Joined Aug 2002
Aurora: Trainer / Buddy system Master & Slave function Set-up. and also to sub Section "Trainer (Buddy box) cables - DIY " under "Buddy Boxes. Servo Leads. Flight Simulator & Interface." at: Alan's Hobby, Model & RC FAQ Web Links 2 . There is no power transfered to or from the Aurora 9 (nor Optic Sport which uses similar system) Aurora 9, Spectra 2.4Ghz Module & Optima Transceiver - FAQ & Undocumented Features - Mixes, Setups, Tips. {Individual Links often updated} Alan T. |
Nope, if you have something like a dragon link, whack the three cables on a servo plug, remove the module from the A9 and (when viewed from the back of the Tx) you want the three leftmost pins, I can't remember the pinout off hand (it's on the thread somewhere) but a standard servo plug can be used with the DL (it's what I use) and its easy enough to do.
CJ |
Joined Aug 2010
using external modules with Aurora 9
I have this figured out. took me a while.
I have the aurora 9 with the spectra pro module (72 MHZ) I also use the FRSKY DHTU module. this module works fine on my Futaba 9c as shown in the FRSKY instructions. the Aurora 9s voltage is not high enough to use with the included pack. (I have not tried a LIPO) so I connected my DHTU to a 9.6V NiCad battery and then connected the ground wire to the ring of a 1/8 inch head phones jack and the PPM signal to the TIP of the headphones jack. please ensure that you connect the negative wire of the battery and the ring (ground) of the 1/8 inch headphone jack (trainer port on back of aurora 9) works like a champ. the radio has the spectra pro module installed. the screen prompts me to turn on the radio and I say NO and even so the module works. also my modulation type is set to PPM negative. to be clear - I am not using the pins on the module at all. I am using a 1/8 inch headphone jack and an external battery to power the FRSKY DHTU. |
Romania, Dolj, Craiova
Joined Sep 2007
Isn't Aurora powered from a 2s Lipo pack or 6Nimh? Thus more than 7V anyway ... ?
If true, DHT-U will work fine powered from Aurora, it is OK even at 6V. |
Latest blog entry: JRSky - birth of a dream radio
| Thread Tools | |
| Help! 9 pin D-Sub connector source? | hbielich | Thermal | 15 | Nov 10, 2009 07:41 AM |
| Discussion Hitec Aurora 9 Trainer Link | jedorme | Hitec/Multiplex USA | 1 | Aug 24, 2009 10:36 PM |
| Discussion Jim -XPS module for new Hitec Aurora 9 ?? | Howard L | Xtreme Power Systems | 4 | Apr 21, 2009 12:06 AM |
| Sold Futaba Trainer Cord Micro to Micro Plug SQUARE PIN | rajesh5024 | Aircraft - General - Radio Equipment (FS/W) | 0 | Apr 10, 2009 03:47 PM |
| Photos of Multiplex 6 pin connector plug installs? | surfimp | Slope | 14 | Aug 08, 2005 10:12 PM |
