Old May 04, 2003, 04:47 PM
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
Separate battery for a retract servo? How?
Guru's,
I'm thinking about fitting retracting u/c to my next proposed project.
I keep hearing horror stories about stalled servo's draining all the current from the main batteries, so is there a diode or sumfink so I could use a separate small cell pack just to power the u/c.
Just disabling the BEC won't work as the stalled servo scenario will still kill the radio gear.
Any thoughts before Bri shifts this thread elsewhere?
tim
tim hooper is offline Find More Posts by tim hooper
Old May 04, 2003, 05:22 PM
Tony Oliver's Avatar
North-East England
Joined Mar 2002
Is this what you want Tim?
Tony
Tony Oliver is offline Find More Posts by Tony Oliver
Old May 04, 2003, 06:08 PM
Registered Lifeform
Paul Willenborg's Avatar
Little Rock,AR,USA
Joined Jun 1999
Tim,
Is the project big enough to carry an honest-to-gosh retract servo? One of their big advantages is that they "time out" if stalled and turn themselves off. Although I still think a seperate battery is a good idea.
At least this was true in the past. These days it seems to be hard to find anything but the most superficial information about servos.
Paul
Paul Willenborg is offline Find More Posts by Paul Willenborg
Old May 04, 2003, 07:44 PM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Re: Separate battery for a retract servo? How?
..a
Old May 04, 2003, 08:20 PM
Malaysia
Joined Jun 2001
Do you really need to use retract servo? assuming that travel is properly set and no binding?
What happen if you use normal std servo. You just basically swing the servo arm from one end to the other, does this really need retract servo? WHats the differences?
Magna is offline Find More Posts by Magna
Old May 04, 2003, 08:42 PM
Monticello, FL USA
Joined Jul 2002
Tim,
I have installed retracts on my 1/2A P-51 conversion using a Hitec HS-85BB. The advantage here is the ability to set EPA to eliminate the binding/stall. I am pleased with this setup.
sluufuut is offline Find More Posts by sluufuut
Old May 04, 2003, 08:59 PM
Registered Lifeform
Little Rock,AR,USA
Joined Jun 1999
>>...the ability to set EPA to eliminate the binding/stall.<<
>>...assuming that travel is properly set and no binding?<<
All well and good until one leg gets a little bent when it hits a bump or the plane swerves badly on takeoff. Then it binds and 30 seconds later the BEC goes into thermal overload and the plane crashes. A single stalled servo may draw several amps.
Do you cycle your landing gear and check them after EVERY landing? You'd better.
The difference is (or was) that a retract servo knows it should only operate for a short time and turns itself off even if jammed badly. It's a shame there are not any micro retract servos. They would not be difficult to manufacture.
Paul
Old May 04, 2003, 09:50 PM
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Retract servos have a geneva mechanism that locks the servo into the end of it's travel. At this point the motor is turned off and you can not move the ouput arm regardless of how hard you try. The motor will not turn back on until it is commanded to go to the other extreme of travel. Retract servos are two position, 180 degree travel servos and have mechincal locks in these positions.
I don't think there are actually any retract servos that shut down after a given time period, not the one's I've played with anyhow.
Greg
gkamysz is offline Find More Posts by gkamysz
Latest blog entry: A tiny diesel engine AE 0.1CC
Old May 04, 2003, 10:57 PM
Registered Lifeform
Little Rock,AR,USA
Joined Jun 1999
Greg,
The old Futaba low profile (136G?) retract servo would shut off after just a few seconds if stopped in an intermediate position. Pretty sure the equivalent JR was the same. I'm not sure about current versions.
Old May 04, 2003, 10:58 PM
Colonial Heights, Virginia, USA
Joined Mar 2001
You could install in the retract wiring, a slo-blow fuse rated at about double the amp draw for the normal servo involved in the retract system.... at least under any abnormal current condition, the blown fuse should auto-disconnect from the flite pack any let the other chans work normally........... kw
KillerWatt is offline Find More Posts by KillerWatt
Old May 05, 2003, 03:07 AM
All under control, Grommit!
leccyflyer's Avatar
NW England
Joined Sep 2000
I'm not moving this anywhere- lots of useful info in there, the diagram has found it's way straight onto my hard disk.
Hoops with retracts???? It'll be rivets next, you mark my words
leccyflyer is offline Find More Posts by leccyflyer
Old May 05, 2003, 07:04 AM
North-East England
Joined Mar 2002
Battery system
What I forgot to say was that I used this system in my F117 - our field is rough, and there's every chance that even a touch-and-go will end with a non retracting retract system.
The added weight is negligible - a second 500mah rx pack is more than sufficient. I used a 280mah pack with no problems.
Tony
Old May 05, 2003, 09:20 AM
Joined Oct 2001
All you have to do is disconnect the red wire going from the retract servo to the receiver.
Here's what I would do: Get a short quality Y-harness, a standard switch harness, and your retract battery. At the receiver end of the Y-harness, extract the center pin from the servo plug by carefully lifting the plastic catch with an exacto knife. Insulate this pin with heat shrink tubing to prevent any shorts. Now, just connect the battery and switch harness to the one leg of the Y-harness, and the retract servo to the other.
mkirsch1 is offline Find More Posts by mkirsch1
Old May 05, 2003, 01:51 PM
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
One of these days I'm going to have to learn how to do line drawings on the PC. For now please forgive my crude manual drawing.
The way I've tackled this problem before on my Twin Bushwacker used one switch to operate a 4.8V pack for the RX and a 6V pack for the retracts. The switch opened and closed the negative lead in the radio system on both packs. The four channels of flight control were operated as you would normally do them. The retract servo on the other hand got the + from the 6V pack and the - and signal wires from the retract channel on the RX. Hope this makes sence.
GregG is offline Find More Posts by GregG
Old May 05, 2003, 02:22 PM
Member
William A's Avatar
Tacoma,WA USA
Joined Jun 2001
Greg, try this.
http://www.microcode.com/downloads/student.htm
William A is offline Find More Posts by William A
Question extra battery needed for retract servo? fullscalepilot87 Fuel Plane Talk 8 Mar 23, 2007 08:44 AM
Discussion Esc and separate battery for rcvr/servo Jack Hyde Electric Sailplanes 13 Feb 03, 2006 08:07 PM
separate BEC for retract servo? hul DIY Electronics 2 Apr 09, 2005 02:29 AM
Looking for retract servo coloradoz Aircraft - General - Radio Equipment (FS/W) 0 Feb 20, 2005 12:27 PM
Pager motor retract servo, how to build? JonB Indoor and Micro Models 1 Apr 04, 2002 01:29 AM
