Old Nov 28, 2009, 04:28 PM
kadil is offline
Find More Posts by kadil
unconventional :-)
kadil's Avatar
Brisbane north, Australia
Joined Feb 2009
Tools - cutter, sander, drill combo
Years ago recall seeing television advertisements for work centers that had a table saw, sanding disc and drill all in one neat (albeit cheap) device. I was think this might be a useful item for foamie construction. I googled it but cannot find any trace. Does anyone know what these things were called or if they still sell them?
I think the table saw was an inverted jigsaw, and the sanding disc has a platform so you could hold pieces at right angles to the disc?
kadil is offline Find More Posts by kadil
Old Nov 28, 2009, 04:36 PM
space 1 is offline
Find More Posts by space 1
USA
Joined Apr 2007
popular science & mechanics illustratet
space 1 is offline Find More Posts by space 1
Old Nov 28, 2009, 07:58 PM
DaDesign is offline
Find More Posts by DaDesign
ɹǝsn pǝɹǝʇsıƃǝɹ - inverted!
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
Shopsmith??
http://www.shopsmith.com/
DaDesign is offline Find More Posts by DaDesign
Old Nov 28, 2009, 09:41 PM
philba is offline
Find More Posts by philba
Prop Buster Extraordinaire
philba's Avatar
Seattle
Joined Aug 2009
A friend had a shopsmith. Probably the biggest gripe against it is the set up time for a given tool. If you have to switch between tools, it can get very tedious. Couple that with a really high price. If you are just doing modeling and other small projects, you can get a scroll saw, small benchtop drill press and small disc sander for fairly cheap. It will take up about the same amount of space. If you have the space, toss in a small bandsaw and you will have a nice shop for modeling for a LOT less than a shopsmith.
philba is offline Find More Posts by philba
Old Nov 28, 2009, 10:13 PM
kadil is offline
unconventional :-)
kadil's Avatar
Joined Feb 2009
the one I saw was more of a toy, but would be durable working with foam
Old Nov 29, 2009, 07:00 AM
DaDesign is offline
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
This is what I did. Works great! Also if one tool breaks you only replace that tool but mine has been working fine forever. You don't use them all that much at a time.
Old Nov 30, 2009, 12:58 AM
kadil is offline
unconventional :-)
kadil's Avatar
Joined Feb 2009
is it worth mounting a jigsaw upside-down under the bench and using a thin blade to do the work of a band saw? Not ideal I know, but various woodworkers around the net seem to have done this.
Old Nov 30, 2009, 02:41 AM
philba is offline
philba's Avatar
Seattle
Joined Aug 2009
more like a poor man's scroll saw. You would need to make a hold down and a blower to clear sawdust away would be very useful.
Decent (though not great) scroll saws can be had for <$100. Harbor Freight has one for $79.
Old Nov 30, 2009, 05:47 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
My little 10" band saw is one of the most-used power tools I have on the bench. I had a local blade repair house make me a combination blade so I can cut wood, plastick or metal (32tpi, IIRC)
Gene Bond is offline Find More Posts by Gene Bond
Old Nov 30, 2009, 06:08 AM
RogueTitan is offline
Find More Posts by RogueTitan
Foam Av8r
RogueTitan's Avatar
In Teh Garage (Rossville, GA. USA)
Joined Sep 2008
I Loves my little Dremmel and my router and other attatchments, these things are very versatile for working with foam
I also have one set up with a flex shaft which is also very handy.
RogueTitan is offline Find More Posts by RogueTitan
Discussion Looking for a power workshop toy (lathe, drill, sander, jigsaw) TEM The Builders Workshop 2 Oct 21, 2013 12:53 PM
Discussion 100 Year Old Scotch on the Rocks: Drill Baby Drill! Looooeeee! Life, The Universe, and Politics 26 Nov 19, 2009 02:50 PM
Sold Misc building tools, Higley Hinge, mitre sander, CG machine, Etc. Steve H. Aircraft - General - Miscellaneous (FS/W) 6 Aug 07, 2007 07:29 PM
For Sale 32" Cutter/plotter With Signgo Pro, Supplies, Tools, Clipart, DVD Turorial $1,200 foxesfarm Non R/C Items (FS/W) 0 Jan 29, 2007 11:15 AM
