Old May 30, 2012, 06:13 AM
francesco67 is offline
Find More Posts by francesco67
Florence, Italy
Joined Feb 2010
Originally Posted by nioa View Post
I always thought it best to ask those more knowledgeable. Sometimes the answers surprise you, and a great bargain is revealed.
Sounds like you are satisfied with quality of the stock prop and its price. I will probably just go with that.
I bought a graupner replacement, the price was similar to the original prop, that anyway was not avalilable in Italy.
I am satisfied with the quality, would not try to save 5 USD or so, buying a low cost propeller: you are not supposed to break many props because of its position, protected.
I preferred to save more money buying an esc and a replacement motor from HK, when I had to replace both....
francesco67 is offline Find More Posts by francesco67
Old May 31, 2012, 07:17 AM
DOCFIGHT is offline
Find More Posts by DOCFIGHT
Searching Field
DOCFIGHT's Avatar
Joined Oct 2011
Hi guys !
Take a look of the 5th Episode of our Spring Adventures : BATWING with Gopro.
Flight test of the Xeno by Multiplex with the Electric kit and a Gopro Hero on board.
Watch the other Episodes : http://www.matterhorns.org/pages/vid...dventures.html
Multiplex Xeno with GoPro (3 min 16 sec)
Have Fun & Fly.Over.
www.matterhorns.ch
DOCFIGHT is offline Find More Posts by DOCFIGHT
Old Jun 18, 2012, 01:38 PM
Bowman813 is offline
Find More Posts by Bowman813
Bowman813's Avatar
France
Joined Sep 2007
Hello pilots!
Here is my Xeno, it's my first flying wing. Finding the propulsion set too expensive, I built the motor support like in this French site http://www.jivaro-models.org/xeno_mu.../page_xeno.htm then made my own vacuumformed body.
Motor: Turnigy 2217 1050kv
Prop: Graupner folding prop 8x6
ESC: Red Brick 30A
Battery: Turnigy 3S 20C 1800mAh
Servos: HK939MG
AUW: 820g
First flight yesterday with a lot of wind, here is a video of the second flight with a missed landing (rather a crash ) at the end. No broken parts, it's very strong!
Denis
Multiplex XENO - 2ème vol 17/06/2012 - 2nd flight 06/17/2012 (3 min 15 sec)
Bowman813 is offline Find More Posts by Bowman813
Old Jun 23, 2012, 09:47 PM
Endlesslag is offline
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Orlando
Joined Jan 2011
Just got one of these for my birthday. Looks like a well put together kit, anyone have a good electronics setup for it using the stock power pod thingy?
I'd like to keep it clean looking
If possible I'd like to get everything from the US, and from one place.
Endlesslag is offline Find More Posts by Endlesslag
Old Jun 23, 2012, 09:54 PM
Endlesslag's Avatar
Joined Jan 2011
Might have found some stuff I didn't see before:
HURC 450 sport motor- http://www.headsuprc.com/servlet/the...2C-28mm/Detail
HURC 30A ESC http://www.headsuprc.com/servlet/the...-30-Amp/Detail
And a pair of these: http://www.headsuprc.com/servlet/the...0-Metal/Detail
That sound like a decent setup that'll drop right in?
Old Jun 24, 2012, 04:59 AM
Bowman813's Avatar
France
Joined Sep 2007
How to launch Xeno
Hello pilots!
After several bad launches without help, here is a method which always works for me. NOTE: I use a transmitter stand and I'm in mode 2.
Enjoy!
Denis
Comment lancer la Xeno - How to launch Xeno (0 min 35 sec)
Old Jun 26, 2012, 03:58 AM
rkopka is offline
Find More Posts by rkopka
Electric only
rkopka's Avatar
Graz - Austria
Joined Nov 2002
Changing hands wouldn't work for me. I prefer to throw it at full power and then the hand finds down quick enough.
