Old Nov 30, 2009, 07:46 AM
ath512 is offline
Find More Posts by ath512
Joined Nov 2004
Gaui Hurricane EP425 any good?
Flying-hobby is selling it for $59, one day deal. Is it worth it?
I mean is the build good?
I don't see many threads talking about it. I read in other forums that it can be converted to a 550 size heli. It will be cheaper than buying the Gaui 550 basic kit.
ath512 is offline Find More Posts by ath512
Old Nov 30, 2009, 07:54 AM
mosca.br is offline
Find More Posts by mosca.br
Trying to fly on the cheap!
Norway, Rogaland, Stavanger
Joined Aug 2008
It is basically a Hurricane 550 with shorter boom and belt.
You can easily convert it to 550 by changing boom, belt and tail pushrod.
I have one and like it alot
Just keep in mind that the kit on flying-hobby does not include any electonics or blades.
mosca.br is offline Find More Posts by mosca.br
Old Nov 30, 2009, 08:08 AM
ath512 is offline
Joined Nov 2004
Thank you for your reply.
Is the stock build good? Do I have to change or upgrade anything?
Old Nov 30, 2009, 08:20 AM
mosca.br is offline
Joined Aug 2008
It works out of the box. I changed the bell cracks to the cnc version to remove the offset required in the stock build, but that just makes the build easier (not by much, but I like it).
I forgot to mention, no pinions included on the kit either.
Old Nov 30, 2009, 09:17 AM
ath512 is offline
Joined Nov 2004
Thank you again for your info.
What is the part number for the cnc bell cracks?
When you said that the 425 is actually a 550 but with shorter boom and belt
does that mean the frame and head is the same as the one in the gaui 550 kit? or is there any difference?
Because I will rely on Finless Bob videos for building the gaui 550.
Also to make it 550 size,do I only need this part "Tail Boom Conversion Set(with Belt 572XL) for 550L Blade" #204663
and 550mm blades. Right? or is there anything else like the tail blades?
I appreciate your help.
Old Nov 30, 2009, 04:10 PM
sparrow1717 is offline
Find More Posts by sparrow1717
WOOOOsssSSSShhHH !!
sparrow1717's Avatar
Long Island , NY
Joined May 2003
mosca.br has got my attention in regards to the "stretched" Gaui EP425 to a 550.
Do you have pics and what is the flight performance like?
ath512 - there isnt much info on the little Gaui 425 it seems. Good luck with your build .
Spar
sparrow1717 is offline Find More Posts by sparrow1717
Old Nov 30, 2009, 04:13 PM
mosca.br is offline
Joined Aug 2008
Yes. The the head and frame are the same as the standard 550 kit. You can even use standard sized servos in the 425.
I think the tail boom conversion set will be enough, but I'll probably end up replacing my tail blades with kbdd tail blades since I like orange tail blades Just pick your 550 blades carefully, as the bolt that holds the main blades is 3mm on the plastic grips, and keep the headspeed below 1900rpm (unless you upgrade to metal grips).
You can see a full list of parts for the 425/550 here:
http://www.gaui.com.tw/html-en/produ..._550_parts.htm
The cnc levers are #204612 and #204614. I believe you only need #204614, as the aileron and pitch levers have holes to remove the offset already.
Old Dec 01, 2009, 12:36 AM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
This is my 425. Running a Scorpion HK 3026-1210kv on stock gears, and 16 tooth pinion. With an Castle ICE 75 esc, and Spektrum 821 servo's. Has Infinity Hobby $29 carbon 430mm blades.
http://www.rcgroups.com/forums/attac...8&d=1259360574
http://www.rcgroups.com/forums/attac...7&d=1258355596
I like it as a 425. I did buy the 550 stretch kit, and blades but have not used them. My stretched 550 was a little faster on top end, and a little slower on cyclic. The 550 tail rotor blades, and canopy are longer.
Roto Rob is offline Find More Posts by Roto Rob
Old Dec 01, 2009, 10:31 AM
ath512 is offline
Joined Nov 2004
Can you recommend some sites that sell sapre parts with good prices?
Old Dec 01, 2009, 11:12 AM
mosca.br is offline
Joined Aug 2008
I do most of my gaui shopping on allerc.com, flying-hobby.com and infinity-hobby.com (in that order). I also order from readyheli and helidirect (they don't carry a lot of gaui stuf anymore) and I heard hobby-lobby.com also caries gaui now.
Old Dec 01, 2009, 08:19 PM
cbarnettone is offline
Find More Posts by cbarnettone
Indianapolis, IN
Joined Mar 2007
Spar
I got my 425 kit at IRCHA this year. My current setup is:
Cyclic - S9650s
Tail - GY401/S9257
Motor - Scorpion 3026-1400 / 13T Pinion
ESC - Castle Creations Ice 100 lite
Main Blades - Prod 3D 430mm
Tail Blades - Outrage 550 82mm (upgraded for more tail authority)
I REALLY like it. Very nice upgrade from the Blade 400 that I had been flying before. This size is great, because I can swap the batteries back and forth with the blade. I run 1 - 3S 2200 mah lipo on the Blade, or run 2 in series (for 6s) on the Gaui.
Here's a link to some pictures:
http://www.rcgroups.com/forums/showt...3#post13093113
I've upgraded ESC and the batteries since the initial build. The 50 amp Ice was not up to the task. I'm pulling 90 amps on full collective manuvers! So, I'm running a the 100 Amp lite version now along with 30C batteries. Also, here is a flight video. Not doing anything special because I still have A LOT to learn, but it sure is fun!
Hurricane 425 Sport Flying (3 min 28 sec)
cbarnettone is offline Find More Posts by cbarnettone
Old Dec 01, 2009, 09:27 PM
mosca.br is offline
Joined Aug 2008
Spar
I am waiting for blades to arrive so I can finish the conversion.
It is currently still running as a 425.
You can read more about my build here:
http://helistamagazine.com/forum%20p...hp?f=31&t=1392
It is nexgen's thread, but I got my kit from him...
Old Dec 01, 2009, 11:27 PM
AceMigKiller is offline
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Need I say more???
2009 IRCHA Bobby Watts Friday (3 min 48 sec)
AceMigKiller is offline Find More Posts by AceMigKiller
Old Dec 02, 2009, 12:22 AM
Flyextreme is offline
Find More Posts by Flyextreme
Sure it'll work
Flyextreme's Avatar
United States, CA, Redondo Beach
Joined Nov 2005
Alot more activity here http://helifreak.com/forumdisplay.php?f=80
And, by the way, I love my Hurri 550 (550mm blades). You should just get it.
Bill
Flyextreme is offline Find More Posts by Flyextreme
Old Dec 02, 2009, 09:50 AM
Joined Jul 2004
Agreed.
Probably the easiest to build, rock-solid flying 500-Class Heli I've flown.
Gobs of power on the stock 6s setup... really can't say enough about it.
Vic
For Sale Two GAUI Hurricane 425 kits New in Box kc7328 Aircraft - Electric - Helis (FS/W) 1 Sep 16, 2009 07:11 PM
Sold GAUI Hurricane 550 w/ Upgrades HighNear90 Aircraft - Electric - Helis (FS/W) 4 Sep 11, 2009 04:57 PM
For Sale Gaui Hurricane 550 Kit thunder1 Aircraft - Electric - Helis (FS/W) 0 Aug 30, 2009 11:09 PM
Discussion More Pic for hurricane EP425 for share fung Electric Heli Talk 46 Mar 13, 2008 07:04 AM
Discussion Hurricane EP425 First Look fung 3D Electric Heli Flying 3 Jan 30, 2008 12:41 PM
