Old Jun 29, 2012, 11:07 AM
Endlesslag is offline
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Orlando
Joined Jan 2011
Gave my xeno a short maiden flight today. I obviously set it up ok....it flies fast! took 0 trim, launched power off, glided for a bit, and then hit the power. Can you say rocketship??
Anyway, all went well, and it flies great!
I might have hit 100mph, I crossed the absolutely huge parking lot at the local YMCA in about 2 seconds.
At slower speed it wobbles a bit for sure, what's the easiest fix for that?
Endlesslag is offline Find More Posts by Endlesslag
Old Jun 30, 2012, 01:52 PM
jpgcag is offline
Find More Posts by jpgcag
The desert collection
jpgcag's Avatar
Yuma AZ/Puyallup WA
Joined Jun 2006
Congrats on your successful maiden. The low speed wobble fix done by several is to increase the size of the winglets. I haven't done it myself, as I fly faster so the wobble is minimized, but its still there.
Jack
jpgcag is offline Find More Posts by jpgcag
Old Jun 30, 2012, 02:54 PM
Endlesslag's Avatar
Joined Jan 2011
yeah, the wobble is only there when on landing approach. not a big deal to me, if it drops a wing I can just power out of it
Old Jul 01, 2012, 10:27 AM
hobie14 is offline
Find More Posts by hobie14
hobie14's Avatar
Western Europe 52.7 N 8.9 W
Joined Jul 2007
I hope someone has the guts to cut the tips off the wing and put some vertical tips in see if it would stop the wobble ....... maybe also remove the existing fins ? ......
I hate wobbles ! .......
hobie14 is offline Find More Posts by hobie14
Old Jul 01, 2012, 05:38 PM
Endlesslag's Avatar
Joined Jan 2011
flew again today.
not 100.....88.7 mph according to a rc doppler app on my phone.
Not half bad. With a prop change I could probably do 100 if I really wanted to, but with this plane I think I'm just going to fly it like a glider with an occasional high speed pass.
Old Jul 01, 2012, 06:25 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
hobby People has been trying to liquidate their stock of Xenos since their Warehouse clearance sale, but can't get rid of them, so they had a 1 day sale for the "leftover" stock including lots of Xeno kits, the leftover sale has been extended, they are going for $50, so if anyone actually wants one, for $50:
http://www.hobbypeople.net/index.php...plane-kit.html
Doubletap is offline Find More Posts by Doubletap
Old Jul 01, 2012, 06:28 PM
Endlesslag's Avatar
Joined Jan 2011
If I had $50 in paypal I'd grab a second one now...grrr
Old Jul 21, 2012, 01:45 AM
BravoGolf is offline
Find More Posts by BravoGolf
Spearheading an Alliance
BravoGolf's Avatar
United States, CO, Aspen
Joined Oct 2010
what motor
Ok, mine now has a 480 size motor in it, pulling 290 watts or so on a full 3s Should be lots of fun!
Sorry, I'm not clear, what 480 motor did you end up going with and from who? Did it drop right in. I'm looking for a more affordable motor than the himax and need it to drop right in and bolt on without messing around.
BG
Anyone else have suggestions for a replacement motor with sames specs and hole pattern?
BravoGolf is offline Find More Posts by BravoGolf
Old Jul 21, 2012, 03:09 AM
EuroDriver is offline
Find More Posts by EuroDriver
Monaco
Joined Dec 2006
My Xeno does not wobble any more ! Turbulator helps ?
On its maiden flight, my Xeno wobbled big time, but on third approach for landing I hit a tree. The leading edge in front of the left rudder was a bit dinged up. On all of the subsequent flights the Xeno does not wobble at all !
It seems like a bit of turbulence gereration in front of a fin is enough to make the fin more effective and she will not go into the oscilating yaw
My suggestion is to apply some crinkled masking tape close to the leading edge in front of each fin to cause some turbulence
Turbulators are moulded into the underside of the MPX Cularis wings to increase the effectiveness of the ailerons
EuroDriver is offline Find More Posts by EuroDriver
Old Jul 21, 2012, 08:03 AM
Endlesslag's Avatar
Joined Jan 2011
BG
I ended up going with this:
http://www.headsuprc.com/servlet/the...h-11%29/Detail
I needed to drill two new mounting holes, and do some fancy work with a screwdriver to get the bottom one in, but in the end it all works really well. maybe if you went with their 450 it would fit in the existing holes.
Old Jul 23, 2012, 02:26 AM
francesco67 is offline
Find More Posts by francesco67
Florence, Italy
Joined Feb 2010
BG
This is a very affordable and good replacement for the tuning version of the himax motor: http://www.hobbyking.com/hobbyking/s...dProduct=19036 very easy to adapt to the xeno, as it has got a 4mm shaft
francesco67 is offline Find More Posts by francesco67
Old Aug 02, 2012, 05:40 PM
sparky210 is online now
Find More Posts by sparky210
United States, NY, Buffalo
Joined Jul 2009
xeno build
when installing the bearing ,does it press into the end plastic piece
on the power system?????
sparky210 is online now Find More Posts by sparky210
Old Aug 02, 2012, 05:48 PM
Endlesslag's Avatar
Joined Jan 2011
Yep. It's fairly hard to get in there though. I ended up using a block of wood and a punch and a hammer to get it in.
Old Aug 02, 2012, 09:44 PM
ZSimon is offline
Find More Posts by ZSimon
Canada, ON, Mississauga
Joined May 2011
Hopefully I'm not late to the party..
Here is my handy work on my FPV Xeno..
There are many like it, this one is mine
Whats that.. bump?!
Where did the ESC go.. ?
Oh it is all routed to the inside of the shaft housing ;-)
Modified canopy to flush-fit the wires and give me maximum battery space (up to 2300mah)
GoPro screw+nut into the canopy + glued
Video: http://youtu.be/I-UWgtfeJ7E?hd=1
ZSimon is offline Find More Posts by ZSimon
Old Aug 03, 2012, 05:25 AM
Joined Jul 2009
thanks for the info Endlesslag
one last question what with the two rubber bands i recieved with the power kit ????
New Product Multiplex Xeno checkup Flying Wings 129 Apr 10, 2010 08:47 AM
Yippee! New Multiplex Models 2009: MERLIN and XENO Doubletap Slope 12 Feb 26, 2010 10:31 PM
Discussion XENO, New to Multiplex??? sparkie624 Hitec/Multiplex USA 4 May 27, 2009 06:16 PM
Discussion Multiplex Xeno as FPV JakAck FPV Talk 7 Mar 09, 2009 06:40 PM
New Product Multiplex Xeno soundcheque Flying Wings 2 Mar 03, 2009 09:25 PM
