny thing is I had to run high gain to hold the tail and then it would break loose now and then. I mean 80 to 90% in HH. )n my radio 51 -100 is HH mode 50 is off and 1-49 is rate mode. I was running at 90 to 95 (90-50=40. 40 X 2 = 80). I had a fairly hard crash about 6 weeks ago and the heli only just flew this weekend. I had to go to 100% gain and then it just wagged around all over. Virtually no control. I believe tonight I found out why.
There was NO glue holding the inside of the gyro to the case. The PCB was loose and vibrating. On the bench it seemed super sensitive bu vibrating in the air it was NFG.
I put a little Gorilla glue on the edges and reinstalled the cover after wiping the pcb with a little silicone for anti-corrosion.
Time will tell but I bet this was the problem.
There was no indication of a seal for warranty so I would recomend anyone using one to open the case first and put some kind of glue in there to hold the pcb rigid.
aramsdell is offline Find More Posts by aramsdell
Old Nov 30, 2009, 07:43 PM
bad400's Avatar
Joined Jan 2009
i did the glue trick, absalutelly no difference on my gy48v. it still sucked.
i had it on a blade400 and used a 9650 and the ds3500g, still sucked.
plus my heli has NO visable vibration`s.
Old Nov 30, 2009, 08:50 PM
Joined Feb 2008
Hey, I'm a big n00b so I dont really understand but what sucks about it? It came with my copter x and I thought it was ok but really dont know what makes a good gyro and a bad gyro. I too had to put the gain on the remote to 85%. It seems to hold pretty well when I drop the throttle and then throw it back up to 100%.
Aaron_M is offline Find More Posts by Aaron_M
Old Nov 30, 2009, 09:01 PM
bad400's Avatar
Joined Jan 2009
dynam gy48v
mine would never stop drifting, tail would rotate 90 degress in less than a minute.
it would not hold when you really needed it to.
pitch pump`s/throttle pump`s the tail would hick out, i personally didnt like it at all.
Old Nov 30, 2009, 09:05 PM
Joined Feb 2008
So if mine holds fine with throttle pumps and I can fix the drift with sub trim on the remote then what would I gain with going to a better gyro?
Old Nov 30, 2009, 09:11 PM
bad400's Avatar
Joined Jan 2009
going from a trim/sub-trim peizo gyro to a no trim/sub-trim smm or mems gyro cant be measured by word`s.
if you know no different from a good gyro and a bad gyro then you are not flying sport or 3d.
Old Nov 30, 2009, 09:13 PM
Joined Feb 2008
oh Im definitely not to that level yet, I can hove really well and am just starting to do some nose in and forward flight.
Old Nov 30, 2009, 09:53 PM
anarchist
frac's Avatar
BWHAHAHAHAHHAHAHAHAHAHAHHA
how well i know this........
frac is offline Find More Posts by frac
Old Nov 30, 2009, 10:21 PM
Redjestird Youser
Joined Jan 2009
Hey, as long as it keeps the tail in back of the heli I'm happy, lol. Gotta keep with the theme of the airframe...dirt cheap. I'll leave the good stuff for the FBL models
Old Nov 30, 2009, 10:34 PM
anarchist
frac's Avatar
let me explain: this is what happened in almost every cheap gyro thread, mine , gino's, now this.
some ppl get them to work well, some don't. mysterious.
FAQ DYNAM gy48v bad400 Mini Helis 58 Apr 20, 2011 03:55 AM
Discussion To gyro, or not to gyro. Cralis Video Piloting (FPV/RPV) 37 Dec 02, 2009 02:41 PM
Sold GY48V (401 Knock off) gyro & ino-lab HG-201 servo UAV_PILOT Aircraft - Electric - Helis (FS/W) 2 Oct 26, 2009 10:45 AM
Sold GY48V gyro - $28.00 shipped Adroc3905 Aircraft - Electric - Helis (FS/W) 0 Jul 23, 2009 09:54 PM
For Sale gy401 or gy48v dynam bad400 Aircraft - Electric - Helis (FS/W) 2 Jul 17, 2009 08:53 AM
