Old Nov 28, 2009, 01:04 PM
claude_3d is offline
Find More Posts by claude_3d
claude_3d's Avatar
Zapopan, Jalisco
Joined Mar 2008
Help!
Advice for powering a SEBART MISS WIND 50E
Info on the next post, below
claude_3d is offline Find More Posts by claude_3d
Old Nov 28, 2009, 02:47 PM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
Originally Posted by claude_3d View Post
Hi Guys:
I was wondering if I can make move nicely the sebart miss wind using the:
torque 4016- 500 KV 80 amp eliteboss ESC and flightpower 5S 3700. I assume and have check some numbers that I will be drowning to much watts for the motor and will get hot with an airplane around 7 pounds.
I was using a 15x8 on an EF extra 300 58" and the motor was very happy.
Any advice of using the equipment listed for the miss wind 50?
thanks guys,
Hi claude,
99% of the readers have no idea what a sebart miss wind is. Could you provide a link to the following?
The plane, the motor, the battery, and the prop.
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Nov 30, 2009, 09:59 AM
claude_3d's Avatar
Zapopan, Jalisco
Joined Mar 2008
links
HI 99% of people who dont know what is SEBART (italian brand owned by Sebastiano Silvestri whose factory in china is the same as Extreme Flight) one of the models for F3A that they are selling is the:
miss wind 50e http://www.sebart.it/50E-class.html
So the things is:
I have very few experience with electrics and setup for power and the following gear is laying around ready for a new airplane:
extreme flight torque revolution 3D Flying - For .40-.60 sized 3D aircraft.
MODEL 4016T-500
TURNS/KV 16/500
WEIGHT 280 gr
MAX CURRENT 80 amp burst (20 sec)
SHAFT DIA. 6mm
PROP SIZE 5S 14x7-15x8
I have the Airboss 80 Elite
number of cells 6-18NC 2-6Lipo
BEC 3 AMP
Current peak 80 amps
and flight power 5S with 3900 mah.
I think i will be using a 15x8 APC electric or maybe the 16x8 or 16x6.
The plane is around 6.6 pounds RTF. do you think that if I put this gear to the Miss WIND 50e it will be underpowered?
Any suggestions?
thanks guys
Claude
Old Dec 04, 2009, 12:08 PM
jooNorway is offline
Find More Posts by jooNorway
jooNorway's Avatar
Norway
Joined Jul 2005
Any suggestions?
thanks guys
Claude
The setup will work OK. Same numbers I run in my Angel 50, except I have 5000mAh batteries. Select propeller to get 1200Watt or more.
jooNorway is offline Find More Posts by jooNorway
Sold Sebart Miss Wind 50E Bieplane Tommyb240 Aircraft - Electric - Airplanes (FS/W) 7 Sep 18, 2009 10:50 PM
Help! Can anybody share the transmitter set up for a DX6i Chooby Coaxial Helicopters 0 Aug 27, 2009 07:45 PM
Question Set up for Sebart 50E claude_3d Sport Planes 0 May 15, 2009 05:31 PM
Discussion Fuel tank set up problems: unable to fill with wind up filler arukum17 Beginner Training Area (Fuel) 3 Dec 28, 2007 03:43 PM
help with radio set up for shogun servos all move together falcon41176 Mini Helis 2 Aug 09, 2004 01:27 PM