RK
rkopka is offline Find More Posts by rkopka
Old Jun 26, 2012, 06:33 AM
Endlesslag's Avatar
Joined Jan 2011
RK
I did a test glide on mine, if you give it a good hard throw there should be plenty of time to launch power off then get a hand back on the tx
Old Jun 26, 2012, 02:46 PM
Bowman813's Avatar
France
Joined Sep 2007
I tried the glide method, but crashed each time! Now, with the changing hands method it works every time, at least for me
Denis
Old Jun 26, 2012, 03:47 PM
Endlesslag's Avatar
Joined Jan 2011
Denis
How much does yours weigh and where is it balanced?
Old Jun 27, 2012, 12:21 AM
Bowman813's Avatar
France
Joined Sep 2007
820 g and perfectly balanced at 220 mm from the front, as said in the manual. In the video the wing go to the left because of a gust of wind, otherwise it takes off straight.
Denis
Old Jun 27, 2012, 10:05 AM
hugofly is offline
Find More Posts by hugofly
Wallington, New Jersey, USA
Joined Apr 2010
This is how I throw mine: I put a mix in place where I use the flap switch to give a little bit of up elevator. I'm right handed.
- Engage the switch to give slight up elevator
- Toss it with my right hand with no power, transmitter in my left hand. Xeno does NOT aim for the ground, but it goes straight (slightly up, losing speed quickly)
- Give full throttle as quickly as possible, which I do before I even grab the right stick completely
- Xeno goes nicely up without me having to give up elevator (because of the mix)
- once I get a hold of myself and the transmitter and the Xeno, I disengage the flap switch and fly!
This method works for me pretty much every time, I crash it only if I totally mess up the toss, which doesn't happen a lot (but it does happen :-) ). I tried the power on method in the beginning, but when I mess up the toss, it just goes into the ground at full throttle.
hugofly is offline Find More Posts by hugofly
Old Jun 27, 2012, 11:57 AM
jswain is online now
Find More Posts by jswain
Gasbags & Gussets
jswain's Avatar
Riverside, Ca
Joined Feb 2009
a "ahaa!!!" moment for me
Originally Posted by hugofly View Post
This is how I throw mine: I put a mix in place where I use the flap switch to give a little bit of up elevator. I'm right handed....- Engage the switch to give slight up elevator I tried the power on method in the beginning, but when I mess up the toss, it just goes into the ground at full throttle.
Hugofly, This should work out well for me!.
When i underhand toss my little edf's, its at full power (and easier to keep everything level underhanded) but with a flying wing like this, if it goes poorly it will just auger itself into the ground at full power.
So with flying wing's its toss it, then power on with a bit of up trim.
The worse that can happen is it glides a few feet away in front of you undamaged if the toss goes poorly and you leave the throttle alone.
Thank you for the tip!!!
js
jswain is online now Find More Posts by jswain
Old Jun 27, 2012, 12:31 PM
Endlesslag's Avatar
Joined Jan 2011
Ok, mine now has a 480 size motor in it, pulling 290 watts or so on a full 3s Should be lots of fun!
Old Jun 27, 2012, 01:25 PM
Endlesslag's Avatar
Joined Jan 2011
Ok, weighing in at 850g ready to go, my xeno!
161 watts per pound, nice and spirited performance
Glide test in the yard went well, looking forward to the maiden.
New Product Multiplex Xeno checkup Flying Wings 129 Apr 10, 2010 08:47 AM
Yippee! New Multiplex Models 2009: MERLIN and XENO Doubletap Slope 12 Feb 26, 2010 10:31 PM
Discussion XENO, New to Multiplex??? sparkie624 Hitec/Multiplex USA 4 May 27, 2009 06:16 PM
Discussion Multiplex Xeno as FPV JakAck FPV Talk 7 Mar 09, 2009 06:40 PM
New Product Multiplex Xeno soundcheque Flying Wings 2 Mar 03, 2009 09:25 PM
