Old Sep 03, 2012, 03:19 PM
mopetista is offline
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
Photos of tractor pusher pod
Here are some pics
The template is really good for the essential part: the lower portion where you
fix it to the Xeno - the upper part is up to you, depending on prop size etc.
I just tried it, and it works, you might go for slightly smaller angle up, but
it worked ok at that power level
for mounting the motor I just glued on two EPP pieces, and put a plywood
piece in front.
Most work is to get the curvature right at the bottom, for stability you need
to glue on some wood, and file it to the right curvature. I put some rubber
pieces on for vibration damping
I think it's 3mm plywood, anyway that should be fine
most importanty I learned that it won't work to try to fix it like the MPX
power cowling, the thin plywood gave way after the first hard landing
Better to just have some plywood extending below, and press the pod
to the plane usiing a zip tie around the inner body, just make small holes on
both sides to get the zip tie through
good luck with yours!
cheers
Clemens
mopetista is offline Find More Posts by mopetista
Old Sep 03, 2012, 03:55 PM
francesco67 is offline
Find More Posts by francesco67
Florence, Italy
Joined Feb 2010
Very clear now Clemens, thanks a really a lot for your pacience!
francesco67 is offline Find More Posts by francesco67
Old Sep 16, 2012, 01:22 PM
Angelus1383 is offline
Find More Posts by Angelus1383
Italy, Lazio, Rome
Joined Sep 2012
Hi guys,
in the next days i'll receive my xeno. I'm reading this thread to prepare me to build it in the best way. I have a question about how to move the linkages on top.
I don't understand how to calculate the right slope to dig the hole across the wing. Can anyone explain to me how to do this? Unfortunately I don't speak german so the instructions reported in link at post 527 are unuseful to me, but I wish do a thing like this.
Angelus1383 is offline Find More Posts by Angelus1383
Old Sep 17, 2012, 03:09 PM
nioa is offline
Find More Posts by nioa
More Motors, More Fun... :-)
nioa's Avatar
Phoenix, AZ
Hi, Welcome,
My Xeno servos are on the top of the wing. Use the servo cut-outs on the bottom of the wing as a guide to cut through the wing with a sharp razor. Once you have cut out the pieces, slide them to the "bottom" and re-glue them in place.
Nick
nioa is offline Find More Posts by nioa
Old Sep 18, 2012, 03:21 PM
Italy, Lazio, Rome
Joined Sep 2012
Originally Posted by nioa View Post
Hi, Welcome,
Nick
Hi Nioa,
thanks for your reply.
I don't want put the servos on top of the wing. I want put on top only the linkages as shown in post 527 but I don't understand how calculate the correct slope to dig the wings. Can you explain me how to do this?
Angelus
Old Sep 18, 2012, 04:08 PM
Koo is offline
Koo
Find More Posts by Koo
Koo
A semi-advanced FPV newbie
Koo's Avatar
United States, OH, Oxford
Joined Mar 2012
I just ordered one of these from eBay and cant decide if I want to make this a glider or more like an acrobatic plane with lots of power. Would adding 50 grams of weight make a big difference on how this plane would glide?
Koo is offline Find More Posts by Koo
Old Sep 18, 2012, 04:17 PM
nioa is offline
nioa's Avatar
Phoenix, AZ
Originally Posted by Angelus1383 View Post
Hi Nioa,
Angelus
Angelus, I think that contributor just poked the linkage through the wing by estimation. I know you don't want the servo on the top of the wing, but consider also that the control arm can easily be moved to the top of the wing too. If the control arm is on the bottom of the wing, you can still damage the servo and the linkage in a bad landing. Moving the servo and the control arm to the top of the wing is the most protected position.
Nick
Old Sep 28, 2012, 01:06 PM
Left Coast DJ is offline
Find More Posts by Left Coast DJ
Left Coast DJ's Avatar
Joined Jan 2012
Thinking about picking up a Xeno. Does the kit come with a motor mount to attach an outrunner?
Left Coast DJ is offline Find More Posts by Left Coast DJ
Old Oct 09, 2012, 01:51 PM
Koo is offline
Koo
Koo
Koo's Avatar
Joined Mar 2012
Sadly no. You will have to make your own. Many people use plywood and mounts from other planes.
Old Oct 10, 2012, 09:01 AM
rkopka is offline
Find More Posts by rkopka
Electric only
rkopka's Avatar
Graz - Austria
Joined Nov 2002
Around here the motor set was sometimes sold quite cheap. ESC and motor with local (not Honkong) prices and a bit for the mechanics were not much cheaper than the set which works quite well.
At the moment the regular price here is 85 for the set and 50 only motor and ESC.
And a picture of what I used with my first XENO:
RK
rkopka is offline Find More Posts by rkopka
Old Oct 10, 2012, 10:32 AM
Koo is offline
Koo
Koo
Koo's Avatar
Joined Mar 2012
RK
Looks great! I picked up a new xeno on ebay for $35 and I'm still in middle of building it. Is a folding prop "a must"? I got plenty of 7x6s APCs so if I would buy, lets say a 1600kv motor with 300 watts, I think that would work pretty well. I never used folding props and they seem to be expensive-ish.
Old Oct 10, 2012, 12:14 PM
jpgcag is offline
Find More Posts by jpgcag
The desert collection
jpgcag's Avatar
Yuma AZ/Puyallup WA
Joined Jun 2006
I have the Multiplex motor set on mine, but I've got several other wings that I just use a regular prop without any problems, and I fly out in the desert on gravel and sand.
If I were to rebuild my Xeno or build a new one, I'd put the servos on the top rather than underneath where the control horns or servo arms can be damaged. I wrecked one servo with just a normal landing, on the sand. Other than that I really like mine.
Jack
jpgcag is offline Find More Posts by jpgcag
Old Oct 10, 2012, 10:35 PM
Bugman Jeff is offline
Find More Posts by Bugman Jeff
I'm a Registered User
Evansville, WI
Joined Dec 2006
The only reason for the folding prop is that this was intended to be a gliding/soaring plane and the folding prop is more aerodynamic while gliding.
Bugman Jeff is offline Find More Posts by Bugman Jeff
Old Oct 11, 2012, 09:03 AM
rkopka is offline
Electric only
rkopka's Avatar
Graz - Austria
Joined Nov 2002
AND it will survive better at landings. Gliding with a normal prop is not very funny.
They may be a bit more expensive, but they probably won't break. But you need to limit the blade travel for tail props so that it doesn't swing to the front or cross in the back.
The servos can stay where they are, but you can put the linkage to the top which is definitely a good idea.
RK
Old Oct 11, 2012, 03:14 PM
Joined Jan 2012
The motor mount situation of the Xeno reminds me more of the wonky mounts on the TwinJet more so than the streamlined FunJet and Ultra!
New Product Multiplex Xeno checkup Flying Wings 129 Apr 10, 2010 09:47 AM
Yippee! New Multiplex Models 2009: MERLIN and XENO Doubletap Slope 12 Feb 26, 2010 11:31 PM
Discussion XENO, New to Multiplex??? sparkie624 Hitec/Multiplex USA 4 May 27, 2009 07:16 PM
Discussion Multiplex Xeno as FPV JakAck FPV Talk 7 Mar 09, 2009 07:40 PM
New Product Multiplex Xeno soundcheque Flying Wings 2 Mar 03, 2009 10:25 PM
