Old Oct 11, 2012, 07:32 PM
Bugman Jeff is offline
Find More Posts by Bugman Jeff
I'm a Registered User
Evansville, WI
Joined Dec 2006
On all my pusher prop wings, I think I've only broken a prop on landing once or twice. Here's my solution to powering the Xeno. It's a 3000KV 24g "blue wonder" with an 8x4 folder. The ESC is much bigger than it needs to be, but I needed weight ahead of the CG anyway. I use it on 3S, and while the performance isn't rocketship like, it keeps the plane in the air just fine. It's made so the wing still folds too. The black circle on the left wing is a lost model alarm. The wing is notched for prop clearance, and put a plastic plate across the back of the prop yoke to keep the blades from over folding(if a blade goes over center to far, it won't fling out on powerup and will shake the plane to pieces. Not a problem on pullers because the blades fold against the fuse)
Bugman Jeff is offline Find More Posts by Bugman Jeff
Old Oct 21, 2012, 06:15 PM
meanbaby is offline
Find More Posts by meanbaby
meanbaby's Avatar
United States, PA, Mt Pocono
Joined Jul 2007
Jeff, can you explain how you made it thats it still foldable?
-pete
meanbaby is offline Find More Posts by meanbaby
Old Oct 21, 2012, 07:01 PM
Evansville, WI
Joined Dec 2006
Pretty simple really. The motor mount is only screwed onto the right wing half(you can see the three white nylon screws in that half). There is enough flex in the wires that they don't need to be unplugged although they can be if need be.
Old Oct 21, 2012, 07:20 PM
meanbaby is offline
meanbaby's Avatar
Joined Jul 2007
ahhh i get it, so you offset the mounting screws to one side so to speek and still able to fold it, sweet idea, ima going steal your idea if you dont mind
-pete
Old Oct 21, 2012, 09:41 PM
Evansville, WI
Joined Dec 2006
Feel free, I stole it myself
Old Oct 23, 2012, 12:53 PM
meanbaby is offline
meanbaby's Avatar
Joined Jul 2007
not the best but cheap!!!
made my mount like Jeff's,and still foldable, need to pick up a few bolt and nut and ready for maiden this weekend
-pete
Old Oct 23, 2012, 06:45 PM
Evansville, WI
Joined Dec 2006
Looks nice, cheap is good If I might make a suggestion, trim the top of your motor mount round. It'll be a bit more aerodynamic, and allow more cooling air to get to the motor.
Old Oct 23, 2012, 07:42 PM
meanbaby is offline
meanbaby's Avatar
Joined Jul 2007
good idea!!! thanks for the round top heads up
-pete
Old Dec 03, 2012, 08:45 AM
billyd60 is offline
Find More Posts by billyd60
Gravity is patient............
Joined Mar 2006
Am I the only one launching this by hand as designed? I haven't had any strikes. What am I doing right (or wrong lol)? Is this a real issue or another internet mythos like lipo fires and bigfoot?
billyd60 is offline Find More Posts by billyd60
Old Dec 03, 2012, 10:06 AM
Papangue is offline
Find More Posts by Papangue
Reunion
Joined Nov 2010
I also launch it by hand, three fingers in the right holes, no gaz. When it is one meter away, full gaz... It works well, but always go against the wind.
Papangue is offline Find More Posts by Papangue
Old Dec 03, 2012, 12:06 PM
nioa is offline
Find More Posts by nioa
More Motors, More Fun... :-)
nioa's Avatar
Phoenix, AZ
........put a plastic plate across the back of the prop yoke to keep the blades from over folding (if a blade goes over center to far, it won't fling out on powerup and will shake the plane to pieces. ..........
I too hand-launch, and apply power when the plane clears my fingers.
I had difficulties launching because the props would sometimes not be able to spin up fast enough to get the plane flying due to the props trying to sort themselves out. Most of the time this resulted in expensive repairs to the Xeno power train.
Thanks to Bugman Jeff for his simple and effective modification to assure a good power launch.
Nick
nioa is offline Find More Posts by nioa
Old Dec 03, 2012, 12:21 PM
billyd60 is offline
Joined Mar 2006
No I'm launching it powered up.
I suppose it's possible to hit your fingers, but I'm wondering why I haven't? Just luck?
Old Dec 03, 2012, 06:54 PM
Evansville, WI
Joined Dec 2006
I give mine a good throw then throttle up. As long as it's into the wind, it seems to work just fine.
Old Dec 04, 2012, 04:21 AM
rkopka is offline
Find More Posts by rkopka
Electric only
rkopka's Avatar
Graz - Austria
Joined Nov 2002
Me, too - no wounds, yet.
RK
rkopka is offline Find More Posts by rkopka
Old Dec 04, 2012, 05:36 AM
francesco67 is offline
Find More Posts by francesco67
Florence, Italy
Joined Feb 2010
RK
It is possible...believe me, pay attention!
I learnt on my blood that it is important to withaw down fastly your hand after the launch if you want to launch it powered
francesco67 is offline Find More Posts by francesco67
New Product Multiplex Xeno checkup Flying Wings 129 Apr 10, 2010 08:47 AM
Yippee! New Multiplex Models 2009: MERLIN and XENO Doubletap Slope 12 Feb 26, 2010 10:31 PM
Discussion XENO, New to Multiplex??? sparkie624 Hitec/Multiplex USA 4 May 27, 2009 06:16 PM
Discussion Multiplex Xeno as FPV JakAck FPV Talk 7 Mar 09, 2009 06:40 PM
New Product Multiplex Xeno soundcheque Flying Wings 2 Mar 03, 2009 09:25 PM
