Old Nov 29, 2009, 06:03 PM
daemuon is offline
Find More Posts by daemuon
daemuon's Avatar
Joined Sep 2008
Question
Dukw
I've searched the forum but have not found any really helpful threads.
Has anyone here built one of the DUKW amphibious trucks? Or maybe the Ford Seep Jeep...
What did you use for propulsion? steering?
daemuon is offline Find More Posts by daemuon
Old Nov 29, 2009, 06:20 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
I used to have a DUKW build on Geocities, but they shut down... maybe I'll get around to redoing it here.
I scratch built the axles (4 whl drive including steering linkage), while the prop was driven through a 3:1 gearbox.
CG Bob built the Deans Marine kit... they have a list of parts from the RC trucker guys.
patmat2350 is offline Find More Posts by patmat2350
Old Nov 29, 2009, 06:34 PM
daemuon is offline
daemuon's Avatar
Joined Sep 2008
Great DUKW Pat! How did you scratch build those axles?
How many channels did you have? One for land drive, land steering, water drive, and water steering?
Too bad you don't have a backup of that site, I'm probably going to ask you so many questions!!
Old Nov 29, 2009, 06:39 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
2-1/2 ch. Traxxas radio.. flip a switch to run a servo which toggles the ESC to one motor or the other.
All scratch built... it's nice to have a lathe (nicer if I had a mill too). Hull was scaled from an Italeri plastic kit.
Old Nov 29, 2009, 07:04 PM
CG Bob is online now
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
Here's my build log on the Dean's Marine DUKW.
CG Bob is online now Find More Posts by CG Bob
Old Nov 29, 2009, 07:47 PM
daemuon is offline
daemuon's Avatar
Joined Sep 2008
Thanks for the info Pat. I don't have the tools to do metal machining, so i'll need to do some kind of stock axles. The rudder and front tires were linked full time? What is the performance like on land and in the water?
Nice looking DUKW CG Bob! I like the skirts on the wheel wells.
Old Nov 29, 2009, 08:29 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Yes. Two servos Y'd together in my case.
Performance? Fine, just like the original:
"She's not very fast, but she's better in water than any truck, and she'll beat any boat on a highway!"
Old Nov 29, 2009, 08:42 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Only vehicle to use in hurricane waters.
Rich
cyclops2 is offline Find More Posts by cyclops2
Old Nov 30, 2009, 06:48 AM
daemuon is offline
daemuon's Avatar
Joined Sep 2008
pat about how much do you have into your lathe setup? if i buy the axles it looks like i'd be into it about $1000!!! if i go 6x6. even if i go 4x6 it'll be a good amount of change.
cyclops2, luckily we don't get many hurricanes around here...
cg bob, i saw your dukw in your thread about dean's marine dukw. what drive system did you use?
Old Nov 30, 2009, 11:38 AM
KC8WPF
CG Bob's Avatar
Joined Sep 2004
I bought the kit from Loyalhanna Dockyard, and used their recommended drive systems. The motors are MFA/Como 12V units with a gear box. IIRC the propellor drive has a 6:1 reduction and the wheel drive motor has an 11:1 reduction. I used the recommended Robbe differentials, two for the rear wheels and a steerable unit for the front wheels.
Old Nov 30, 2009, 12:06 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
With a few extras, I probably have $500 in... and really need a mill to do good work. All useful if you intend to do lots of this kind of work... and what a great project to learn on!
Search on "lathes" in these forums, lots of previous discussion.
Old Nov 30, 2009, 01:44 PM
keith S is online now
Find More Posts by keith S
r/c ships and workboats
bellingham, wa
Joined May 2006
Like the DUWK photo from Seattle where the take you out on Lake Washington as part of the tour and give every one a duck quacker ( kazoo ) to quack with on the tour.
keith S is online now Find More Posts by keith S
Old Nov 30, 2009, 03:02 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Still have my quacker...
Old Nov 30, 2009, 03:07 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
One thing to watch for- climbing out takes a lot of driveline torque, so design accordingly. I use a 50:1 drive unit with a Speed 400 in place of the stock MFA Como motor, and I can't keep the cog belt from jumping in this maneuver. If I could fit them in, I'd use cogs of twice the diameter to reduce the belt tension for the same torque.
Also would be neat to have authentic bar tread tires... these airplane tires have no grab. No one makes them though. I can't climb out on a beach, but I can at the local pool, where they have a shallow pebbly concrete ramp in the kiddy pool...
Dean's Marine DUKW CG Bob Scale Boats 44 Apr 08, 2012 02:54 PM
Discussion Rubber DUKW Race patmat2350 Dock Talk 12 Sep 29, 2008 09:00 AM
Question Where can I find a powered front steering axle for a 1:16 RC DUKW??? DUKWsinArow Off-road Cars 0 Nov 28, 2007 12:36 PM
